Question about Sony STR-DE475 Receiver
SONY RECEIVER STR-DE475
ALL COMPONENTS WORK FINE THROUGH THE SPEAKERS, BUT WHEN I SWITCH TO THE TUNER I GET A HUMMING NOISE AND THE RADIO STATION IS FAINT, THIS PROBLEM STARTED INSTANTLY THE RECEIVER HAD BEEN WORKING FINE UNTIL THE PROBLEM OCCURED
  • hutchdm Jan 08, 2009
    same problem. Out of the blue I now get a loud buzz rather than the radio. The radio can be heard in the background. It does not seem like a reception issue as it is the same volume on any station - very annoying.
SOURCE: No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Posted on Feb 10, 2009
dunnbiker
  • 8546 Answers
SOURCE: Centre speaker stops functioning
Is the audio for the center channel driven by its own amp? No other channels on it or affected?
Assuming you're not cranking it up to "11" to rattle the walls...
I think what you're hearing is the protection relay dropping out - removing power from the output stages of the amp when the amp thinks something is amiss. If it turns on OK after being OFF for a while and repeats the loop you probably have a heat issue.
A solid click OFF that is not resettable would possibly be a short in the speaker path - shorted speaker wire or speaker.
Check the amp to see if it was hot to the touch or getting warmer up to the point it clicked off.
Is it ventilated properly with no heat-producing components below it? Clean out its vents and make sure it can breath. If it has a fan make sure it's working and has good airflow.
Posted on Apr 02, 2009
SOURCE: working the Sony STR-DE475 5.1 Channels Receiver
It has a dedicated sub out. you need a phono connection on one end for the amp and the other end must have a compatable connection to your sub.
You will need a phono connection to the amp from your TV. You can utilise a scart lead that has phono outputs however a TV with audio outs (the red and white leads) is the default option.
Posted on Jun 02, 2009
  • 82 Answers
SOURCE: i have a sony STR-DE475 and the surround speakers
have you checked ur cables and connectors? check them with the multimeter and confirm
Posted on Jul 09, 2009
dunnbiker
  • 8546 Answers
SOURCE: Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Posted on Dec 29, 2009
Str-de985 humming noise only when using FM tuner. Everything else works fine with no humming noise
Have you got a FM Antena hook up to it for the FM ,Sations, If not that could be causeing it to hum.
Dec 06, 2012 | Sony STR-DE985 Receiver
Right front channel not working
try to check balance adjustment if working.
Apr 16, 2010 | Sony STR-DE475 Receiver
My Sony STR-DG500 wont turn on just clicks once and nothing.
Sounds like faulty psu (pwer suply unit) Amp is going into protection mode. Disconnected all speaker and av wires (only power) turn up volume and see if it stays on. If not psu, sounboard or volume function faulty. If on, connect one speaker L or R. Go to tuner mode to tuned radio station an listen for sounds. If on, connect speakers and av cables one by one and test each one on its own until amp switches off, Investigate from there were problem is. Make sure speakerwires is not shorting out.
Aug 29, 2009 | Sony STR-DG500 Receiver
That didnt help rsgardener! Maybe some other tips please?
Jul 14, 2009 | Sony STR-DE475 Receiver
I have a sony STR-DE475 and the surround speakers have stopped working.
Jul 08, 2009 | Sony STR-DE475 Receiver
Mar 21, 2009 | Sony STR-DE475 Receiver
Sub not working with amp
Connect a sub cable to the amps sub OUTPUT then to the sub input turn the volume up half way on the sub then go to the amp setup menu and make sure the sub is switched on then set the cross over to suit your speakers,if your not sure set to 80hrtz.
Hope this helps.
CABLE GUY.
Feb 24, 2009 | Sony STR-DE475 Receiver
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
Sony STR-DE475 Receiver Logo
335 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
