Question about Panasonic PT-53WX42 53" Rear Projection Television
Hey jomaru, question about ic
I have located some conv. IC amps to fit my tv at Electroix online. I have STK 392-110 in my tv. At the top right corner they have another number. One IC has B2F17 on it and the other has B2F18 on it. What are these numbers and do they make a differance in what you are getting. Should the ones I order have that number? I know you said to wait but this thing is driving me crazy. I cant hardly watch it its so bad. They only cost $5.99 a piece at this sight so I figured it is worth a shot. Other sights have them for 29.99 a piece. Is there any differance? What should I look for? Also there are 3, 4 wire plugs that plug into the board next to the IC's. Each one goes to a differant lamp. I am assuming thats the convergence wires from the board. When I unplug the one to the blue lamp the image straightens its self out. Its not a pincushion anymore. It is straight and flat like the others. When i plug it back in it screws up again. And I didnt tell you before when I go into my convergence menu the blue + are crooked and sideways. Its like they are twisted. They would align in a million years. Thought I would tell you that just to givr a little more info on it, incase that is a sign of somthing else. Sorry I bug the hell out of you just want it fixed and dont want to pay someone 3 or 400 bucks to fix it. Thanx for all your help!!
    President:
  • 3,130 Answers
Just an FYI, those numbers are Date codes. They are differant for almost every manufacturer.
Posted on Oct 16, 2006
    Sergeant:
  • 337 Answers
Hello,The important number are the STK numbers,the others numbers mean something but not to Us,some parts are inexpensive because they are not originals ,they are copies and they work but not as good,you should get the parts from www.partstore.com,give them a call and see how much they want for them,I heard they have the good ones,maybe a little more but worthed.I am glad I can can help you ,just let me know how it goes.
  • Omar Urrutia
    Omar Urrutia Oct 16, 2006
    Your rating is important to me.
Repair of SONY Music system Model MHC-VX901 for Push Power Protect code+ India
Its stk ic problem. Change stk ic. Purchase from online china website and change stk ic no 412750
Jul 16, 2017 | Sony Audio Players & Recorders
Letters and numbers are 3d and curved picture
Hello
red, green, and blue lines curve across the top of tv is cause by defective convergence STK IC or you have open resistor at convergence section. if you have defective RGB Color vertical ramp probably you have defective STK IC..
Angel
Thanks...
Aug 02, 2009 | RCA D52W23 52" HDTV CRT TV
STK IC 392-110 Chips
am having stk 4392 amp board 2 channel, i want to change this two channel in to one channel. what modofication should i do
Dec 02, 2008 | Toshiba 42H81 42" Rear Projection...
Blinking colors
there is a stk ic in the tv.which is located on the main board of the tv.that stk ic has gone faulty so u r getting this problem. u can get this new stk ic for replacement at  radioshack websites.
Dec 01, 2008 | Toshiba Televison & Video
Bow at top and bottom of screen
Your one and only problem is a bad convergence Amp board. Changing it will fix your set. You can contact http://www.interactiverepair.com for step by step assistant with installation of this board.
List price $100
Part Number: BP95-00142P
Hope this may help;
Regards,
VOTIT
Aug 04, 2008 | Samsung HCN653W 65" Rear Projection...
SONY GREEN CONV OUT BLUE/GREEN OK,SONY KP-65WV600
Red,blue and green each have an amplifier IC--Stk392-560 x 2
Replace both IC's for reliable repair.Also,check  fuses,location sometimes ps5003-5008. fuse value 3.15 amp. ......T.
Oct 22, 2007 | Sony KP-57WS500 57" Rear Projection...
Tv won't turn on
Your problem could be the Convergence board is loading down the power supplies and will not let the TV set come on, or the power/deflection board, part number AA94-08574A, or the STR type regulator IC, part number AA13-00105A. If you locate the convergence board, unplug the connectors, and see if the set will come on. if the set does come on, replace both of the STK convergence IC's at once. The part numbers for those IC's are STK392-40. You can get the original replacement IC's from MCM electronics for about 15 to 16 bucks a piece. Do not use the less expensive STK IC's as they are not the same. the replacement IC's should have the name of SANYO printed right on the face of the IC's. Good Luck
Jul 22, 2007 | Samsung HCM4215W 42" Rear Projection...
Buckshot again no improvement
the 999 ohm is probably the bad one thats high for a conv ckt. also i would use the amps the tv calls for that upgrade stuff does not always work out like you think it should.
Apr 21, 2007 | Zenith IQZ60Z97D 60 in. Rear Projection...
Sony KP-43HT20 ghosting effect.
may have bad convergence amps stk392-560 board location Ic8001 Ic8002 or the dcu unit is bad or the alignment drifted off and it needs service adjustments made to it.
Dec 28, 2006 | Sony KP-43HT20 43" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
27 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
