I have a Palm m100 Series and my newly acquired Microsoft Vista has only USB ports for accepting the HotSync Cradle that came with it. Local vendors advised my contacting you for downloading the means/facility for accomplishing this. Your input for solving the problem would be appreciated. Sincerely, Ron Warnock
  • Anonymous May 08, 2009
    The hp pavilion has no port for the palm m100 hot cable. wwhat can i use.
Thanks for your responce.
Contacting the guru answering all problems I have with my PC,..........he tells me Palm does not support 64-bit editions of Windo. Vista and based on that, suspect I had better forget about it. (I still have an XP I can use though.)
Regardless, thanks again!.
Ron Warnock
Posted on Nov 07, 2008
IQ3600
Is it connected to the pc via usb? Try other usb port like the usb port on the back of your computer if your are using a desktop computer.
Aug 04, 2008 | Garmin iQue 3600 GPS Receiver
Is there a way to use ique 3600 with windows 7? ique does not syc.
I am using Windows 7 Ultimate 64 and the iQue did not work. There is no USB driver and as far as I know there isn't going to be one. However, I did get it working by installing Windows XP mode and the Windows Virtual Machine on my XP system. You need to check if your computer can run XP mode and there are Microsoft tools to do that. After you get XP mode installed and running, there will be a virtual XP window on your desktop. Plug the iQue in its cradle and plug it in to the USB port. Use your iQue setup CD to install the Palm desktop in XP as you normally would. At some point, you have to tell XP to attach your iQue to the USB port. Near the XP title bar, there is a USB pull-down menu. Use this to attach the device. It will ask for a driver. Just say to use the Garmin-supplied driver. Wait until this finishes successfully. Before trying a sync, open the Palm desktop and go to Hotsync/custom and change everything you can to "handheld overwrites desktop" and save this. Push the hotsync button on the cradle. If it doesn't connect, go to the USB pull-down and click attach. It should work!
Dec 08, 2009 | Garmin iQue 3600 GPS Receiver
Garmin IQUE 3600 unable to HotSync, Windows XP
I think I have solved this problem.
Try this:
Go to my computer, right click -> Properties -> Hardware -> Device Manager.
Locate your IQUE 3600, or Palm.
Now, if your palm has a Yellow Exclamation mark on it, that means that your computer is not recognizing the Palm. Select
Driver details. Re-install the driver off the "Setup CD" that came with your IQUE 3600.
This worked for me.
Sep 21, 2007 | Garmin iQue 3600 GPS Receiver
Considerations for Windows 2000 - WorkPad c500/505
The WorkPad c500 and c505 can be used only with PCs running Microsoft Windows 98 or Microsoft Windows 2000 operating systems. NOTE: Microsoft Windows 95 and Microsoft NT 4.0, or serial connectivity, require a serial HotSync cradle or cable, available separately from Palm, Inc. The WorkPad HotSync utility will not sync via IR when the host PC is running Windows 2000.
Sep 14, 2005 | IBM WorkPad c505
Sep 14, 2005 | IBM WorkPad c500
Connection is lost (6410)
First open the HotSync custom menu, start changing conduits to do nothing. Work your way down the list until you end up with a complete HotSync. If you still have the 6410 error, unplug the USB adapter, replug and try your HotSync again. The USB adapter may be the week link in this equation.
Sep 12, 2005 | Palm IIIe Special Edition Handheld
USB Connection
Do you have the USB option turned on in the HotSync Manager? Have you checked the item called Local USB in the HotSync Manager menu. This check mark ensures that HotSync Manager is listening to the USB ports on your PC for a HotSync request.
Sep 12, 2005 | Palm m130 Handheld
Error message using IrComm port
Hi, Right click on hotsync manager at the bottom right corner of the pc , make sure only local serial and ir is having a check mark , if anything else has check mark , just go to that and do a left click , it will get unchecked . On the handheld tap on home , on the main page u will see hotsync icon , tap on that , on the hotsync page make sure via ir , and not cradle or cable , then at the top u will see hotsync in words , tap on that , in the drop down u will see lan sync pref, tap on that and make sure lan sync is highlighted , and not local hot sync , since local hotsync is usefull only when u perform cradle or cable hot sync using usb , then click on ok , try a hotsync . If this doesnt help and again u get the same error , do a soft reset on the handheld and on the pc , go into hotsync manager , click on setup , choose local , change the com port to a different port and reduce the speed to 9600 , click on ok restart the pc and again perform a hotsync . The error u got was coz of this , on ur pc a ir port is not been assigned .. Try this it should work .. Regards
Sep 11, 2005 | Palm Tungsten T3 Handheld
Synch problem after installation
If your cradle is connected to a serial port, you will need to ensure that HotSync Manager is configured to use Serial Ports. To do this, follow these steps: 1. Click the HotSync Manager icon in the Windows system tray. 2. If there is a check mark next to the 'Local Serial' menu item, then you are already configured. 3. If there is not a check mark, click the 'Local Serial' option. For more information, refer to the handbook that came with your handheld. If you did not uninstall your previous version of Palm Desktop, the configuration will be done automatically.
Sep 07, 2005 | Palm Tungsten T5 - Multilingual Handheld
Computers & Internet Logo
57 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
