Question about Yamaha HTR-6130 Receiver
No video when conected to fron av jacks
When conected to front av jacks for suround sound during game play there is only sound
    Scholar:
  • 107 Answers
Try different AV input at the rear or try different source such as DVD player at front where you connector game use different AV cable
Sometime the AV jack input poor contact because for long time you not use it or the electronic switching video inside your receiver is faulty
Cheers
Posted on Dec 03, 2008
HOW TO SET UP REMOT TO VIDEO CHANEL,I CAN,T CHAN THE CHANEL TO THE VIDEO CHANEL
Hello
Audio and Video Front Inputs are available
for a quick connection of a VCR, to playback
video from a camera or attach a gaming
device. Use the AV button on the remote control
to tune these inputs.
1 Connect the video (yellow) cable
from the Video output on the Camera
(or accessory device) to the Video (yellow)
Input located on the FRONT of
the TV.
2 For Stereo Devices: Connect the audio
cable (red and white) from the Audio
Left and Right Outputs on the Camera
to a Stereo to Mono adapter. Then plug
the single end of the adapter to the
Audio In (white) jack on the FRONT
of the television.
For Mono Devices: Connect one end
of the audio cable from the Audio Out
jack on the device to the Audio In
(white) jack on the FRONT of the television
3 Turn the TV and the accessory device
ON.
4 Press the AV button on the remote
control to tune the TV to the side input
jacks. "Front" will appear on the TV
screen.
5 Press the PLAY  button on the
accessory device to view playback, or
to access the accessory device (camera,
gaming unit, etc.).
Repeatedly pressing the AV button on the
remote control will toggle the picture source
from the current channel, or Front input
jacks.
Note: The Audio/Video cables needed for
this connection are not supplied with your
TV. Please contact your dealer or Philips at
800-531-0039 for information about purchasing
the needed cables
OK
Jan 06, 2011 | Philips 20PT633R 20" TV
Jacks show in black and white
You need component output on your Wi. You should have 2 AV jacks on your TV. I am guessing you have a red,white ,and yellow for your WI? That is made to hook up in the AV and NOT the component.If you have red,green,and blue? You might just have a bad cable,that is why it is in B&W. Or hook your Wi to your suround sound AV input if it has one. It is hard to give you all the answers with the info you provided.
But this is a educated guess. hope it helps. Todd
P.S. Be carefull with your controlers, SEVERAL accidents of them hitting the TV and breaking the screen. Play nice. :)
Jan 15, 2010 | Samsung UN55B6000 54.6 in. LCD HDTV
I've bought a panasonic sound surround dvd player and want to link it to a sky+ box and tv so that sky will play in sound surround. Can you advise on the wiring configuration please?
look at the back of your tv does it have a audio out RCA jack?
it should do plug in the surround sound into that using RCA cables
if your tv does not have audio out RCA jack then you can
get a adapter which makes scart connectors turn into RCA jacks get that off ebay
plug the yellow line to the tv and connect the red and white to suround sound
but with this there are a few problems sound will only come out when surround sound is turned on and skys sound will never play out the tv
if you switch to a PS3 or something it will not play suround sound
yuo best option is the RCA plugs in the back of the tv
because you have not written the model number of the tv or the suround sound i cant help any further
Jan 12, 2010 | Panasonic Home Theater System System
Can't get surround sound while playing the PS3. The surround works while watching cable
your suround sound system has been wired up so only cable plays throgh speakers
does your tv have a audio out RCA jack?
if so then connect the home theater to that
i cant help anymore because i dont know the suround sound model number ot what tv
Jan 11, 2010 | Audio Players & Recorders
No audio through Vista
360 sound will not work through the line in on a comp you need av sound jack which most computers sound cards do not have therefore you need to buy a sound system that has av jack capability
Aug 21, 2009 | Microsoft Xbox 360 Console
WHile playing my game the sceen turns black but still has sound..
check your av conection i had same problem and it was just the plug wasn't pushed all the way in but looked like it was. check ps and tv
May 15, 2009 | Sony PlayStation 2 (PS2) Console
Has sound but no video picture for game playing
try changing the av to another channel or if you have access to a front panel or side panel on the tv set, try using this for your av leads 'red' 'yellow' and 'white'. Also check that the av lead is correctly inserted into the back of the wii
Oct 25, 2008 | Nintendo Wii Console
Xbox 360 flickers across screen
it is your av cable however the components in the cable get a small static boost when u are using your controller so it becomes an intermittent fault ie;....when in game vidios or watching dvds, u rarely use the controller so u dont see the flickering and u only see it when in game play because u are in constant contact with the controlls and the components inside the av cable recieve a small static boost causing the interference.
Oct 07, 2008 | Microsoft Xbox 360 Console
Can't figure out how to get suround sound on tv with new home entertainmain center we do have suround sound on dvd and tuner conection just not able to conect to our panisonic tv
Look at the TV specification - does it include a surround sound receiver and amplifiers? The tuner may not be 5:1 capable - thus there is no surround on off air broadcasts. If there is then you may need to select the correct menu and turn it on - THIS WILL INVOLVE READING THE MANUAL OR USER GUIDES.
Mar 16, 2008 | Audio Players & Recorders
Playstation 2 with no audio.
Hi, Im a game console repairer by trade, Had a look at the parts numbers lsit for you but none match to the AV jack your after. Your best solution would be to source another dead 50001 with another problem such as a laser problem or similar from somewhere like Ebay and unsolder that AV jack or just swap out the motherboard completely, Sony have never been up to speed in supplying parts so used parts are really your only option.
Sep 19, 2007 | Sony PlayStation 2 (PS2) Console
Yamaha HTR-6130 Receiver Logo
155 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
