Cd burning on windows media player
The cd goes through the burn procedure then registers blank when i attempt to play it on cd player or computer.
  • 1 more comment
  • 2lyons Nov 08, 2008
    i use the windows media player programme and until 1 month ago it worked fine. The strange thing is that it burns dvds still.I have tried other brands of cd to no avail.
  • 2lyons Jan 12, 2009
    CD burner goes through the process but doesnt finalise disc so disc remains blank when computer says its been completed. Does anyone know why this happens?
  • Johnny Massengill
    Johnny Massengill May 11, 2010
    what program are you using to burn the CD's with?
  • 345 Answers
A DVD/CD combo burner has two lasers in it (one used to burn CD's and the other to burn DVD's) and if the one that is used to burn CD's has stopped working it would stand to reason that it would be able to burn DVD's but not CD's. If the computer isn't under warranty, I would just go buy another DVD/CD combo burner. If the computer is still under warranty, take it to an authorized repair station for that model/brand of computer. The only other thing you might try is to clean the drive with a CD cleaner disk.
Posted on Nov 09, 2008
  • 128 Answers
You will need a burning software like Nero to burn cds
Posted on Nov 07, 2008
After running a CD burn, PC treats it as a blank disc
Try putting the burned disc into another computer to see if it reads it. If not then it could be an issue with the disc burner itself. The laser could be going bad and that would cause the burner not to burn discs properly.
Dec 24, 2011 | E-Machines eMachines Desktop PC
Tip
Burn a Data CD or DVD in Windows 7 Using Media Player
You can burn a data CD or data DVD in Windows 7 using Media Player. An audio CD can contain just approximately eight minutes of music. On the other hand, if you burn a data CD or data DVD in Windows 7 using Media Player, it will be able to hold numerous hours of music. Video files and pictures can also be added to the data discs.
When you burn a data CD or data DVD in Windows 7, the Windows Media Player does not transform the selected files to a different format prior to saving them to a blank data disc, so the files stay in the compressed condition. This allows you to put much more items on a single disc.As the format of the files is not changed, the quality of the files remains the same.
You can burn a data CD or data DVD in Windows 7 using Media Player as follows:
  • Click Start.
  • Click All Programs.
  • Select Windows Media Player.
  • Click the Burn tab in the Player Library.
  • Click Burn options and select Data DVD or CD.
  • Insert a blank disc into the CD or DVD burner of your computer.
  • Close the AutoPlay dialog box if it comes into sight.
  • Some people have more than one CD drive in their computer. If you have multiple CD drives in your computer too, select the one you would like to use in the navigation window.
  • Look for the songs you want to burn.
  • In order to make your burn list, drag the songs from the details pane in the center of the Player Library to the list pane which is on its right side.
  • You can also change the order of the items in the burn list by dragging them upward or downward in the list.
  • To remove a song from your list, simply right-click on the item and click on Remove from list.
  • After you finish making your list, click upon Start burn.
It can take a while to burn a data disc. If your selected items cannot fit in one disc, you also have the choice of burning the rest of the items to a different disc. A data DVD is not the same as a DVD-Video disc ex. the movie DVD you buy or rent from the store.
on Apr 15, 2010 | Computers & Internet
Tip
WANT TO BURN A DATA-CD OR A DATA DVD ON WINDOWS 7 USING WINDOWS MEDIA ...
Burning a Data cd on dvd on windows 7 is very easy and simple using Windows media player....
just follow the steps given below:
1) Click on the Start button
2) Click on All programs
3) Go to Windows Media player
4) Once the player is open look for the Player library and click on the Burn Tab There.
5) Once the Burn options are opened click on Data DVD or CD
6) Insert a blank cd into your cd-rom.....make sure the type of cd you are inserting is same as the
option you select for burning.
7) if in case auto play box opens then close it
8) In order to make it easier, prior to starting the procedure of burning a dvd or a cd make a folder on
the desktop which includes the data or the songs that you want to burn in......it makes it easier to locate a single
folder rather than to search individually for an item.
9) Drag the songs you want to burn right into the middle of the player library's list pane which lies on its right side
10) for removing a certain song, right click and select remove from list
11) after your'e done with the selection, just click on the START BURN button
12)It takes a little time to burn a data disc. Make a note that data DVD is not as same as DVD video disc.
That's it and you get a whole set of songs into your cd just within a few minutes.........so get goin.!!!
