Pioneer VSX-454 Receiver
Problem for Pioneer VSX-454 Receiver
Multiple speakers in same outlet
By Dash on Oct 15, 2006
Is it ok to hook up two sets of speakers in the same channel?
(not sure is "channel" is the correct termanology.)
Is there a devise that can be attached to my receiver so more speakers can be hooked up to it? I only have a place to hook up two sets of speakers.
Same Problem
Dec 29, 2007
-   hook up two speaker 4 ch amp 1 ch is 50 rms x 2 @ 1.5ohm-4ohm 1 speaker is 100 watts rms 4 ohm and the atherone is 2-9 watts rms-   Guest
Best Solution
posted on Dec 30, 2006
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I don't know how "Techman" got a "Guru" rating but his answer is completely stupid.
The manufacturer rates the speaker outputs for 8 ohms. Plenty of people have reported running 6 ohm speakers just fine. What few people realize is that this impedance rating is not fixed like a resistor, it changes based on frequency.
Anyway, all the rating means is that you have to keep the individual total speaker output rating near 8 ohms to avoid over or underloading the amplifier channel. You could put two 4 ohm speakers in series (some dual voicecoil subwoofers are manufactured this way on purpose), or two 16 ohm speakers in parallel. You could put four 2-ohm speakers in series, four 32 ohm speakers in parallel, two 2-ohm speakers in series with two 16 ohm speakers in parallel, etc etc etc. As long as the equivalent resistance presented to the speaker output is around 8 ohms.
Also if you underload (present more than 8 ohms) you won't "burn up" anything, you just won't develop the maximum volume potential of the amplifier out of the speakers.
Solution #2
posted on Oct 16, 2006
Helpful)
techman
Rank: Guru  Pioneer Expert
Rating: 86%, 7650 votes
How this reciever is set up is there are left and right A and left and right B Only one 8 ohm speaker should be attached per outlet. if you exceed that your driving the channel at a much lower resistance then the units designed for and the channel will burn up.. Oh it might last a short time but bet your last dollar it will burn up the channel if you over load it.
Please dont forget to rate this.
Was this helpful?
Yes
No
Solution #3
posted on Sep 27, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
What about a niles switch box ?
Solution #4
posted on May 20, 2008
Not Rated)
CABLE CUY
Rank: Wiz
Rating: 85%, 73 votes
TECHMAN IS WRIGHT BUT IFF YOU MUST USE MORE SPEAKERS USE A 1 INTO 4 SWITCH BOX.
WHEN USEING A STEREO AMP YOU SHOULD ONLY USE 2 SPEAKERS FOR BEST SOUND.
REMEMBER WHEN YOU LISTEN TO A LIVE BAND THEY ARE IN FRONT OF YOU NOT AROUND YOU.
HOPE THIS IS HELPFUL.
CABLE GUY.
Was this helpful?
Yes
No
Solution #5
posted on Apr 09, 2008
Not Rated)
mick2450
Rank: Apprentice
Rating: 0%, 0 votes
i have a similar issue...i have a decent sound system, mix and matched....by that i mean, i run a cable from my laptop, to a mixing board, then from there i run 2 cables to my stereo system, which is hooked to 2 speakers....basic....but i have 2 more speakers that the wires from each speaker are split to another 2 subwoofer enclosure...would 2 splitters do me fine if i do so decide to hook up the last combination to the stereo?
Was this helpful?
Yes
No
Solution #6
posted on Feb 06, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The suggestion is correct for Amps designed to run at 8 ohms. If you amp, like the Onkyo 8511 that I was attempting to search on, is capable of driving 4 ohms, then go for it.
Popular Solutions for Pioneer VSX-454 Receiver
Questions and Unsolved Problems for Pioneer VSX-454 Receiver
Do you recommend Pioneer VSX-454 Receiver?
Answer
Answer
Pioneer VSX 454 receiver displays overload and shuts down. I have checked speaker connections and... (More)
Answer
center channel not working. unplugged one of the other speakers and the center channel would work.... (More)
Answer
I have my Sky TV & DVD sound through a VSX 454, and I get an "out of sync" or a... (More)
Answer
Bought new Denon receiver. Hooked up main speakers to speaker A and 3 sets of small speakers... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Receivers Experts
Top Audio & Video Equipment Repairmen
in , AR
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
