Question about NTL Lands Phones
How to set the time and day on ntl t200 digital answering system
3 Suggested Answers
SOURCE: IIncreasing the number of times the phone rings before message system answers
I have a Panasonic KX-TG5632 and I need to set the ring time, how do I set the ring time?
Posted on Jun 10, 2008
SOURCE: ntl d5100 digital answering phone system with 4 phones
I HAD THE SAME PROBLEM BUT HAVE FOUND MY INSTRUCTIONS I HAVE A D5903SE WITH 3 ADD HANDSETS YOU CAN E.MAIL ME ON wendi_borrie@msn.com OR I HAVE A N.T.L HELPLINE NUMBER 08702413201 LET ME KNOW IF THIS HELPS WENDI
Posted on Dec 18, 2008
Fuji fine pix t200 turns on intermittently, when It does it asks me to set time
There is only one thing you can do, and if it does not change the situation, you have to bring the camera to a repair centre. The manual says tis:
Jul 05, 2014 | FUJIFILM - FinePix T200 14.0-Megapixel...
I don`t know how to change the date and time of my sony dsc-t200
Hello there. You can do it this way:
1 Select (Clock Settings) from (Settings) on the HOME screen. 2 Touch [Clock Settings]. 3 Touch the desired date display format, then touch [t]. The clock settings screen appears. 4 Touch each item, then set its numeric value by touching v/V. 5 Touch [OK]. To cancel the clock setting Touch [Cancel] or [BACK] in step 5.
Sincerely, Steve TM
May 28, 2011 | Sony Cybershot DSC-T200 Digital Camera
Lost manuel....how do I set the day and time....
1. Turn on the system. Hold down
SKIP/TIME SET/CHECK. The
system sounds a tone after 1
second.
2. While holding down SKIP/TIME
SET/CHECK, press REPEAT/ANNC/
DAY. The system announces
"Monday" and &'?appears on the
display. Repeatedly press REPEAT/
ANNC/DAY until you hear or see the
correct day.
3. While holding down SKIP/TIME
SET/CHECK, press MEMO/2 WAY/
HOUR. The system announces "1
AM". &' appears on the display.
Repeatedly press MEMO/2 WAY/
HOUR until you hear or see the
correct hour.
4. While holding down SKIP/TIME
SET/CHECK, press PLAY/PAUSE/
MIN. The system announces "01".
Repeatedly press or hold down
PLAY/PAUSE/MIN until you hear or
see the correct minute.
5. Release SKIP/TIME SET/CHECK.
The system announces the day
and time you set.
6. To hear the current day and time,
press SKIP/TIME SET/CHECK while
the system is on or off.
Thanks!
Mar 29, 2011 | Radio Shack 3808 Digital Answering Machine
Are there any ways to change the language Japanese to English for dsc t200
Touch [HOME] to bring up the main menu. Select Settings (toolbox icon). Select the "A" icon. Select the desired language.
Sep 23, 2010 | Sony Cyber-Shot DSC-T200/B Black Digital...
Dsc-t200 langauge setting
Here is a link to your manual:
http://www.docs.sony.com/release/DSCT70.pdf
Go to Page 23. The language settings are accessed through the Home menu.
Thanks for using Fixya.
Jun 26, 2010 | Sony Cybershot DSC-T200 Digital Camera
How do you set the time and date? Thanks
Hi!
First of all you need to set the Language which allows you to set the answer in either English or in Spanish voice menu mode. Once the language is set, all voice menu, including the ones used in Remote access mode, will be switched to the selected language.
1. Press and hold the STOP/SET button for two seconds, then release to access the set-up menu.
2. The answering machine announces, "For English, press NEXT, press SET to continue (in English). Para espanol, oprima PREVIO, oprima PROGRAMAR para continuar (in Spanish)".
3. Press NEXT, answerer enters English voice menu mode. If PREVIOUS is pressed, answerer enters Spanish voice menu mode. If SET is pressed, answerer remains in the current language mode. In any case, the answerer enters to the TIME/DAY menu.
NOTE: Language can only be set when the user is in physical access of the unit. When you are running in Remote Access mode, the language cannot be changed and will remain in the language you’ve previously set.10
Setting the Time/Day : This setting allows you to set the current time and day for the Time/Day stamp attached to each message.
Hour : 1. When you have completed setting the Language, the unit will enter the TIME/DAY menu. The answering system announces, "Time (the current time and day setting) To set hour, press next...press set to continue."
2. To change the hour, press and release the NEXT or PREVIOUS button and the answering system announces an hour, such as "12am, 1am, 2am," or "12am, 11pm, 10pm."
3. After choosing the hour, press and release the STOP/SET button to store the hour. The answering system enters the Minute menu.
Minutes : 1. The answering system announces, "(the current minutes setting). To set minutes, press next...press set to continue."
2. To change the minutes, press and release the NEXT or PREVIOUS button, and the answering system announces a minute such as "1, 2, 3" or "59, 58, 57."
3. After choosing the minute, press and release the STOP/SET button to store the minute. The answering system enters the Day menu.
Range of Settings
Time
Hour 12 a.m. - 11 p.m.
Minute 0 - 59
Day Sunday - Monday
Rings 2,3,4,5 toll saverto Answer
Message time 1,2,3,4, minutes
Security 0 - 9, 0 - 9, 0 - 9Code
Default Settings
Time 12 a.m. Sunday
Rings to Answer 4
Message time 2
Security Code 12311
Day
1. The answering system announces, "(the current day setting) To set day, press next...press set to continue."
2. To change the day, press and release the NEXT or PREVIOUS button, and the answering system announces a day, such as "Sunday, Monday" or "Sunday, Saturday."
3. After choosing a day, press and release the STOP/SET button to store the day. The answering system enters the Rings to Answer menu.
Thanks for using FixYa and do rate the solution as Fixya, if found helpful.
Thanks
Rylee
Apr 06, 2009 | GE Telephone
Sony DSC T200 image fault
pls see this link to get help from Sony
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
http://eservice.sony.com/webrma/web/index.do
pls rate me FIXYA for help
Apr 03, 2009 | Sony Cybershot DSC-T200 Digital Camera
How to set time and date
For example to set wedesday 1:10 am you would:
a: press and hold the time/code button for 2 sec. You will hear announcement "to set code ...... to set time press memo (2-way) button
b: release the time/code button
c: press the 2-way/m button once. You will hear voice prompt set day and time, sunday
d: press the << button or the >> button until you hear wed.
e: press the time code button once to enter the current day and xx hour is announced
f: press the << button or >> button to get to 1.
g: press the time code button once and 1 will be announced and you will hear xx min. announced
h: press the << button or >> button once for each minute as it will gradually increases or decreases to reach 10.
i: press the time code button and 10 will be announced followed by pm
j: press << button or >> button to change am
k: press the time code button once and it should announce the current day and time.
good luck
Mar 13, 2009 | BellSouth Digital Answering System 2006C...
Ntl d5100 digital answering phone system with 4 phones
Oct 16, 2008 | NTL Lands Phones
Lands Phones Logo
21 people viewed this question
Top NTL Lands Phones Experts
Computer Repairing
Computer Repairing
Cliff
David Burbee
David Burbee
Are you a NTL Lands Phone Expert? Answer questions, earn points and help others
