Question about Casio Exilim EX-Z750 Digital Camera
Problem with taking picture with SD card
My camera works fine with internal memory and for picture reviewing.
When I'm trying to take picture on SD card first few photos are OK, than blwck screen and black photos. Green battery icon in lower left corner.
With newly charged battery I can take up to 10 pictures, after turning off and then on - 3-4 max.
I tried:
1.to reset camera settings
2.3 different SD cards
3.2 batteries
4.TO format SD card on PC
5.To format SD card in camera
6.TO clean contacts with alcohol.
All without any success.
Any other suggestions/recommendations.
THanks
  • ppsg2001 Dec 12, 2008
    How do I transfer pictures from EX-Z75 camera memory to SD card?
  • 374 Answers
The only thing I can recommend is using the brands of memory cards that Casio recommends. They are Panasonic, San Disc, Toshiba. Make sure the card is formatted with the camera before use.
Posted on Dec 01, 2008
When I try to take a picture, it says memory full. But, when I try to look at the memory it says no file. I tried using the disk, installing software, formatting it.. Nothing works. The SD memory card is...
Format the SD card make sure the camera is set to place the new files on the SD card and not go to the internal memory. What I fully expect is the camera has defaulted to using the internal memory which is now full of files/pictures and needs to be set back to SD card. To get the pictures from the internal memory to your computer you need to load the pictures one by one from the internal memory to the SD card. Then take them from the SD card ether to a card reader to the computer or download them from the camera to the computer.
Dec 25, 2010 | Vivitar ViviCam 8025 Digital Camera
Deleted all pictures off of the disk by mistake- afterwards camera said, internal memory full-bought new sd card, and it still says that --what's wrong?
"Internal Memory" refers to the camera's built-in memory, not the sd card. You didn't specify the make or model for your camera, so this response has to be general. Use your camera's menu to select memory location, and then select External or memory card. That will direct all camera activity to the card. You might also select review, then internal memory to review and/or delete the pics that are on the internal memory.
If this general guidance doesn't work for you, please post the make and model of your camera and we'll try again.
Bill B
Nov 01, 2010 | Cameras
Kodak easyshare m360 says memory full after 3 photos i just bought the camera, what i shell do < shell i buy memory card or usb for it ?
You need to switch the camera over to saving pictures directly onto the SD card.
  • Menu
  • Cam settings
  • Chose AUTO or SD card option
  • Press OK to SD card
Note: If the SD card isn't in the camera or is unreadable the camera will automatically go back to saving you taken pictures on the internal memory.
If you experience problems:
The lever on your SD card might be turned the wrong way so the SD card is reading protective.
Please turn the lever and try again.
The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 2 Gigabyte and SDHC up to 8 Gigabyte
The SD card might not be faulty, try another card, since the camera could give you a message like the one you're experiencing.
Try with a different SD card that is supported by the camera.
Once you have set the settings to save onto the SD card directly you might like to transferre your existing pictures from the internal memory onto the SD card:
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  • On the camera, press Review and then Menu.
  • Select Image Storage.
  • Change to Internal Memory.
  • In the menu listing, scroll down to Copy, and select OK.
  • Select a single picture, or select All.
  • When you have finished copying pictures, reset the Image Storage location to your original setting.
  • Jan 18, 2010 | Kodak EasyShare One Digital Camera
    How do i switch off internal memory
    How to switch the camera over to saving pictures directly onto the SD card.
      1. Menu
      2. Cam settings
      3. Chose AUTO or SD card option and Press OK
      After you have done so I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 17, 2010 | Kodak EasyShare C613 Digital Camera
    Just put a new memory card in the camera but the screen keeps showing internal memory is full
      1. Menu
      2. Cam settings
    If you still experience problems:
    The SD card might not be supported by the model: Your camera Memory card support is SD/MMC up to 1 Gigabyte
      After you having successfully switched over to saving onto the SD card. I would guess that you would like to transferre the pictures from your internal memory over to the SD card.:
    Question :
    Follow these steps:
  • Jan 16, 2010 | Kodak EasyShare C643 Digital Camera
    I can only take one picture. If I take another,
    Try resetting the camera. Go into the setup menu and find "reset".
    Sep 21, 2009 | Kodak EASYSHARE M1063 Digital Camera
    I can take pictures just fine but when I push the review button on the camera, it statesno images to display. I cannot review any pics and cannot download into my laptop, HELP I am trying to sell my home...
    if the display its ok ..I suspect something wrong with the internal memory ..try to remove the SD memory card and see if the pictures are actually stored on the card..and download directly from the card using a card reader ...if you only use the 32M internal memory and didnt expend on a Sd card ...probably its full or something wrong and do not store pictures anymore ..and thats why it doesnt sow'em anymore ...try to reset the camera to default setings Im not sure but all cameras have something lik ethis in menu...and try to see again the results...but if the camera works ok ..but cause a malfunction of software it do not sowa the pictures anymore ..the solution is to download from the SD mem card directly using a card reader ...most laptops have sd card reader ..and all picture printers read from the card too
    Aug 04, 2009 | Kodak EasyShare CX7530 Digital Camera
    Trying to transfer pics on internal memory to my SD card.
    Set the image storage setting of the camera to Internal.
    Once it is set to internal, put the card in the camera and press review.
    Copy the pictures from the internal memory to the card.
    Jun 22, 2009 | Kodak EasyShare C330 Digital Camera
    Whenever i take a picture and press to review it says file error
    Hello!!
    Try formatting ur memory card once and reload it ...
    Apr 20, 2009 | Samsung Digimax S630 Digital Camera
    New camera won't work!
    That message is probably because you have not saved any images in the camera's internal memory. Whatever pictures you took are on the SD card. Try taking a couple of pics using the SD card and try the review. If you are able to review, then all is well. If you cannot review, then one of 2 things:
    1. Faulty SD card..Replace or format it.
    2. Remove the SD card and take a pic. The pic will be saved in the camera's internal memory. If you still cant preview, probably a fault with the camera, and you'll need to service it.
    Jun 02, 2008 | Kodak EasyShare C340 Digital Camera
    Casio Exilim EX-Z750 Digital Camera Logo
    161 people viewed this question
    Top Casio Cameras Experts
    Greg Cann
    Greg Cann
    Are you a Casio Camera Expert? Answer questions, earn points and help others
