Question about Refrigerators
Fridge not cool enough - Whirlpool model WRX38RWH6
Hi, I'm having trouble with my fridge not being cold enough (Whirlpool WRX38RWH6). I've put a thermometer in the fridge and the temperature just isn't consistent - some days it is ok & others it gets really warm. The temperature control has the options "cold" and "colder". I've put it on "colder". The temperature control dial also has an option of "WPL(38/42)" ....do you know what that means?....any way of getting the fridge colder or do you think its just broken! ...... I was also having a problem where the fridge drips water from a vent just inside the top of the fridge at the front. I checked the drainage pipe inside the fridge & it isn't blocked - I've seen someone else has had this problem posted on this website & the solution was to check a drainage area in the freezer. Do you think this is related to the temperature issues I'm having?
Thanks for your help!
5 Suggested Answers
SOURCE: Dripping water inside
At the back of the refrigerator, you will find a evaporation tray, unscrew it and empty it.
Posted on Sep 06, 2008
docjohn174
  • 943 Answers
SOURCE: Leaking Whirlpool fridge
Thanks for the question When this happens if the evaporator is all frosted up you have a derost problem could be your timer or your defrost thermostat which is located on the coils of the evaporator you can check this with a volt meter these meters are cheap you dont need a very expensive for ahout 20 dollars or the defrost timer one of the two is your problem thanks for the question The appliancedoc
Posted on Sep 11, 2008
ginko
  • 19396 Answers
SOURCE: Refrigerator does not cool
If the refrigerator cooling is poor, it may be a problem with the thermostat, the compressor, or the evaporator fan. If ice is accumulating at the back of the fridge, that can also be a reason for poor cooling.
See aso the links below for a more detailed explanation:
It's not cool
Cooling is poor
Posted on Oct 04, 2008
aborcass
  • 2651 Answers
SOURCE: refrigerator whirlpool model wrx38rwh6
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Oct 26, 2008
SOURCE: Model GE TBX16SPCL Water dripping from
Michael, I live in an apartment that has this model. I had a similar problem that the apartment maintenance man concluded was a clogged vent. I don't no precisely what he did to fix it but it involved opening the vent compartment and cleaning it out. Be sure to take everything off the shelves of the refrigerator before your start because it makes a mess. Good luck.
Posted on Jul 05, 2009
Tip
Whirlpool Fridge
I am having trouble with my Whirlpool Fridge single door fridge. The top freezer is getting too cold and freezing the food too much and the bottom of the fridge is not cold enough, changing the settings on the fridge only makes it worse.
I have just recently chenged the fan, so what could be the proplem and how can I fix it.
on Feb 11, 2008 | Whirlpool ER6AHKXPQ Top Freezer...
Fridge not cold enough and freezer too cold
check the fan to see if it is running.
Sep 20, 2012 | Whirlpool Refrigerators
My fridge/freezer model no.FRSS36AF25/3 - fridge section does not seem cold enough.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 15, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool fridge not keeping cold, but freezer is working fine. model et4wskxkoo1
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 17, 2010 | Whirlpool Refrigerators
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
heatman101
Nov 17, 2010 | Whirlpool ED5FHEXMQ Side by Side...
Whirlpool 6th sense side by side fridge/freezer 25rid4 model,freezer working fine but fridge part does not cool
heatman101
Oct 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My whirlpool fridge makes a loud humming noise when the door is closed. It is not freezing items in the freexer and is not cooling items in the fridge section. The freezer is above the fridge section in...
The fan is hitting ice build up...
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
heatman101
Oct 11, 2010 | Whirlpool Refrigerators
Hi where can I obtain spare parts for a whirlpool fridge model # wrx38rwh6 - I am after a bottom, shelf, vegetable crisper and big milk side shelf. Do you know the price? Thanks Tara
Check phone book for local part distributor or repair facility, most repair shops sell parts. also check links on this site for mail order.
J
Jun 12, 2008 | Whirlpool Refrigerators
Refrigerators Logo
237 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