Good Luck!!!!!
on Apr 08, 2010 | Computers & Internet
How to burn a dvd from an acer laptop
The laptop should have come with CD/DVD burning software preloaded. Acer's specs page for your model says it comes with NTI Media Maker. The program will have help information available to guide you through, and you can find more help online. If you just want to write data files onto a DVD, the process typically is not much more than dragging files to a layout window and telling the program to burn the disc. This gives you a way to back up data, or to store movies in formats you can view on a computer (AVI, MPG, etc.).
On the other hand, if you're asking how to make a video DVD that will play in a regular DVD player like a commercial movie, maybe with features like menus or scene selection and such, the process for making that kind of DVD is more involved. You need some DVD authoring software. NTI may offer that capability, but I'll admit I have never looked.
In most cases, the software that comes preloaded on computers is a limited version of some commercial product. The computer manufacturers get paid to include the program, and the software company hopes you'll buy the full version when you discover the limitations. If you don't want to pay for software, there are free, more full-featured programs available for downloading.
For general CD and DVD burning, I use CDBurnerXP. To make video DVDs, I use a program called DVDStyler. Both are open-source, meaning they are 100% free to download and use, and they both offer a lot of features.
Feb 11, 2011 | Acer Aspire 5742Z-4200 Notebook
I want to burn Windows Media Audio/Video file to a cd so i could play it to a cd player
put a blank cd in your drive and make a playlist in window media player and open the copy to cd dialog and copy your contents. You can also go for 'nero' for the same purpose which is more easy and better.
Nov 17, 2009 | Microsoft Windows Media Player
My Compaq Presario desktop will not burn CDs
Perform a system restore and take the computer back to a time before the problems started with burning, or you can download a different media player and try burning with that, real player as a good bit of software to use for burning and Nero is too (Nero is a devoted burning suite)
Get real player here >>>>>>
http://uk.real.com/realplayer/
Get Nero 9 here >>>>>>
http://9-burning-rom.com/index.asp?aff=101&camp=gg_nero_uk&se=google
Good luck
Jul 08, 2009 | HP Compaq Presario S4000V (P8655P#ABA) PC...
I have just brought a new pack of blank CD's, i am
Its a common problem with CDs. Check that your CD drive can PLAY CDs. If so either the CD drives optical head is dirty or your CD pack are low quality. CDs damage real easy. Try putting another CD, another brand or you must use CD doctor-something like that. Did that help
Mar 10, 2009 | Packard Bell iMedia 6826 (P481000502) PC...
2002 JEEP [Wrangler] CD player will not play Nero burnt CD's
I had the same problem in my 1998 Jeep GC Limited. It has been a year and a half since I have played a burnt cd in my cd player. I researched everything possible and came to the conclusion that it was either the type of cd I was using (some cds with prints etc are hard for the laser inside the player to read) or the burning speed, and after many failed attempts, I still couldn't find a combination that would work. Then yesterday, my brother had a burnt cd he had made with his computer and we tried it just to see if it might work and it did! So, the brand of cd is Memorex, the type is CD-R, and they are 80min. worth of recording time. I purchased some of these cds at Hastings (although I'm sure they are avaliable wherever you purchase blank cds) and tried burning one in my laptop just to make sure it was going to work and it did! I burned the cd using windows media player and before I started the burn I went into 'burn options' and set the burning speed to the lowest possible. Hope this helps!
Dec 11, 2008 | Jeep AM/FM Cassette with CD Changer...
Burning a wmv file onto a dvd from my laptops dvdrw
Windows Media Center is the best method for burning WTV files to a DVD.
  1. Choose Start?All Programs?Windows Media Center. ...
  2. Stick a blank DVD (or CD) in your DVD drive. ...
  3. To create a DVD that can be played on your TV, select the Video DVD or DVD Slide Show option and click Next. ...
  4. Type a name for the DVD and click Next.
More items...
How to Burn a DVD in Windows Media Center - dummies
www.dummies.com/computers/...7/how-to-burn-a-dvd-in-windows-media-center/..
or go to this link should help you out..
How to Burn DVD in Windows Media Center dummies
Oct 27, 2017 | Computers & Internet
Cd drive
media player needs configuring,select all file types.reason it wont find songs previosly burned is probably because burned as compilation and not finalised.you can download a player called VLC (for free)it will play any file type a lot of which media player cant.whatever media you have it'll play
Dec 06, 2007 | Computers & Internet
Computers & Internet Logo
199 people viewed this question
David Payne
David Payne
