Question about Toshiba e-STUDIO 16 Printer
NETWORK Please help, how do you network the e studio copier with the rest of the 4 computers in the office? Thanks for your guidance in advance.
  • ENG_HOSAMPAD Apr 24, 2009
    NETWORK
  • JDTec
    JDTec May 11, 2010
    What model of eStudio?
    Scholar:
  • 78 Answers
Does your copier have a Network Interface Card ( NIC ) installed in the printer? If not, and if the copier has the Parallel port option installed, you can purchase an HP JetDirect EX network print server, and then connect it to the printer parallel port, and then into your ethernet network. This option is very effective, and a very "Green" solution vs using a computer as a print server for example, or the high cost of adding a Toshiba ethernet option if not already installed.
Posted on Nov 19, 2008
Hi All, I am trying to connect Toshiba e-studio 207 via local network but unable to make it work.
Best way to Check is getca status page from your printer ,check the IP address that’s been assigned to your printer via dhcp from the router ,then just add the printer manually by creating a tcpip port with that op address
Oct 28, 2017 | Toshiba e-Studio 232 Black and White...
Is there a way to configure our e-studio copier as wireless on a network?
There is one way that i know of, you will have to purchase a wireless router(switch). You will then have to setup the wireless router and plug the machine into the router and make sure that the that the rest of the network can see the router.
As soon as the network can see the router you will have to setup the machine.
Assigne the machine with a IP address, and load the printer driver,share the printer and setup the rest of the computers that they can print that should sort you out.if you do not come right please feel free to let me know.
Apr 08, 2011 | Toshiba e-Studio 350 Copier
Please help me.. How can I open a toshiba e-studio 850 copier in order to clean the fuser film.. Or just how can i remove the toner cartige holder.. Many thanks in advance
1. Open the front cover & toner cover
2. Remove the right hand side blue cover ( 2 screws )
3. On top of toner unit, there is a screw with a bracket, remove it.
4. Disconnect the toner unit connector, lift down the pin behind the connector socket and take up the whole toner unit.
* Remember to take out toner 1st
Mar 10, 2011 | Toshiba E-STUDIO 850 Copier
We changed the toner in our E Studio 3511 and now it keeps saying network initializing? Can you help?
Hi how are you hope you are ell
This is jack jack_pak@hotmail.com
Dear dont wary after some time network initializing is finished automaticaly.
PLEASE VOTE ME.
Thanks
Best Regards,
Apr 19, 2010 | Toshiba e-Studio 350 Copier
HOW TO RESET NETWORK INITIALIZING LIGHT TOSHIBA E-STUDIO 350 COPIER
Press User Functions>Admin>then enter 123456 (password) then go to the TCP/IP section and clear all the IP addresse/s out of the fields then hit enter.
Press Back>Back>Copy>User Functions>Shutdown. then turn the machine back on.
Oct 13, 2009 | Toshiba e-Studio 350 Copier
HP Office Pro K8600 not working on a network with vista
Sir,
Click this link to solve your problem
Thanks Good Luck
Aug 21, 2009 | HP OfficeJet Pro K8600 Printer
Error 1335
Method 2: Change the memory settings for installation To change the memory settings for installation, follow these steps:
  1. Click Start, and then click Run.
  2. In the Open box, type msconfig, and then click OK.
  3. On the BOOT.INI tab, click Advanced Options.
  4. In the BOOT.INI Advanced Options dialog box, select the /MAXMEM= check box, and then change the setting to 256 (or lower if your computer has less RAM).
  5. Click OK to close the BOOT.INI Advanced Options dialog box.
  6. In the System Configuration Utility dialog box, click Apply.
  7. Click OK to close the System Configuration Utility dialog box.
  8. Click Restart to the following message: You must restart your computer for some of the changes made by System Configuration to take effect.
  9. After you restart your computer, install Office as a Complete Install.
  10. After you install Microsoft Office, follow steps 1 through 8 to clear the /MAXMEM= check box.
By xIN3N
May 21, 2009 | Sun Java Studio Standard 5 (SSJI9501TL9M)...
Crc failed in Enterprise.ww\enterww.cab
Based on my experience there are many reasons that this issue may occur. I
suggest you try the following suggestions:
* Suggestion 1: Clear Temp folders
1. Click Start>Programs>Accessories>Disk Cleanup
2. Clear your Temporary Internet files and temp files.
3. Restart the PC.
4. Copy your Office 2007 files and folders to a local folder.
5. Double click on the Setup.exe to start the install process.
* Suggestion 2: Check the Environment Variables
I remember I have resolved some similar issues that the users report Office
2007 has failed to install. I have figured out this is caused by the wrong
configuration of the user variables. To check it, please follow the steps
below:
1. Right click on Computer, and choose Properties
2. In the Tasks list that appears on the left, click Advanced system
settings.
3. Click Advanced tab, click Environment Variables.
4. Under User variables for user name, check if TEMP is configured as the
following value: "%USERPROFILE%\AppData\Local\Temp"
* Suggestion 3: Install under Vista safe mode
Please try to install Office 2007 under Vista safe mode:
1. Restart Windows.
2. At the boot sequence, long press F8 key to invoke startup menu.
3. Choose Safe Mode with network connection on the menu and press Enter.
4. After Windows starts in this mode, install Office 2007 again and see the
result.
Feb 04, 2009 | Microsoft Office Professional 2007 Full...
Toshiba e-STUDIO 16 Printer Logo
330 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
