Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
Newest D Link 2310 Problem!!!!!
At&t was able to get the "home computer" back on line, but when they tried to connect the satelite computer.... it had lost all signal to the router. They were unable to do anymore, and D Link phone lines only give me a recording........ sigh...... ready to give up!!!!!!
If anyone has a solution to "coaxing" the satelite computer to recognize the router again, I'd stop pulling my hair out!!!!!
  • 4 more comments
  • Anonymous Nov 14, 2008
    i also lose connection to my router D Link 2310 and my wireless adapter cannot get the signal back. i have to keep unpluging and plug the router back in and the signal is back again. leave for work and come home again and adaper has loss signal again.
  • abaghda Nov 15, 2008
    The wireless signal will fail every few hours - I've also upgraded to the latest firmware and the problem still continues. D-Link GOLD series is Junk.
  • Anonymous Nov 15, 2008
    i have to same problem with both my routers dlink 2310 and my netgear router. i only had this problem when i moved in to my new house. its driving my nuts. i dont want to keep resetting my router everyday. i dont have the time to dig deep into the problem because i dont have the time. i think the problem might be that i have DHCP on and that i put my computer to sleep every night. but i also lose my connection with my xbox360 and ps3. i dont know if the problem is with my ISP, i use to have comcast and never had this problem. when i switch my encryption to TKIP it work for about two weeks. Becuase AES would switch the cipher key everyday and therfore my computers would not be able to connect without the new key. anyway the problem came back now and i dont know what to do.
  • Anonymous Nov 20, 2008
    JESUS CHRIST! I'm gonna throw this **** outside. My old *** linksys didn't even give me trouble. I have the exact same problem as the last person. I can connect to it wirelessly, but when i disconnect, leave home, come back, the wireless signal is gone and i have to restart the router. I e-mail D-Link a very long and detailed explanation of my problem, if they have no solution then i'm returning this junk and going Linksys or Belkin.
  • Theresa Lamb
    Theresa Lamb Nov 21, 2008
    I WAS ABLE TO RE-ESTABLISH CONNECTION TO MY SATELITE COMPUTER....NO THANKS TO THOSE JERKS AT D-LINK!!!! HOWEVER, I AM BACK TO THE SAME CONSISTANT PROBLEM. FOR NO REASON, THE ROUTER WILL LOOSE ITS CONNECTION, RIGHT IN THE MIDDLE OF AN IMPORTANT RESEARCH PROJECT ON LINE...... AND POOF! GONE. I HAVE TO SHUT DOWN, AND REBOOT BOTH COMPUTERS, AND THE ROUTER, AND THEN CAN RE-ESTABLISH THE CONNECTION TO THE INTERNET, AND START MY PROJECT ALL OVER AGAIN!
    SOMEHOW IT MAKES ME FEEL BETTER TO KNOW THERE ARE OTHERS OUT THERE SUFFEREING TOO!!!
  • empty970005 May 11, 2010
    Did At&T attempt to get you up and running with the second PC ? If so what did they have you do? Also what speed are you getting is it 768,1.5,3.0, or 6.0?
The Real Problem with this router is the Atheros chip inside overheating. The remedy is to install a heat-sink on the chip. Also, these routers have a history of the ethernet pins crossing and jumping into the wrong slots, examine the ethernet pins very carefully and attempt to straiten them.
To test my theory, Get a beer cap and take the plastic seal out of it so that it is bare aluminium on the inside of the cap, next put a drop of heat sink grease on the outside of the cap, (if you are too cheap to get some or are in a hurry, use a drop of toothpaste) then stick it on the atheros chip inside and fill the beer cap with vegetable oil, (Use vegetable oil instead of water because if you spill it on the main board, it will not cause damage.. IF YOU MUST USE WATER, be sure to NOT SPILL it on the board.)
After you have tested it and it works, Consider getting a small cpu heatsink, Should work fine without a fan.
Thanks
Vince
Posted on Feb 08, 2010
  • pjdm Jul 09, 2011
    This is the correct analysis of the widespread DI-524, WBR-2310 and other D-LINK products with intermittent wireless. The Atheros chip is smoking hot in use and a heat sink solved the problem on both of my units. I have submitted amateur photos of my personal solution on another topic but the heatsink and holes in the case for airflow solve my issues.
