Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Dyson dc07 animal bagless
My vacume suction good when used upright but when I pull the wand hose out to use with attachments the motor sounds louder and the wand loses suction. I also cannot get the wand to go back down all the way in the hose.
  • dysprosi Nov 15, 2008
    Mine acts like it draws too much suction and collapses the hose and then won't pick up anything. I have to turn it off before it will uncollapse so I can put the hose up.
    Problem Solver:
  • 18 Answers
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Posted on Jan 01, 2009
Dyson 07 wand cap removal
http://www.dyson.com/support/dc17/dc17-animal/diagnosis-root-menu/dc17filterwashvid/flo-dc17-wand-suction/flo-dc17-remove-the-wand-from-hose - This should help you!
Aug 05, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson Animal bagless vacum will not return and lock in the upright postion and the suction is now only working in the wand.
I'm sorry to hear you're having difficulties with your DC07. From what you've described, it sounds as if the valve carriage needs repositioning. This is easy to do - please follow the steps shown in the video below.
If you have any further queries about using or maintaining your Dyson, please get in touch with us directly by calling free on 0800 2980298 (UK), or 1866MYDYSON (US).
Kind regards,
Jack
Dyson Online Customer Support
Oct 15, 2011 | Dyson DC07 Animal Bagless Upright Cyclonic...
My Dyson DC07 vacuum works on the floors, but when I pull out the extension wand the coiled hose attached to the wand collapses and no suction goes through the hose?
Hi there, it sounds like you have a blockage in the hose. I have made a video to show you how to get the hose off and linked it to this answer. It is possible to split the hose in places trying to get the blockage out so try not to be rough. If you do damage the hose you will need to buy a new DC07 hose it is a waste of time trying to repair. If this was a helpful answer please take a moment to rate it or leave a testimonial.
Feb 20, 2011 | Dyson DCO7 Animal Bagless Upright Cyclonic...
How do you remove the hose to ck for blockage?
If the hose collapses and there is no suction, that is a sure sign of a clog. The clog will be on the opposite side of the collapsing hose from the motor. Good luck.
Mar 27, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I just bought a used Dyson DC07. Works good but
Hi its Darran at Dyson.
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Dyson Customer Service
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 bagless - upright mode v poor suction, wand mode ok
From your description of the problem, it sounds as though the bleed valve is activating which only happens when there is a blockage.
We would recommend following the full blockage through as outlined in your user guide or in the Support section on our website at www.dyson.com.
Kind regards
Darran
Jan 11, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson hose looses suction
You have a blockage in the wand. Stand behind the machine and:
1) Remove the u-bend which is located NEXT to the right-hand side wheel, NOT above it. It connects from the bottom of the long gray hose to next to the right-hand side wheel. It is attached to the machine with a rectangular-shaped clip - push the clip and pull the pipe down.
2) Look through the wand if you can (DC07 wand is bent) - if you can't see the ground you have a blockage in either the hose or the wand
3) Remove the hose and separate it from the wand - hold the wand up into the air and look through it - if you can't see light coming through the other end, there is a blockage in the wand. Use a long object like a stick or a metal hanger to remove the blockage.
4) If the wand is clear, stretch the hose out and look for dark spots - those are the blockages. Again use a long object to remove the blockage - be careful not to damage the hose, you don't want to buy a new one.
Jun 29, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson Animal hose collapses when using attachment hose
You have a clog in either your hose or your wand. You need to take off the wand and hose and inspect them.
Nov 15, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
448 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
