Question about ViewSonic A90f+ 19" CRT Monitor
My monitor crt a90f+ viewsonic blurry
My monitor show as blurry those text and not the sharp edge as you could read clearly So is there any way i can sharpness the text with my view? I have hard time to read its strain my eyes. I have a laptop and other computer with different brand name of monitor all are read ok.. espescially this one. Thanks!
  • Jodi Saylor Oct 16, 2006
    HI!!
    thank for try to help me this out yes i am off ultrabrite.. and when i use the window setting at 1024 by 768 with 16 bit anbd it look little better but not able to stay and read.. so i use 1280 by 1024 which i prefer and or the higher and it show bad and worse.. i cant think of and i also go to appearance and go to effect and checked the mark on use the floow method to smooth edges of screen fonts i put clear type it show better than standard but not better as sharp as i want..
  • Earl Roy Aug 05, 2008
    Yes, I am having the same problem. I too have the same settings as you do, and the right and left edge of my screen makes text hard reading... Thanks for any help.
Ensure that the monitor's UltraBrite mode is off, via the "UltraBrite Mode" button on the front panel. UltraBrite is great for games and movies, but it tends to fuzz plain text ever so slightly.
Posted on Oct 16, 2006
You may want to try a few things before you reinstall your video drivers... Go in to the display control panel, and look at the advanced tab. (Or it may be "settings"... no OS specified) you're looking for "Hardware acceleration" When you find it, reduce it a notch until either the problem goes away or you run out of notches.
If you run out of notches, you may have to reinstall your video drivers.
Posted on Sep 29, 2009
  • revlonbabe Jan 20, 2011
    My monitor was blurry for no reason and nothing on any forum seemed to work until I read this somewhere and voila it worked!!!
    I just fixed mine (Dell D1025TM). I went to the menu directly on monitor(which was all
    gibberish), selected the lower-right box (since that's the only one I could
    use), hit the select/enter type button (in between the brightness/contrast
    buttons). Then I think I hit the left contrast control button (just on the
    right side of the enter/select button). That let me access the menus
    again...
    Then I held the reset button for a few seconds and the monitor flashed a few
    times, then the menu was in perfect again.
    So if anyone still has this problem, the above steps will work!
I have a sony trinitron 36in tv, the screen works fine, colours are all great, no flickering or random shapes at all, its just a little blurry around edges, especially small text, its very blurry and...
it is very easy you just need a very small straight edge screwdriver
you should try to adjust sharpness setting with on screen adjustment first
if tv is too old tube might be going "soft" and sharp focus might not be able to be fully achieved anymore
good luck
Mar 13, 2011 | Sony FD Trinitron WEGA KV-36HS510 36" TV
When set on 1280 x 1024 pixels everything looks great but too small for me to read. When I change the setting to 1280 x 800 or lower, words are blurry and taskbar disappears. Can you help?
Which version of Windows are you running? Slightly different between versions, but basically *somewhere* in Control Panel there will be something shown along the lines of Display Options, and somewhere in there will be an option to change Font DPI. (I think XP has a selection of either 80DPI or 120DPI, default is at 80 - Text is much larger and easier to read at 120)
In Windows 7 (and probably Vista) the path is- Start - Control Panel - Appearance and Personalization - Display - "Make text and other items larger or smaller"
Jan 11, 2011 | ViewSonic VG700b 17" LCD Monitor
A90f dark dark screen
Use brighten controls on monitor to lighten
Dec 22, 2009 | ViewSonic A90f+ 19" CRT Monitor
About text sharpness
The monitor shouldn't be changing the settings itself unless you changed it. Try changing the brightness and contrast. Otherwise, it might be a video card issue.
Nov 30, 2009 | Samsung SyncMaster 551 15" CRT Monitor
Hello, i have an issue where my viewsonic A90F 19" crt moniter's picture dims darker at random...then returns back at random as well. Any idea what it might be? I recommend: | Change Remove Formatting Bold...
If you still have the monitor, check the signal cable -- wiggle it a bit at the PC end and at the monitor end, while watching the image on the monitor. Any change? If you have issues when moving the cable at the PC end, you may want to try shutting down the PC and disconnecting the monitor. Then clean the pins on the monitor's connector with 91%+ isopropyl alcohol and a cotton swab (make sure no cotton is left behind). let dry and try again.
If none of this make any difference, wait for the monitor to go dim. Then, gently smack it on all sides. If the image clears up or changes, there is likely an internal bad connection. Do not open the monitor unless you are familiar with all safety precautions involved.
I have the same monitor and I was having a similar problem. Turned out, there was a cracked solder joint on the signal board at the back of the CRT plus several more questionable ones.
Nov 08, 2009 | ViewSonic A90f (Metallic Black) 19 in.CRT...
Blurry monitor
The monitor is going bad. It can be serviced but the cost to fix or adjust is not worth it. You may be able to adjust it yourself but A) you need to know what you are doing and B) Accept the risk of completly ruining the monitor or even worse electricuting yourself by accidentialy touching one of the high voltage circuits. A carry in service repair shop will charge about $125.00 to $200.00 to fix it. A new LCD flatscreen is a much better choice it will cost the same or less and will pay you back in time just from the energy savings. My condolences.
Oct 29, 2009 | ViewSonic G90fb 19" CRT Monitor
Viewsonic Monitor and the text is not black but grey.
try to log in safe mode and reinstall the display adaptors or uninstall them and reboot
Feb 01, 2009 | ViewSonic G90fb 19" CRT Monitor
White colour is displaying as yellow
Your monitor is missing blue drive. Most likely a component failure on the CRT board. Bad color ICs, bad solder connections or defective capacitors can cause the problem.
Aug 25, 2006 | ViewSonic E50C 15" CRT Monitor
Dimension of image change when displaying clear or dark image
Same problem Picked up this monitor about half a year ago, a Viewsonic A91f+, and have been having some issues for a while now concerning what appears to be shifting in the monitor image, but that is about the best I can describe it as. It is most noticable when a large dark area meets a light area, like text or window edges. This "shifting" only occurs on the right side of objects and seems to show most often after I switch resolutions more than a few times, usualy due to gaming. Ive also noticed it happening from running random programs that dont require resolution changing/flickers but this happens FAR less often. -photograph of the effect- As you can see, its pretty subtle on a darker background, but Ive had no luck carturing it on a light one. Anyone have any idea as to what is occuring on this monitor and how it could possibly be fixed? Possibly an issue with magnets? For a while, I did have a small headset hanging off the the monitor on the side that the images "shift" towards, but even taking those off and away havent fixed it. Currently the only fix I have found for this is to shut my monitor off for 5-30 minutes, depending on how bad the "shifting" is when I find a time break long enough to fix it.
Jan 12, 2006 | ViewSonic G790 19" CRT Monitor
ViewSonic A90f+ 19" CRT Monitor Logo
851 people viewed this question
Top ViewSonic Computers & Internet Experts
Steve Allison
Steve Allison
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
