Question about Jenn-Air Kitchen Ranges
I have a Jenn-air model # JGS8850ADS. An F3 - 1 came up. The temperature sensor was changed and it happened again on the same day that it was changed
  • Anonymous Mar 28, 2014
    oven does not light
    Sergeant:
  • 409 Answers
this is an overtemperature error that happens during self-clean. i would recommend ohming out the sensor and the harness and if they check out okay, replace the oven control itself.
Posted on Nov 07, 2008
F-3 signal on Jenn-Air SVE47600, grill-range, self-cleaning convection oven
The F3 means there is something wrong in the sensor circuit, sensor/wiring/clock. F3 Problem: Shorted or open oven temperature sensor (RTD): Solution: Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Jan 06, 2008 | Ovens
Error code F1
F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
Jan 11, 2011 | Jenn-Air JGS8850ADS Gas Kitchen Range
Code F1
Familiar F3-1 error on Jennair #JGS8850ADS. Changed Control Panel, igniter, Sensor, thought problem was solved. After 1 week F3-1 error came back after oven is on for about 20 minutes and shuts the...
F3
or
F4
(RTD) Check sensor harness and harness connection
wiring is ok.
Dec 30, 2010 | Jenn-Air JGS8750 Gas Kitchen Range
Hi ,I have model jgs8850ads,it takes along time to preheat,about 40 min. what could this be? please respond.
is this a duel fuel with an electric oven..... the bake is the bottom and the broil is the top both cycle on and off to preheat the oven.... if ur lower bake element is burnt out then u woould expereicnce the problem u stated..... if u have a gas oven then ur ignitor or glow bar is probably burnt out....... either way it sounds like your bake element or bake ignitor has failed
Jan 31, 2010 | Jenn-Air JGS8850ADS Gas Kitchen Range
I GET AN F1-C ERROR CODE ON MY JENN-AIR RANGE, MODEL JGS8850ADS. WHAT DOES THIS CODE MEAN?
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
$#WED
Nov 30, 2009 | Jenn-Air JGS8850ADS Gas Kitchen Range
F1-8
Problem fixed!!! Lowes is giving us a new stove!!!
Oct 08, 2009 | Jenn-Air JGS8850ADS Gas Kitchen Range
Back Left Burner clicks
Hi!
Please use a blower or hair dryer and blow out any moisture on the back burner knob. This happens when moisture enters the knob area. Moisture shorts the connections and thus, its clicking continuosly.
Also, check for the electrical connections.
Please ask for further clarifications.
Please rate this solution.
Thanks
Rylee
Mar 02, 2009 | Jenn-Air JGS8850ADS Gas Kitchen Range
Kitchen Ranges Logo
184 people viewed this question
Top Jenn-Air Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Craig Butler
Craig Butler
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
