Toshiba CZ27V51 27" TV
Problem for Toshiba CZ27V51 27" TV
COld Solder/Short
By Guitar1 on Oct 15, 2006
Here is a strange one. If I lean the whole TV forward, I have no problems. When I sit it correctly, the picture and sound shut off, and the LED blinks. It's probably a cold solder. The silver box that the cable input plugs into seems to be the issue. What is this silver box (It appears to be fuses?), and has anyone heard of this? Shaking the cable itself does no good, it only works if I lean it forward, which takes pressure off of the chassis. The tv is not old, and the picture and sound are fantastic. It's never seen hard use/abuse, and has never been moved since it was placed in it's current location. I'm good with solder, and a mechanic, so small tool use is not a problem, I just don't know what not to touch for safety reasons. Thanks.
Same Problem
Dec 02, 2007
-   Horizontal is going out on TV. Can this be fixed or do we need to spend the money to get a new TV.-   Guest
Best Solution
posted on Oct 16, 2006
Very Helpful)
Coil
Rank: Wiz
Rating: 81%, 300 votes
Before taking anything apart, if the TV is on legs, try propping it up in the normal position so the legs are just off the floor. If this does nothing it will show it is not pressure distorting the cabinet.
If it does the movement of the cabinet must be shifting something on a PCB, such as a dry joint or a plug/socket.
In modern sets there is no chassis; the Printed Circuit Boards are usually clipped and screwed directly onto projections inside the cabinet.
The dangerous high voltages are usually well insulated and confined to one PCB.
A PCB for control is usually in the bottom of the cabinet, and this is the one you should look at. It only has low safe voltage on it.
The mains lead goes to the PCB which also has high voltages for the power supply; if this is in the bottom of the cabinet also then suspect a fault on it, but beware you really need an expert.
Was this helpful?
Yes
No
Solution #2
Very Helpful)
jomaru
Rank: Guru  Toshiba Expert
Rating: 87%, 492 votes
The silver box where the cable plugs into is the TUNER,there are no fuses in there and the problem is not likely to be there,the loose conection could be anywhere but you have a few places to check,with the tv unplug from the wall you can safely check for loose conections in the power supply area and around the output transistor including the areas of the horizontal drive circuit and output transformer,those are the areas most likely to the symptoms you have but you can also check the edges of the chassis for a broken or crack board.Let Us know if you need more help.Be careful when you are checking for conections.
Comments:
Oct 16, 2006
- Your rating is also important.
Was this helpful?
Yes
No
Solution #3
posted on Oct 22, 2006
Not Rated)
Guitar1
Rank: Apprentice
Rating: 0%, 0 votes
Ok, so it's the tuner. That makes perfect sense. With the back off, nothing seems loose. The PCB is basically to the right, under and behind the CRT. I had it working for about two hours, then it pulled it's old tricks. Should I pull the PCB, or do you think tapping with an insulated screwdriver on various components would do the trick? I'll be careful not to short a connection. I don't really like poking around in an unfamiliar region, but I can R & R any component, no matter how small the solder. I've fixed power supplies for my studio, and I've done audio gear. It's the high voltage that worries me. I don't want to smoke a component. Supporting it other than on it's base is a good idea. I'll suspend it from it's sides and see if "chassis" flex is what causes it, or if it's directly related to a component moving when it's level, and back again when it's leaned forward. You are correct that the PCB is mounted directly to the base.Thanks for the really good info.I appreciate the help.
Was this helpful?
Yes
No
Popular Solutions for Toshiba CZ27V51 27" TV
Questions and Unsolved Problems for Toshiba CZ27V51 27" TV
Do you recommend Toshiba CZ27V51 27" TV?
Answer
Answer
cant change volume or put tv on or off with the remote from charter
Answer
my toshiba cz27v51 goes black with a green line going across the middle. picture would eventually... (More)
Answer
Dim picture....contrast is jacked all the way up as well as the brightness in the menu. I have... (More)
Answer
This happens randomly, about once every 6-8 hours...Yesterday did same, but screen and sound quit. ... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Standard... Experts
Top TV Repairmen
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
