Question about Philips DVP642 DVD Player
Power light flashing constantly.. no response
  • Anonymous Nov 18, 2008
    Power light flashes and there is no response to buttons. Power light goes steadily red in between episodes, but when I push any of the buttons, it starts flashing again.
  • Anonymous Nov 26, 2008
    DVD is stuck and the red power light flashes constantly. Does not respond to any buttons and tried disconnecting, restarting.
  • 88 Answers
1.check&replce flash ram.IC
2.replce mpeg pcb with new one.
Posted on Nov 14, 2008
Why does dishwasher rinse light keeps flashing and sounds like its draining. ?cant put another programme on
the flashing rinse light is a error code but i need a model number to know exactly what it means, constant draining with an error normally indicates an issue with water either its filling up to much and leaking into the base or it has a leak from somewhere in the dishwasher i.e. a hole in hose or a leaking seal, constant draining is a default response to a leak for all dishwashers often continuing draining even when the door is opened
Oct 08, 2014 | Dishwashers
After battery replacement, upon power up, constant beep with fault light full on and battery light flashing. On some trys, the bypass light will also light up. No response from buttons. Unit is...
Try and push and hold the on button for about 3 sec. This will start a manual battery test. If only three of the five battery led illuminate allow the ups to recharge the batteries for 24 hours. Battery light flashing means internal battery source not available. Check battery connection, completely power down and reboot UPS
Sep 06, 2011 | Liebert UPStation GXT1000RT...
Lite way rascal 3 red light flashes constantly to indicate sleep mode.I have switched on and off but there is no response.Micro switch ok.Happened before and switching off cured it.also leak on axle which...
According with the manual...
LED Flashes 7 times means a Throttle fault. Engager levers must be in neutral (centered) position before venicle is turned on. Paddle fault and speed pot fault. Switch vehicle off center levers and switch back on.
I suggest contact the technical service supoort to solve it.
Hope helps.
Mar 20, 2011 | Electric Mobility Golden Liteway Scooter...
No AC power
Why does the AC indicator light constantly flash and I have no AC power on my Black and Decker Electormate 400
May 03, 2009 | Black & Decker 400 Watt Electromate With...
Flashing Green and Red lights
i querried from epson site it says the ink is low, repalce cartridge
Step 1 WHICH MODEL ARE YOU USING? Stylus C44UX Step 2 What were you doing when the problem occurred? Turning on the printer Step 3 What happened when you were turning on your printer? An error appeared on its control panel Step 4 What is the power light's current state? Flashing Step 5 What is the error light's current state? Flashing Step 6 WHAT IS THE PRINTER'S STATUS? Ink low
Oct 28, 2008 | Epson Stylus C44UX InkJet Printer
Prainter failed without warning,will not respond
Hi Tcov,
Please click on the web link given below and perform the steps as provided in the web page.
Please read the documentation provided in the web page carefully to fix the issue.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00045587&cc=us&lc=en&dlc=en&product=79499
Have a great day!
Feb 02, 2008 | HP PSC 2210 All-In-One InkJet Printer
Philips DVP642 DVD Player Logo
71 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
