Door open The printer was working great and a paper jam happened. I pulled the paper out and now the printer is not responding. I checked the status and "Door Open" is indicated. yet it is not.
    Sergeant:
  • 207 Answers
It sounds like there is a sensor that got damaged or jammed when your paper jam occurred. Look around the inside edge of the door for a pin or clip that may pass into a hole that signals a door closed. If you can't find that look around the edge that the door touches for a contact that the door could trip. If you find either look for a damaged clip or a piece of paper that could be affecting the signal.
If you can't find either please advise me as to the manufacturer and model of your printer so I may find out what type and the location of your sensor
Thanks
Dave
Posted on Nov 07, 2008
How do I fix this paper jam2
Dear
Open and close the front door. The jammed paper
automatically exits the machine.or gently pull the paper out of the output tray.
If there is any resistance and the paper does not
move when you pull, or if you cannot see the paper
in the output tray, open the rear door by pulling the
tab on it.Remove the jammed paper by gently pulling it
straight out.Close the rear door.
Some times it may happen if machine gets ready and after one page print it shows jam2 , then check the lever for jam2 sensor on the top of fusser, the spring may dislocated or lever may broken(rare).
Thanks.
Feb 13, 2015 | Office Equipment & Supplies
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
Does the office jet 8500 have a power reset button ? paper jamed, i removed the paper but now nothing happens
Check the following Steps to fix HP Printer Carriage Jam :
Open the print carriage access door. Check for any packing material that may be blocking the internal components. Check for an orange shipping lock that may still be in place on the left side. Pull the shipping lock out, if present, and discard.
Remove and reinstall the cartridges to make sure they are properly installed. Lift the front center of the print carriage access door to open it. Lift the door up until it locks into an open position. Press down on a print cartridge and allow it to spring back up. Lift the cartridge out of the printer. Do the same for the other cartridge. Slide the black cartridge into the slot on the left and the color cartridge into the slot on the right. Press down on each one to lock it into place. Lower the print carriage access door.
Check the print cartridges to make sure the protective tape has been removed from the ink nozzles. Remove the cartridges from the printer. Remove any tape or labels. Replace the cartridges into the printer.
Push in on the tab on the left side of the clean-out door on the back of the printer to open the door. Lift the door out of the printer. Check for any paper jams. Jammed paper can block the printer cartridge carriage from moving. Pull any jammed papaer out.
Oct 11, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Printer status states paper jam although there is
Have you check the rear side of your printer?
Try the below..maybe it will help...
Disconnect the USB cable or parallel cable from the rear of the product then turn off the printer. Turn the knob on the rear access door counter clockwise, and then pull the door out to remove it.Check if there is any paper there..
May 24, 2010 | HP DeskJet 5550 InkJet Printer
I have a paper jam in my printer. The paper is
You will have to open the Printer door and pull the paper out if you are lucky it will pull out in one piece if not you will have to get all the pieces out before it will operate again. When pulling out go very easy with it and move your fingers down with the paper to apply force at the closest point to where the paper pulls into printer.
May 13, 2010 | Brother HL-2040 Laser Printer
I had a paper jam- I pulled out the paper - checked every where, all paper was cleared. I can make copies but can't print anything from the computer. Status of the printer says paper jam, but there isn't...
open ur printer front cover clean paper pickup roller (black rubber roller)
2.:- then go to printer back cover open clean all (black rubber roller)
hope this is working
Apr 08, 2010 | HP Deskjet F335 All-In-One InkJet Printer
How can i remove the paper inside the printer
For the paper jam issue turn around the printer and open the back door to pull the paper.
and for the power issue unplug power cord from wall and from the printer side too,plug everything back and ready to work.
Aug 04, 2009 | HP OfficeJet 6110 All-In-One InkJet...
HOW DO I REMOVE JAMMED PAPER
Please turn the printer Off and then ON , till you see the error message of " Paper Jam" check all the flags on paper path, specially on Fuser Assembly.
Turn printer OFF, pull all trays out gently,
Disconnect cables to network or PC. turn printer ON,
check the message gets repeated - paper Jam,
Conclusion : There is some bit and piece of paper activating flags,
take all toners out gently and transfer Drum, look into printer, and
lift the paper path under the toners, push the door a little bit and unscrew the paper path and can see a piece of paper on right side..
Pull the paper out and screw bach. put every thing back in their original status.
Now the printer will work and there will not be any papers..
Jul 31, 2009 | HP Color LaserJet 2600n Printer
HL 2040 paper jam light is blinking but there is no jam. the printer sounds like it dies out everytime it tries to print.
Often the paper jam light will stay on when the *back* paper jam door is not cleared.
Open up the back of your printer. There is a 2nd door behind this door that you can pull open. If there is a paper in this section, pull it out and it should clear your red light.
When clearing paper jams, clear the front first, and then if the red light is still on, you need to check the back hidden door for another piece of paper.
Dec 08, 2008 | Brother HL 1440 Laser Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
