Iomega zip drive Z100ATAPI returns error message: "Insert Disk into drive H:" even though there is a disk in it. It is recognized by the system and Device Manager in Windwos XP says the drive is working fine.
  • dadandy Nov 07, 2008
    I have since discovered that this particular drive is subject to what has been called the "click of death" syndrome. I decided to try a new drive. Found an inexpensive replacement drive on eBay.
  • Anonymous Nov 28, 2008
    BIOS/DM won't even find this critter on a Dell XPS R400 (current on BIOS -- I know, a bit old on machine -- it's a clunker I play with).
  • 345 Answers
Just because the device manager says the drive is working fine doesn't mean it is. If it won't recognize the ZIP disk, either the disk itself is bad or the zip drive is bad. I would try another zip disk and see if it will read a known good zip disk.
Posted on Nov 07, 2008
I am trying to connect a Iomega Z100ATAPI Zip drive to my Windows 7 laptop.
click start right click on computer select properties device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
Mar 23, 2012 | Iomega 100MB IOMega ZIP Drive Internal IDE...
My Z100atapi Zip drive is recognized by Windows 7, but the old disks are not in a recognized file format. I need to get the old data ..
Greetings - According to Iomega your 100 MB ZIP drive media should be fine at being at least readable (the Iomega software does not work with Win 7) natively by Win 7 and Vista. Since the drive is recognized I suspect the problem is actually the discs themselves.
It turns out that the discs were not very good at long term storage and are notorious enough to have a term referring to the problem as the "Zip Burp" where:
  • A) All files on the disk disappear
  • B) Just Compressed Formats such as JPG, ZIP, CAB, ECT Disapear
  • C) "The Disk Needs To Be Reformatted" message is displayed or
  • D) files disappear as you click them
The only way that I know to find out for sure if your discs are good is if you can find someone with an XP machine that will let you temporarily install your Zip drive (including the latest drivers) and see what happens.
Good Luck,
Mikeywaf
May 27, 2011 | Iomega 100MB IOMega ZIP Drive Internal IDE...
Pen drive is not appearing
No need to worry, I will solve your problem follow this link to find how to solve it http://www.fixya.com/support/r4391734-usb_flashdisk_pen_drive_write_protect or you can see my blog, http://adhiwahyudy.blogspot.com, but this blog use indonesian languange
Mar 15, 2010 | IBM Iomega ZIP 750 (22P7099) External ZIP...
Pen drive showing insert disk
check your pend drive on some other system if the message is the same, it has become corrupt,replace it
Sep 16, 2009 | IBM Iomega ZIP 750 (22P7099) External ZIP...
Can't read specific Zip 100MB Diskette
Its probably a bad disk. The only way I have been able to fix these is to First launch disk utility THEN put the disk in. THEN run the utility. You have to do it in this order. The key thing here is utility has to be running first and then insert the disk "HOT"
Hope this helps!
Jan 22, 2009 | Iomega Zip 100MB (31714) External ZIP...
100mb zip disk not reading
These are pre-formatted and servoed at the factory.
Awhile back I was researching the 'Click of death" fault and found a guy in Belgium or Germany that coded a repair program for bad disks. Googlee for it
sometimes when it formats, it hoses the servo information (which the drive uses to keep track of things) and the disk becomes useless. This is why I stopped using ZIP disks and won't even buy a drive when I see them for 9.99 ;-)
Jan 16, 2009 | Iomega Zip 100MB (31714) External ZIP...
Pendrive error message "please insert a disk in removable disk"
right click my computer.
click manage
selest disk management
right click to drive-H
select change path 7 name of drive
change it to any letter except lettur used for your other drives
thats it it is done.
Dec 23, 2008 | IBM Iomega ZIP 750 (22P7099) External ZIP...
Iomega 100MB zip drive
i think it is damaged. because of the bad sectors . try to use third party recovery app
Jul 16, 2017 | Iomega 100MB IDE Black Zip Drive...
Computers & Internet Logo
170 people viewed this question
David Payne
David Payne
