Question about Car Audio & Video
Jensen uv8035 brake bypass code
Ned the Jensen uv8035 brake bypass cod.
  • cmedina37 Jan 01, 2009
    but...a can find the code to get my dvd player region free...anyone can help?
  • garont1 Jan 01, 2009
    Just grounding the pink wire alone will not solve the problem. There is a safety that prevents a solid ground from unlocking the video. The circuitry needs to sense that the brake pedal is active by sensing the brake pedal has been pressed and depressed. Federal regulations prevent video to be watched by a driver so the video will only display when the circuitry senses the brake pedal is depressed. I needed video to entertain passengers in the rear of a limo. In order to "fake out" the system, I installed a momentary switch to brake the ground. In essence duplicating a brake pedal being depressed. This works always. It is a federal violation for manufacturers to provide the code to permanently disable the safety feature.
Just wire the pink wire to any ground-point of your car...
Posted on Jan 01, 2009
Whats the brake bypass code for jensen 9215bt
I have no idea what you are talking with the "code". It's a Jensen!!!Attach the parking brake wire to ground and watch a movie.
Feb 11, 2013 | Jensen Car Audio & Video
What is the parking/ emergency brake code to bypass the jensen uv10 dvd player
uv10 radio dvd player all you have to do find the wire on the back uv10 radio and ground it..( parking brake wire)
Jan 31, 2011 | Jensen Car Audio & Video
Can't find Jensen UV10 e-brake bypass code.
Ok what you gotta do is connect the pink e-brake wire with the black wire that is already connected to the radio as the grounding.
UV10 Works 100%!!!!
Greetings from Montenegro
Jan 28, 2010 | Jensen Car Audio & Video
How do i bypass the parking brake on my jensen vm8013hd
I just installed the vm8013hd and I simply grounded the pink parking brake wire to the chassis prior to connecting the power to the unit and it works just fine. No bypass box, switch, codes, etc. Good luck
Dec 28, 2009 | Jensen Car Audio & Video
Jensen uv8 bypass code didn't work
no the code should work . unless jensen put a stop to the code in the newer modles.
Jan 19, 2009 | Jensen VM9510 Car DVD Player
Need bypass code for Jensen VM9311TS
Here it is how brother,insert a dvd movie,next use the toggle switch sequence to get image,next press stop button twice on the remote,then press 1 2 6 4 on the remote,you will now see a menu that says
Regon Code
Brake Override(I know you are drooling by now)
Macrovision
Loader Version
Model Version
Using the right joystick on the unit,navigate to the options of your choice,click on them to toggle on,off or which region code you want.
This wht you want.
Region Code 1
Brake Override ON
Macrovision OFF
When you are done,click SYS SETUP on the main remote TWICE to save the settings and vingo.
Nov 22, 2008 | Jensen VM9510 Car DVD Player
Jensen vm9512hd e-brake bypass
the pink wire on the unit is for the E-brake.... ground it out somewhere and that will bypass the brake and fix the problem.
Nov 13, 2008 | Jensen VM9510 Car DVD Player
Jensen in dash dvd monitors
jensen double din dvd monitor it a uv8020 model to bypass the e brake or parking brake
Dec 19, 2007 | Jensen VM9510 Car DVD Player
Jensen vm9311
Need to know and bypass codes for the jensen 9311 but dont have the remote...
Oct 21, 2007 | Jensen VM9510 Car DVD Player
Car Audio & Video Logo
518 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