  • 3 Answers
As far as the wireless dropping periodically I'm pretty sure that downgrading the firmware to 1.0.3 will work. I had been running at this level for quite some time and for some reason I decided to upgrade to the latest version which started the problems for me. I am downgrading to this now and I expect better results. All of the firmware versions are available at http://www.dlink.com/products/support.asp?pid=470&sec=0. You pick the right hardware revision. PLEASE NOTE: Save off/remember your settings as when you change the firmware it resets all of them back to system defaults.
I don't really know about the connection to the satellite so this is really only regarding the drops which seem to be what others are experiencing as well.
Posted on Jan 04, 2009
After cable co. split cable and installed another modem, D-Link WBR 2310 router no longer works with its original modem. Tried resetting, unplugging, etc. Can't get wireless.
Use an Ethernet cable to connect your computer to one of the LAN ports.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for a line of output like:
Default Gateway . . . . . . . . . : 123.468.32.1
Start Internet Explorer
Type http://123.468.32.1
Press Enter
Login to your router
Click to run the "Wireless Networking Setup Wizard", to:
1. set an SSID
2. set an encryption-level, e.g., 'WPA' or 'WPA2'
3. set a password for your network
Click OK to restart your computer
Use your wireless device to connect to that SSID, using that password that you set.]
Jun 06, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
Last january my d-link WBR-2310 still working fine but now i wanna use it, it wont connect in the net?
Try power cycling the router.
Disconnect the router from all computers. Power off the router. Power on the router. Reconnect the router to all computers. Check the Internet connectivity.
Mar 01, 2011 | Computers & Internet
I have a d-link wbr-2310, we got the child a ipod touch for xmas i cannot connect to my wifi.
On the iPod touch, select "Settings"
On the second line, you should see "Wi-Fi", touch on the right side of this bar, this will bring you to the menu to choose a network. From there, choose the network you want, and type in the security code if need be.
As a note, if you go back to settings, the 1st line is "Airplane Mode", make sure this option is "OFF".
Jan 05, 2011 | D-Link RangeBooster G WBR-2310 Wireless...
TomTom One has lost connection with satilet
To regain connection back to th satelite, first remove it and reinstall it back, if it does not connect still, then you have to update the tom tom reciever by connecting it to a computer, remove all the maps on it, the update it from the home website.
After updating, upload the new maps back on it, the you connect it to the car system, after doing this, then you try to use it. If it does the same, then it is due to a poor signal in the area that the gps in not connecting to the satelite.
Take care
Sep 09, 2010 | Tomtom ONE GPS Receiver
Wbr-2310 error 112
Check your physical connection first. From the modem, it should be connected to the router's Internet port, then your computer must be connected to port 1 on the back of the router. Then do a power cycle, no need to run the setup CD. If it doesn't work, you need to manually configure the router. You may need assistance from D-Link tech support. Call their toll free number
Jun 20, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
I have a D Link WBR 2310 router. I had it set up for wireless network on my home laptop. It was always configured for immediate access (no pwd required), secured with wpa. I try to connect with my work...
did you reset to factory defaults or just unplug the router?  If you hit the reset button, you'll have to go in and set everything back up.   Have you tried to connect via webbrowser connected to the router from your home computer?  go to 192.168.0.1 and see if you can connect to the router to see what's going on.
Dec 17, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Vista Home new computer causing busy signal on home phone
In the modem there are two link one for the phone and other for the line . In the line link you have to connect the direct phone line and phone link you have get the extent cable, link it and connect it to the phone . try it and porb comes inform to fixya.com
May 12, 2008 | Dell Dimension 3000 PC Desktop
Can you install without the set up CD?
Hi
go to this link and click on download
http://www.dlink.com/products/support.asp?pid=470&sec=0#applications
DLINK
Pls dont forget to rate solution, thanks!!
Apr 30, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Wireless router and home phone
it is highly unlikely that your router would disable your phone. Although there is a possibility it may cause static on the line.
Feb 03, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
525 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
