Question about Transcend (589307) Media
Transcend 8 GB Pendrive showing write protected
Please help me. My new Transcend 8 GB pendrive is showing message ' Disk Write Protected' after it is 1.88 GB full. It does not show any such message when it is not full upto 1.88 GB.How m i to use the rest of the memory storage of the pendrive?? n also How a pendrive write protection can be removed???
  • 12 more comments
  • yamve475 Nov 29, 2008
    my pen drive is 124 mb but just 4kb is filled but write procted is coming everytime i try copy a file so how to solve
  • Anonymous Dec 04, 2008
    i too have the same probs
  • Anonymous Jan 15, 2009
    I have the same problem
  • Anonymous Jan 30, 2009
    tracend 8 gb pen drive showing write protected
  • Anonymous Feb 01, 2009
    same problem here, but in my case it doesn't write after 2.33 gb full
  • mohitarora24 Feb 01, 2009
    i am having the same problem, but in my case it doesn't write after 2.33 gb full
  • Anonymous Feb 03, 2009
    i have that problem
  • Anonymous Feb 06, 2009
    Transcend 8 GB Pendrive showing write protected problem
  • sujith270 Feb 06, 2009
    Transcend 8 GB Pendrive showing write protected problem,
  • diwakar_chdh Feb 06, 2009
    plz anybody give the right solution to remove write protection from the pen drive....
  • Anonymous Feb 11, 2009
    i am not able to use my 8gb pen drive .
    neither i am able to format it nor am i able to copy dat into. It's not working in both windows and linux.
    please help me out
  • syed aziz Mar 18, 2009
    i want to remove write protection frm my pendrive & formatted.
  • karthik88 Mar 28, 2009
    i am also having the same problem...........
    if anyone find the solution means
    please post it to me
    my e-mail-id is nkarthik.arul@gmail.com
  • aravind1_nmc Apr 29, 2009
    I can not perform any action in my pendrive and it says the disk is write protected
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
It worked for me and my friends....
Other pen drive users may visit there vendors site and download any fromat utility present there for your model.
Posted on May 16, 2009
  • jefftobin Dec 21, 2010
    I thank you so much - absolutely worked like a charm! Jeff Orlando, FL :-)
  • vishalkj Feb 25, 2011
    try the jet flash recovery tool it is helpfull for the write protect problem download the software from trancend website and then run the utility. select the option complete from the recovery screen. it works 100%. thanks
    vishal_katneshwarkar@rediffmail.com
Use following link to download recover jetflash from transcend site.
http://www.transcend.nl/support/dlcenter/Software/JetFlash%20Recovery%20Tool.zip
note that the data on the pen drive will be erased. so back it up before you run it.
Posted on Jan 30, 2010
  • Makara Jul 25, 2013
    thanks it useful, it solve my problem, ( note plz backup data before run it , due to it will delete all data in you flash dirve )
example: JFV30(all alphabets in Caps ) (DOWNLOAD JET FLASH RECOVERY TOOL)
Thats all...
Posted on Jul 24, 2009
  • amithmalli Apr 20, 2011
    Thank u. Its working sure 100%
  • girishdrag Jul 24, 2011
    I've downloaded the jetflash recovery tool but it is showning U don't 've enough privilege t run dis programme i've logged in as adm but even its not working pls help me out :'(
    Problem Solver:
  • 5 Answers
Posted on Feb 11, 2010
    Scholar:
  • 77 Answers
Download this small file:
http://www.kellys-korner-xp.com/regs_edits/writeenable.reg
Save the file on your desktop. Then double click the writeenable.reg file and click on Yes when Windows asks if yo u want to write to registry.
That;s it. Now you can try to create a new folder on your usb drive and it should be created. That means it's now normal.
