Clear monter cable, needs to know witch is postive and negative.
  • 1,512 Answers
Hi gaitan1
There are a few ways that cable can have positive and negative identified. In the case of monster cable, the first thing to look for is
  1. a single silver strand of wire in one bunch of many copper strands. OR
  2. writing along one side of the cable
  3. a fine ridge along one side
  4. a small white stripe every so often on one side
It is not important which one you make positive, but VERY important to get the speakers in phase. If none of these suggestions help you, I am happy to still assist you. :)
regards
robotek
Posted on Nov 07, 2008
Battery does not hold charge battery is good
How do you know the battery is good? Have you had a load test performed on the battery? Just because a battery reads 12 volts when using a volt meter doesn't tell you anything. You need to have the battery load tested. If it tests good, charge the battery to full charge. Put it in the bike and connect the negative battery cable. Using a good Digital Volt Ohm Meter that will measure amps up to ten amps. Set the meter up to measure AMPS. and put it in it's highest scale. Put the postive lead of the meter to the postive battery post. Put the negative meter lead to the postive battery cable that is disconnected from the battery. If you have a current drain, lower the scale range until you get a stead readable value. Then, disconnect the voltage regulator from the battery and read the current drain. Since you bike is ECM controlled, it will draw a little current but not over one amp.
Good luck
Steve
Jul 12, 2011 | Harley Davidson FLHR-FLHRI Road king...
I took out old battery,now i am having problem knowing witch side is positive and wich is negative on cables
RED is positive and BLACK is negative if both cables are black then trace wires the gound or negative will go back to frame of bike somwhere.And the red or positive will go to starter soliniond and be inlined fused.
Mar 13, 2011 | 2004 Honda VTX 1300
How do you reset computer to remove engine light?
just disconnect the negative battery cable for 5 minutes.
Mar 15, 2010 | 1995 Nissan Maxima
Battery cables for 1994 for explorer
you can purchase them from an online auto parts store or the dealer. your price online will be around 70.00 for both cables. Good Luck!
Sep 17, 2009 | 1991 Ford Explorer
FOR MARANTZ SR5000 RECEIVER
for the RCA cables there color coated RED and WHITE, for example ur hooking up a cdplayer 2 ur unit, cd player output, Red = Right, White = left
the cables go to the cd input on the back of the unit, same as for selections DVD,AUX,an so on some mite have a yellow witch would be Video
and for the speakers, some are black an red, some are clear an has a white strip that would be the negitive wire, red is postive black is negitive those are the color codes for the terminal on the speaker outputs, hope thats what ur asking
hope it helps
Feb 12, 2009 | Marantz SR-5000
Jump starting
Can you send me a Pic of the Battery???? E-Mail or Cell????
Jan 26, 2009 | 2004 Chevrolet Venture Passanger
Jump starting a chevy monte carlo 1997
negative any metal part of engine wiggle the cable to have good contact that it cheers pierre
Jun 24, 2008 | 1997 Chevrolet Monte Carlo
19 people viewed this question
 Grubhead
Grubhead
