Question about Sony KV-32FX20U 32" TV
Problems with the picture on my tv. Pink lines across its screen
All of a sudden, my TV started showing pink lines across the screen about 1cm in diameter. All channels work fine, I have tried changing the scart leads but no joy. Can you help ??? Thanks
  • 2 more comments
  • TONY COLLIER Oct 17, 2006
    The orientation of the lines are horizontal, and they are constant on every channel (even satelite). Thanks
  • ClairesMom Jan 22, 2008
    the pink lines start about one year from purchase. they are horizontal and static on every channel whether my cable is connected or not I tried. modifying the picture using the menu function and no difference. Are there any other ways to adjust the picture?
  • Izap2 Mar 10, 2008
    Same problem except the static horizontal lines are green.
    Thanks
  • JAMESBALDINI Mar 18, 2008
    I AM GETTING WHITE LINES ACROSS THE SCREEN TOP 4 OR 5 INCHES TOP OF PICTURE
Smack the back of your TV, seriously, it just worked for me after none of the other methods on here worked
Posted on Mar 20, 2011
Take the back of the television and atthr back of the screen there is a sucker that sits on the back of t give it a tap and the pink goes away
Posted on May 26, 2007
    Scholar:
  • 68 Answers
You do not say the orientation of the lines and if they are the same on all channels. If they are angled and/or moving then it is usually interference and can be any colour. If the lines are always present they are being picked up in the circuits inside the TV, and not from the aerial or scart. The source of the interference could be from a faulty circuit in the television (continuous) or a nearby aerial mast (usually intermittant). If it is only the satelite reciever giving the probpem the dish angle needs correcting as it may be picking up from a nearby satelite on the same frequency.
Posted on Oct 16, 2006
My lg tv shows pink instead of yellow can u solve this problem?
Posted on Apr 02, 2010
Tell mi how to fixed the white lines on my tv screen
Posted on Feb 09, 2008
4 Suggested Answers
SOURCE: Fushia Pink color on screen
It depends how many times the LED blinks. Tell me how many and I can read the description on the manual.
Posted on Sep 11, 2007
techman
  • 3130 Answers
SOURCE: sony kp-46s25
It sounds like you are going to need to have the convergence IC's replaced. Not really a hard job, but the job requires the proper tools, soldering skills, and a service manual to get the proper part numbers and to perform convergence alighnment in the service menu after the IC's are replaced. Good Luck
Posted on Mar 28, 2007
jerryg50
  • 1690 Answers
SOURCE: Pink Screen
Most likely the green electron-gun in the CRT is failing.
Jerry G.
Posted on Jul 22, 2008
The color on my Samsung Slim Fit TV suddenly blipped to pink and blue. When I turn it off and back on, it comes on with a green line across the middle of the screen. What's up?
This line shows that there is failure of vertical output stage,may be due to high supply from internal power supply of TV set,check the voltage of the vertical output stage,and after rectification of supply problem replace vertical output IC to get this problem solved.
Feb 08, 2011 | Samsung SlimFit TX-T2782 HDTV
I have pink and green wavy lines. Most pronounced at the bottom of the screen.
Ur tv have a problems known as a convergence problems,it dead.The tv have colors lines R,G,B mis alignments anywhere in the pictures,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 24, 2010 | Panasonic PT-47WX49 47" Rear Projection...
The picture all of a sudden became blurred , color convergence is not aligned and there is a pink wave at the top left of the screen and a green wave at the bottom of the screen. When the color is adjusted...
Tv have convergence problems,it dead.Colors lines R,G,B don't aligned.The tv convergence board is dead.The 2 STK convergence ICS and some or all it resistors are dead,these parts must be replaced to solved the tv pictures covergence problems.The shop,will cost u $300-350 for parts and labors.
Sep 18, 2010 | Sony KP-43HT20 43" Rear Projection...
Pink line across top of sony wega 46" tv
after changing the lamp, I still had the same problem as you. I contacted sony and they offered me a brand new 40 inch bravia flat screen tv replacement...at no cost! If I chose a 46" or 55" there would be a charge between $325
Dec 24, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Samsung 46" pink dots
I had a problem with the TV going on and off several times before "warming up" and then having pink dots. I would have to reboot to get rid of the dots. I called 1-800-SAMSUNG and reported that I had problems with the capacitors. That is what was causing the problems - cheap capacitors and Samsung is aware that this has caused many TV's to malfunction. My set was not under warranty but Samsung sent a technician across two state lines to fix my TV. As long as the problem is the capacitors Samsung will cover this service call 100%. My TV is fine now. BTW - capacitors which are sold in Radio Shack are not expensive. Why Samsung chose to put the cheapest Korean capacitors in their expensive TVs is a mystery.
So if your TV need warming up and has pink dots on the screen - call 1-800 -SAMSUNG and tell them your capacitors are malfunctioning.
Nov 27, 2009 | Samsung LN-T4665F 46 in. LCD Television
Arched pink lines across screen. Now green and pink double stacked wording.
Projection sets have two very common problems.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Oct 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Concave Images with pink and green colors
you can get it your tv fix the problem is in the IF amp and video circuit.a convergence will also be neeeded.the tv is old but can give you some more life call a tech they will be your tv doc.
Apr 03, 2007 | Sony KP-57HW40 57" Rear Projection...
Emerson TV EWT2721 27"
Did the TV get pink with the wavy lines all at once, or did it start out gradual? If all of a sudden, then a defective part on the CRT control board or the picture tube itself could be going bad along with some components in the video section of the set. Probably not a cheap and easy fix I'm afraid.
Jan 01, 2007 | Emerson EWF2703 27" TV
Televison & Video Logo
4,527 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