HTH,
Regards,
Deboo
Posted on Feb 19, 2009
Ren this file.,.. and unloker sof use... if the problem not slove then you download hiren boot cd
Posted on Nov 07, 2008
How to remove write protection from pendrive
Posted on Jan 10, 2009
Frankly i should say that i have not seen any pen drive in my life which got repaired by using any stupid techniques on net ...so conclusion is go to the SERVICE CENTRE it may be in warranty or pay money to get it fixed...if you have imp data on it then go to data recovery proffesionals and get it done ,,,,,,,,,,,,,do not try to do it yourself ...u r making things more misrable
Posted on May 06, 2009
    New Friend:
  • 6 Answers
1) GO HERE
2) select your drive
3) use JetFlash Online format or download Autoformat
use AUTO FORMAT 2 optimize format it !!!!!!!!
Posted on Nov 12, 2012
It is showing but not opening
Posted on Oct 02, 2012
Hello dear, I am so problem, My transcend pen drive is write protected. Who can I solve it? Pls. give me easy solution.
My pen drive details : PUSB110J530 8GB Transcend Retractable USB 2.0 JetFlash 530 (White Body W/ Blue Slider)
Posted on Jun 29, 2012
Friend this the best solution ever 100% working ...
After 2 days of effort atlast i found this ..
All types of transcend could be solved ..First while formatting i shows an error then it gives a clear formatting...
http://in.transcend-info.com/support/DlCenter/DlLogin.asp?link='Support'DLCenter'Software'OnLineRecovery.zip&ufrom=ORT_Software&Func1No=3&Func2No=205
Posted on Jun 10, 2012
Sir,All comment now check but don't my pendrive problem.My pendrive problem is don't formatted And all time say drive write protected
Posted on Sep 27, 2011
Deboogeek thnks bro
Posted on Jul 19, 2011
  • kchanduak Jul 19, 2011
    its working
Sir, my 8 gb pen drive in not protection facility and my pen drive are not play in my dvd player. so please solve this my problem. sir and i request you please my protection problem are solve in password system.
Thank you.
Posted on Aug 12, 2009
3 Suggested Answers
softwareguru
  • 78 Answers
SOURCE: displaying write protected while loading and deleting files
Your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes (It is antimalware software)and scan your whole computer as well as your pendrive when you scaning finish remove all threats
IF the above method is not work
Try to format in other operating system like windows vista or in windows 7 because in vista and 7 you can force format your pendrive
Posted on Jan 03, 2010
jeltey
  • 44 Answers
SOURCE: Please help me. My new
Have you tried to format it?
Posted on Dec 12, 2008
Transcend pendrive problem
Your USB connector have a problem. U try other computer or other USB connector.
Jul 13, 2010 | Toshiba Computers & Internet
How to remove write protected in my 8 gb transcend
hi........please check that if there is switch in your pendrive..if present turn it other side..if not than follow this steps... 1. download a software from here http://www.softpedia.com/get/System/Hard-Disk-Utils/HDD-Low-Level-Format-Tool.shtml
2.now fromat your pendrive by this software and than scan it for virus ...
hope this will solve your problem
May 25, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My Pendrive "Write protected"
your pendrive is infected with Autorun.inf virus
to remove this virus install malwarebytes and scan your whole system as well as your pendrive
If the above method is not work
try to format in other operating system like vista or in 7
but not in xp because in vista and 7 you can force format your pendrive..
Oct 16, 2009 | iLO (2 GB) MP3 Player
Pendrive Transcend 8GB JFV10 error message "Disk is Write Protected"
Thats all...
May 31, 2009 | Transcend (589307) Media
Write protected
May 23, 2009 | iLO (2 GB) MP3 Player
Pendrive not work
Jan 30, 2009 | Transcend 32GB ExpressCard SSD, MLC 32 GB...
Displaying write protected while loading and deleting files
Dec 11, 2008 | Transcend (589307) Media
Pendrive write protection removing
Hey, the transcend pen drives usually have a small switch on the side of it, ie to turn the write protect on and off, usually a small lock symbol on it, the problem with unreadable files names etc, could be a corrupt partition, i would suggest formatting the drive as long as you aint got any important information on it,
All the best
John
Jul 27, 2008 | Computers & Internet
Transcend (589307) Media Logo
19,373 people viewed this question
Top Transcend Electronics - Others Experts
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
