Question about Sony KV-32XBR48 32" TV
Sony kv-32xbr48 tv won't turn on
My tv is ten yrs old. it would not turn on one day. I took the back cover off and the fuse to the power supply is good. What do I check next?
    Problem Solver:
  • 4 Answers
You need to check the horizontal drive transistor. This circuit provides the high voltage and other voltages needed for the television.
Jerry
Posted on Nov 07, 2008
No picture on KV-32XBR48
check for a busted screen back light .
Mar 30, 2013 | Sony KV-32XBR48 32" TV
No Power Problem with KV-27s15 Sony TV
Barry, remove the back cover by removing the screws with an arrow next to them. The fuse is located on the left side as viewed from the back, where the power cord connects to the circuit board.
Aug 09, 2009 | Sony KV-27S15 27" TV
36xbr800 sometimrs will turn on sometimes won't
it may be open contact on the flyback or
bad solder in standby power supply
Give it a smack open hand on the side
or better yet if you can have someone press
the power button as you rock it back and forth
this can tell you if its bad solder some times.
Jun 23, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Standby/stereo light blinking no picture or sound
My picture would go out after several minutes but I still had sound. I took the rear cover off and blew all the dust off with compresed air.I did this for a few times over several days nothing happened.I also took off the rear circuit board that attaches to the tube with a round pin socket and blew that with compressed air and put it back on. The TV has now worked for two days without the picture going out. It worked!!!!!!!!!!!!!! My TV is 9 years old.
Aug 31, 2008 | Sony KV-36FS100 36" TV
Power light is blinking TV does not turn on
the power is blinking because there is a deffective parts... the supply that makes oscillation of tv has been cut off... either the horizontal transistor is open or the resistor from the abl change its value...if you have knowledge with the parts maybe you can try... only the qualified servicemen can repair the problems...
Aug 29, 2008 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Where are the fuses in this tv
That is the only fuse. Its purpose is not so much to protect the TV parts but to establish the UL rating by protecting against overcurrents and fire.
Next thing to check is the B+ voltage (125 to 160Vdc) on the big electrolytic capacitor near the power entry. No volts here tells you the problem is before this in the power supply parts. After here means the high-voltage supply.
Check that and get backl to us.
Jan 31, 2008 | Sony KV-32XBR48 32" TV
TV died
Death can occur from a simple power supply fuse to the anything inside. Now if you are confident that you can try to fix it on your own, start from the fuses, and check for possible shorted components if the fuse is blown.
Jan 30, 2008 | Sony KV-32XBR48 32" TV
SONY WEGA KV27FS120 WON'T TURN ON, LED BLINKS A FEW TIMES
I have a SONY WEGA 3 years old KV-32XL90E and have the same problem the Stand By/Timer light blinks 16 TIMES, pauses and then does it again.The sound is but no picture.
Nov 13, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony KV-32S40 32" TV problem
intermittent problems can usuall be liked to bad solder connections. And sony typically has some that will develop after a few years in the power supply. so check for bad sodler connections throught the main board & give a close look to the power supply & check you work after to make sure you have no shorted pins. good luck.
Dec 27, 2006 | Sony KV-32S40 32" TV
Televison & Video Logo
136 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
