Blows fuse Has a dead short blows fuse everytime. I have an RCA television with Chassis #CTC197AH with the same problem. When connected it blow the fuse (5 Amp) I have replace the thermistor and it still blows the fuse. I cannot be sure I used the right thermistor. Do you have a part number for this thermistor????
    Sergeant:
  • 280 Answers
You may want to check the regulator IC. RCA had a lot of shorted regs
Posted on Nov 07, 2008
How to repair engine wiring harness; asd fuse blows asap everytime
Google this asd problem, there is a lot of information on this problem. I would look for a short but would not want to remove the complete harness.. If you do this take pictures of the harness and all connections before you start.
May 18, 2014 | 2004 Chrysler Pacifica
My 89 civic lx keeps blowing the battery fuse everytime I connect the battery
My first guess would be a short inside the alternator, so if you have replaced it, look for a shorted wire in the harness.
Disconnect the wires from the alternator and everything connected to the battery, then connect one at a time until the fuse blows.
Could be a problem with the starter solenoid too.
Jul 03, 2012 | 1989 Honda Civic
Fuse blows everytime i turn on A/C in 99 oldsmobile silhouette
CHeck wires in short, ground connections or bad blower motor.
Mar 27, 2012 | 1999 Jeep Cherokee
I have a 2000 gmc yukon denali and everytime i push my ciggarete lighter in it blows the fuse and my radio also stops working
Replace the cigarette lighter. Parts houses have the right one for your Yukon.
The lighter itself shorts out so when you push it in it creates an immediate dead short . Fuse Blows.
Thanks for using Fix Ya.
Wayne
Mar 18, 2011 | GMC Yukon Denali Cars & Trucks
BLOWING FUSES
Ist of all is 10 amp the proper size?
2nd if you bypass and whatever you are replacing the fuse with, is it warm, or hot to the touch?
If it is you have a direct short in you have a direct short in the electrical system. Check for bare wires,wires touching the motor or chassis that don't have a connector.
Hope this is a FixYa
Kurt
Mar 20, 2009 | Garden
Tv dead
no problem
replace by same number.
but remember before you replace check the following.
  1. check for normal output from power supply.
  2. check components connected to flyback transformer.like capacitors & diodes.
  3. check for print short.
  4. while replacing h/output be careful to check heat sink compound & mica sheet normal.
  5. put on the set
  6. if still it blows then flyback transformer is faulty.
  7. hope this will help.
  8. good luck.
Oct 11, 2007 | RCA HD56W58 56" TV
RCA big screen tv
whenever fuse blows every time it is the indication of short circuit in tv. so please do not put fuse unless you know the cause of blowing fuse. these are the reasons of blowing fuse. 1 main filter cap.short. 2 rectifier diode short. 3 swithing transistor short 4 horizontal output transistor short 5 caps & diodes connected to flyback transformer short. 6 print short. 7 at last if every thing ok then flyback transformer defective. hope this will help. if you are not a tech person call skilled tech to fix it. good luck
Sep 24, 2007 | RCA P60828 TV
Blows fuse
If you disconnect the degaussing coil and the set plays fine, it means one of 2 things is wrong. The degaussing thermistor could be shorted internally. I have seen this happen a few times on those degaussing thermistors that are in the little black boxes with 3 legs. Those boxes actually have 2 thermistors in them, one to do the actual degaussing and another connected directly across the AC to act as a heater for the degaussing thermistor. One of those thermistors could have "flashed over", which would blow the fuse the instant the set it turned on. The only other thing would be the wrong size main fuse. Without a degaussing coil the set probably draws about one amp, but the surge at turn-on with a degaussing coil could be as high as 4 amps. If you have the correct fuse installed and it blows at turn-on, replace the degaussing thermistor.
Aug 14, 2007 | Emerson EWC20D4 Combo
RCA CHASSIS CTC195K BLOWA SCR
make sure that the scr has adequate insulation. I have run into this problem before several times, and it always comes back to the scr and heatsink. check for shorts before you plug it in. unless you have an isolation transformer, do not hook up ac powered equipment to chassis ground, as this will blow your transistor again. use dc poweered volt-ohm meter.
Jul 31, 2007 | RCA HD61LPW42 61" Rear Projection HDTV
Fuse blows.
Please check for shorted diode or condenser at power section.
May 29, 2006 | Panasonic CT-27G14 27" TV
Televison & Video Logo
136 people viewed this question
Top Televison & Video Experts
Electro Med Services...
