Question about Toshiba e-STUDIO 16 Printer
Phone jack i was trying to network my toshiba e-studio 16 to my computers for fax/scanning capabilities but i found there wasn't any phone jack but a hole covered with white plastic. pls help
There are optional fax and network cards for the estudio try ebay
Posted on Jan 06, 2009
What is error c440 of toshiba photocopier
Toshiba e-studio Error code c440 is just problem with Fuser Unit after warm up time . 200L/ 202L/ 230/ 232/ 280/ 282/ 283/ 233
PROBLEM:
Fuser unit problem,
SOLUTION:
Try to reset it:
1. Hold down "0" and "8" keys while turn on the power.
2. Enter 400 press Start.
3. Enter 0 press Set or Enter.
Hope this helps
you can find more info at this link
Apr 28, 2014 | Toshiba E-studio 352 Digital...
How to configure scaner of my toshiba 353 ,to scan on my pc
In order to allow the e-353 to scan to eMail, and PC, you must have an enabler (Scan, or Scan and Print), either on will allow you utilize the scanning function through network(PC and copier must be in the same subset).
Or you can use the USB connection, just install the unity from the CD, or download it from Toshiba.com
http://business.toshiba.com/support/downloads.jsp?site=usa#Utilities
Choose the e-bridge full installer, burn the ISO image to a CD.
Nov 01, 2013 | Toshiba E-studio 353 Digital...
Reset factory default for toshiba studio 355
Please specify what do you want to reset, there tons of defaults can be reset,
Oct 23, 2013 | Toshiba E-studio 355 Digital...
Using a toshiba e-studio 190f fax machine, i can not recieve a fax or send a fax. I call the line and it just rings, can youhelp
Make sure you have the phone line plugged in, also make sure it's plugged into the LINE port on the machine. (Ext. is for a extension, i.e. secondary phone for manual dialing)
Also check that the wall jack is functional too, easiest way to do this is hook up a regular phone to the jack and if you get a dial tone you know it's okay.
If the wall jack is getting a dial tone and the line is plugged into the LINE port you may have a bad phone cable, try a different one.
May 31, 2011 | Toshiba Office Equipment & Supplies
Cant recieve fax on Toshiba estudio 3511
Hello sir; For the fax line only have two single lines working in the cable one is in-coming ,another one is out-going, therefore if you can send fax and can not receive, that's means your phone cable or phone jack on the wall have problem, my sugestion, replace phone cable first, if still have problem check the phone jack on the wall.
Jan 23, 2009 | Toshiba E-Studio 3511 Color Copier
Network printing issues - Toshiba e-studio 16s
try this:
start, printers and faxes
right click on the print driver , go down to properties click
click on ports
click configure port
click lpr in protocol
Lpr queue name PRINT
LPR byte counting enable
SNMP enabled
Try this and make sure your ip address is correct
Jan 21, 2008 | Toshiba e-STUDIO 16 Printer
Toshiba e-STUDIO 16 Printer Logo
128 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
