Question about Refrigerators
When the fridge is turned on the freezer section works normally but the fridge section does not. All seals are fine but it is just not cooling in the fridge compartment
  • 52 Answers
Sounds like your coils may blocked with ice, preventing airflow to the fridge section. This can be caused by two things. The defrost timer isn't working; a bad timer or timer motor. Or, the defrost heater has burned out. A few checks with a volt/ohmmeter should narrow it down. The timer &timer motor are generally reasonably accessable in the back. The defrost heater is another story. You'll probably have to take some of the freezer panels off to get at it. The parts aren't that expensive but, if you can't do it yourself, labor might be pricey. With new fridges running $800 to $1000+ , if yours isn't too old it would be wise to fix it. good luck, John
Posted on Nov 07, 2008
My gold star three door gr403s fridge isnt staying cold in the fridge section only. the freezer is fine but the middle chiller section is also having a few issues. Im not able to replace is as Im a pe
You might check this link for details that are similar to your fridge issue. Likely you do not have cold air fanning to the bottom compartment hence not cool. I assume your seals work properly and that it is a fridge internal issue.
Refrigerator Repair Not cooling properly freezing up on the back panel...
Feb 13, 2015 | Refrigerators
I have a kitchenaid, KSRS25RSMS01, refrigerator and the freezer is fine and the fridge is not cooling. I have checked the evaporator and it has normal frost, and the fan is turning fine, but the air coming...
Your frig has the classic symptoms of a frig with a clogged or blocked vent between the
freezer section and the refrigerated section. This clog can occur due to (a) stuff in the freezer blocking the vent, or (b) ice in the freezer blocking the vent, or (c) both of the above.
The way a refrigerator works is it cools the freezer, and the warmest air in the freezer is vented out
to the refrigerator section. If this vent is blocked (and everything else is working), your refrigerator
just became a eye-level small freezer atop a well-insulated section of dangerously warm food.
May 13, 2011 | Refrigerators
I have a Kelvinator Opal Fridge/Freezer. The freezer is working fine but the food compartment wont cool. It used to run too cool and freeze stuff on the top shelf. The fridge seals are fine, the fan runs...
The vent from the freezer to the fridge can be blocked with frost and is preventing the flow of cool air to the fridge.
This can happen if there is frost build up due to failure of the auto defrost timer.
So please check on the fan section , remove panel and see if there is frost or block, if so check the timer Heater and the thermostat.
Jan 24, 2011 | Refrigerators
Fridge section not cooling properly
your evaporator iced up, defrost it, leave it off for 24 hours.Check defrost heater,timer, and the fan motor.
Apr 07, 2010 | Amana ABB1927DE Bottom Freezer...
Since defrosting my freezer my fridge does not appear to be working correctly. The thermostat is turned up full however the fridge is not cooling. The seal round the door is fine and there is no blockage...
So you manually defrosted your refrigerator and now the fresh food section is warmer than normal. Can you please send me the model number and your location in the world. Some models are totally impossible. I found related models but no parts listings yet. Could you have someone feel the compressor top to see if warm, cool or too hot to keep hand there. Sea Breeze
Mar 18, 2010 | Refrigerators
Hi, I have an LG refrigerator, the top freezer works fine but the fridge section has stopped cooling, I turned the unit off and next morning there was a large puddle of water on the floor, when I turned it...
When the fridge is not cooling that means the fan are not working or not working properly, need to replace or check if their is an ice bothering the fan to turn. ok
Feb 15, 2010 | Refrigerators
Freezer works great, but refrigeration section stopped working
Check the door seals on fridge and freezer to make sure there are NO leaks.
Try manually adjusting air flap that controls air from freezer to fridge, the flap may be frozen or the actuator that controls the flap may be faulty.
Aug 25, 2009 | Whirlpool GD5SHAX Side by Side...
Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Jan 18, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Admiral - GC2224GEKB
Does freezer cool like the cold food section? Did this suddenly happen, and frozen food began to thaw?  Most freezers control the cooling in the cold food section. The freezer must work fine before the cold food section will work fine. Let us know more, Thanks JT
Oct 24, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
59 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
