Question about Nortel T7316E 2-Line Corded Phone
Nortel nt8b telephone
There is a direct line into this phone, which is on a multiline system, but no one remembers the direct line phone number. Is there someway I can find out the number.
  • 27 Answers
Get on the line and dial 1800 444-4444 and when it answers it will tell you the number then hang up.
Posted on Aug 28, 2009
How do we change the phone numbers on the speed dial
Feb 27, 2010- Speed dial numbers 001 -255 (256-279 are personal speed dial entries) are system wide speed dial numbers and are changed in system programming. System programming is done on M7310,M7324 and T7316 set only.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say Terminals&Sets.
The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the next key 3 times(bottom right arrow).
The display should say Sys speed dial.
Press the show key (top right arrow)
The display should say speed dial#:--
enter in the speed dial number you wish to program.
Press the show key (top right arrow) .
The display should show the existing speed dial number
Press the chg key
Enter in new telephone number
press ok when finished
repeat for remaining speed dials
Press the release key when finished
Apr 16, 2010 | Nortel T7316E 2-Line Corded Phone
Nortel T7316E Call Forwarding - Outside Line
The Nortel call forwarding (feature 4) is for forwarding the ringing and intercom from one extension to another.ex. if you were going to be working in the conference rm. instead of at your desk,with the forward on to the conference rm. extension, the calls you get at your desk will transfer to the conference rm. phone. Call forwarding through your service provider is done by accessing the telephone line you wish to forward, dial *72 (you should get dialtone reordered)and dial the telephone number to where you want the calls to be forwarded to. the party on where your forwarding the line to has to answer the line for the forward to take place. to remove call forwarding , access the line you have the forward on and dial * 73, you should recieve a stuttered dialtone for confirmation that the service is off
Dec 07, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Getting the M7208 to work
Nortel M7000 series are proprietary sets which require a nortel MICS, CICS, or an older 8x24, 6x16, or 3x08 in order to work. If you have the system, it maybe that the jack isn't activated with a system port.
Nov 24, 2009 | Nortel Meridian M7208 Corded Phone
Nortel phone m3904 won't forward to an outside line
The DN may not be configured to allow forwarding to an outside line for security reasons. I think the default is 4 digits. You will need to talk to whomever programs your switch and ask them to allow this feature.
Nov 10, 2009 | Nortel Norstar 16-Line PBX Speakerphone
Server was changed and i have now lost telephone system control
It does if you use a crossover cable plugged directly into the system and set your PC for an address in the same IP range.....
Carl
Sep 16, 2009 | Nortel T7316E 2-Line Corded Phone
I am considering buying a Nortel T7208 2 Line phone for my home office. I have two separate lines, with two separate numbers. I need a phone that will allow me to plug both lines into the desk top unit. I...
Hi there...
OK, the Nortel T7208 set works only on a Nortel system.
It has only one line cord plugged into it, cause the telephone system can be programmed for more telephone lines and features from the system.
If you want just a home (analog) telephone service; look at Aastra/ Telematrix/ there are others - 2 line sets.
ONLY buy this Nortel set is you have a Norstar system. Otherwise the set will not work for you. It needs a system to run off.
Good luck in your search!
Aug 29, 2009 | Nortel Business Series Terminal T7208 -...
Nortel t316e phone only rings 2 times
You could have a CICS, and MICS or a Nortel BCM. Which do you have?
You will need to access admin programming, do you know how?
Jun 26, 2009 | Nortel T7316E 2-Line Corded Phone
Online cheat sheet for the feature buttons on the Nortel T7316E. I work for the school system and our people keep loosing their cheat sheets. I'd like to refer them to a link so they can reprint anytime.
Here's the cheat sheet you were looking for. Here at IdacomUSA we provide User Guides and System Manuals for every system and phone that we repair. We also repair the Nortel T7316E for $75, which will transform your old phone into one that looks and works like it was purchased yesterday.
As for the link for your cheat sheet, here it is.
Nortel ICS Telephone Feature Card
Jun 22, 2009 | Nortel T7316E 2-Line Corded Phone
Programing my nortel t7316e charcoal to access whole phone lines
If you are fmailiar with the programming of the system, you must set the lines (3-8) to appear and ring on the extensions.
Assuming you have a later release MICS or CICS:
Press Feature ** 266344, then the installer password.
Press Show at Terminals and Sets, enter ext #.
Press Show until you are asked for the line number, then scan through the line appearances, and change to "Appear Only" on the lines you don't want to ring at that set.
Repeat for each extension you want to change.
DO NOT DO THIS UNLESS YOU ARE FAMILIAR WITH PROGRAMMING.....
Nov 11, 2008 | NorStar T7316E Corded Phone
T7316e Nortel Meridian Norstar Telephone
Feature *1, Press the desired key, dial the #
Nov 03, 2008 | Nortel Norstar 16-Line PBX Speakerphone
Nortel T7316E 2-Line Corded Phone Logo
506 people viewed this question
Top Nortel Lands Phones Experts
David Burbee
David Burbee
Shehu Pro
Shehu Pro
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
