Question about Philips 36PT842H 36" TV
Power problem i dont know if this is the exact model that mine is, it looks really close, but its a 27 inch screen. but anyway i tried to turn my tv on one day, and it made the noise of it turning on, but then no picture nothing not even the little green light to tell me the tv is on, so i kept on trying and i woudlnt get anything not even the sound, so i looked at the power cord and noticed that the tv was sitting on the cord and had made little dents in them, but its nothing to serious so i dont think the cords are the problem. i have no idea whats wrong with this tv, any help would be much appreciated.
  • adamwestisgo Nov 07, 2008
    k thnx man ill have to try that tommorow, thanks for the help a bunch.
    Problem Solver:
  • 4 Answers
If you don't have any indicators working, you have probably lost your power supply. With no picture and no sound the chances are you have either lost the power supply or blown a fuse. If you remove the cover and look at the circuit board there is a fuse located near the rear of the chassis near where the power cord connects to the chassis. If the fuse is blown, it is advisable to replace your damaged power cord before replacing the fuse. The cord could have a short and this could create a fire. Be very careful when working on any television. Be sure it is unplugged for more than one day to allow the high voltage to decay from the picture tube. Do not touch the picture tube, it still may have some residual voltage and could shock you. If you replace the cord and fuse and still have the same problem, you will probably find that the high voltage transistor is bad and needs to be replaced.
Jerry
Posted on Nov 07, 2008
Black box taking up over 1/2 the screen.
caption box selection is on. disable caption
Jun 29, 2009 | JVC AV-27530 27" TV
Black screen on EVERY input/channel
Turn off the closed capition
Jun 19, 2009 | JVC AV-27530 27" TV
Philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Feb 28, 2009 | Televison & Video
JVC TV
It sounds like you may have the closed caption banner turned on. This is for text notifications that some stations use for messaging about such things as programming info, sports scores, or weather forcasts, and or etc...
Refer to the user manual of the TV set, or explore the menus to see how to turn off the closed captioning options.
Jerry G.
Jul 12, 2008 | JVC AV-27D302 27" TV
27 INCH OLEVIA LCD FLATSCREEN
Access the TV's menu by pressing the "menu" button on the remote. Look for "Captioning" or if not on the screen try "set-up" or "audio" all the while looking for "CC", "Caption" or "Closed Caption".
When you find it, turn it off.
Apr 06, 2008 | Televison & Video
Tv PROBLEM
The black box your are seeing on the screen is the box to display text. It is listed under your "cc" closed captioning setting as T1, T2 etc. Go into your closed captioning and shut off the text. You can still leave closed captioning on or off. The text system was never really used but they put it on all of the TV's.
Feb 05, 2008 | JVC AV-27D303 27" TV
Haier 27 inch Flat screen Model: HFT27R11 Blank screen power led flashing with thump sound
seriously its a difficult problem, well sometimes the system control needs a heat-up by resoldering it. or caused by the flyback and the horizontal transistor. reply me if the problem persist. ^.^
Jan 22, 2008 | Haier HTF27R11 27" TV
Sanyo TV stretches outwards and shakes
If the picture is closing (top to bottom) and goes back to normal when you hit it you probably have a bad solder connection on IC501 (location number) the vertical deflection IC on a metal heat sink. If you mean outwards as in side to side as it looks in the picture, I don't know specifically where to solder but get a magnifying glass and look for suspected bad solder connections. Look for the word width if it is there. It is good that you a confident in soldering.
Dec 27, 2007 | Sanyo DS27910 27" TV
Wont power on
I also have an Astar TV which turns on and flashes the Astar logo before the screen shuts down (Green power light stays on). From what i understand this is generally caused by low grade parts and to much heat. I dont know if you have gotten close to the TV while it is running but it gets extremely hot. The main issus with this is it causes the Capacitors to blow. there are about 20 of them and they generally sell for about $1.25 - $6 each online. If you have any experience soldering i have read about other people performing the fix themselves. I dont so i am currently looking into the cost to have them replaced by a professional. I will try and post what i find out.
Nov 07, 2007 | Astar LTV-2701 27 in. HD-Ready LCD...
Magnavox big screen will not power on button blinks but wont turn on
Need model number really, but sounds like a bad SSB module(small signal board). It would have to be replaced and depending on the model they can be expensive.
Sep 06, 2007 | Televison & Video
Philips 36PT842H 36" TV Logo
69 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
