Question about Refrigerators
Fisher Paykel fridge door handle loose
4 week old fridge, we love it, but the fridge handle is loose and getting worse. it's a fridge on top, freezer on bottom.  i can feel small holes along the bottom of the handles where i assume either small set screw or allen screws are but i can't see in there.
can someone tell me how to tighten the handle? i don't want to call for service just for this.
It's a Fisher Paykel E522BRXU EZKleen Stainless Steel 17.6 cu ft
  • JK Scheinberg Nov 12, 2008
    It was easily fixed using a 2.5mm (or 3mm I can't remember) hex wrench, long enough to fix up in there.
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
  • 4 more comments
  • kmacneill Jul 18, 2010
    Unfortunately, we have this model - which we bought after my parents recommended it to us since they loved their so much. 4 weeks ago our fridge handle broke right off - 2 weeks later, my parents' handle broke off as well. My father called the manufacturer in NZ and they are currently doing an "investigation". Seems to me the whole door will need replacing since it broke off and left tiny parts inside the door.
  • erick967 Jan 15, 2011
    Didi you get any response on this. Same thing has happened to us.
  • cluttergone Apr 08, 2011
    Would love to know what happened because the same thing has happened to our fridge and F & P refuse to replace it. Its definitely a design fault or rather deliberate design to keep the money from spare parts coming in
  • socalrider31 Sep 02, 2011
    Same thing happened to me!! My frig (upper door) handle is now completely detached from the door on the top like the screw fell out of the little hole. I cannot find that screw and I don't know what to do. It looks as if you can just place another screw in to secure from the bottom hole but i cannot find the screw in any stores or online. I called the Fisher & Paykel parts wherehouse and the screws they said I need are the wrong ones!! They said they do not have any other types of screws for the door handles.
    This frig has caused many problems.....1st the handle, then the ice maker, then the water dispenser, now the whole digital panel is out. This morning, I opened the freezer and ice is EVERYWHERE!! As if there was a major water leak inside the freezer and then froze. This frig is only 2 years old and never misused.
  • DJAM
    DJAM May 06, 2014
    Same problem with our fridge door handle. There is a hole on the underside of the door handle, (both top and bottom). The problem is easily fixed by using a 2.5mm hex allen key.
  • Scott C
    Scott C Jan 10, 2017
    My fridge/freezer door handles have a small hole on the underside. The top hole is a bit harder to tighten because the handle gets in the way, but the hole on the bottom of the handle is pretty easy. The hole opening is much bigger than allen key you need. Insert a 2.5mm hex allen key up into the middle of the opening. Simple once you know what size to use.
Fisher & paykel active smart fridge not keeping cold
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 28, 2012 | Fisher and Paykel Active Smart E522B...
Hi,I bought a fisher and paykel refrigerator E450r model for over 2 yrs now. Once you open the door, you can hear a beep sound. You can also hear this sound while the door is open and even when the door is...
I unfortunately bought the F & P 450R upright fridge with the matching freezer, recommended to us by Winnings. Expensive and possibly the worst ever appliance purchase I have made. The door handle design is pathetic and once again today, has come apart. The fridge constantly freezes up which then affects the fan, which in turn stops the fridge getting cold. To date, we have had the F & P service out, he first said he needed to get it back to the factory and we'd be up for about $900. After we advised that wasn't happening, he replaced the control unit, which had didn't clear the problem (although still cost me $300). Having no confidence in F & P, we contacted a fridge mechanic with a good name. He closed his eyes when he saw the brand and mumbled, Kiwi's revenge. Long story short, over 3 visits he, adjusted the inadequate door sensor, refitted a temp sensor which had broken from its poorly designed plastic holder, replaced all the sensors and in the end said sorry, but you have bought a lemon. I now have a choice of buying a new fridge which wont match the freezer, buy a new fridge and freezer, even though the freezer is fine, or continue with what we do now, turn the fridge off every other day for 4 or 5 hours to defrost it. My solution, do not go near Fisher and Paykel, the service and machines are just not up to it.
May 31, 2011 | Fisher and Paykel Refrigerators
I have a fisher and paykel E522B refridgerator and the door handle is coming off. I need to know how the door handle is attached so I can retighten it
In most case the screws are hidden, some of the handles have a cover that slides up or down, and the others have a little hole cover that have to be popped out and then you can access the screw
Dec 13, 2009 | Fisher and Paykel E522B Stainless Steel...
Door handle are loose
get a 2.5 allen wrench and tighten the bottom side of the handle
Nov 15, 2009 | Fisher and Paykel RF201ADUX Bottom Freezer...
Outside door handle loose - how do I remove inside panel to tighten handle?
I had the same problem with this model. Bluntcow is correct, 2.5mm hex screw at the bottom of the handles (the top one is a fair way in).
May 31, 2009 | Fisher and Paykel E522B Stainless Steel...
Top of fridge warm but bottom freezer working ok
Dear customer,
Please perform the following checks
Please rate this,. Thanks for using FIXYA.
Dec 16, 2008 | Fisher and Paykel Fisher Paykel 21768 -...
Refrigerators Logo
3,882 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
