Question about Weller 8200 Soldering Gun
Replacing tip I have an 8200 Weller soldering gun with hex nuts to hold the tip. How do the hold the tip? The tip just slides in and out.
I have an old 8200 and i just bend the ends of the replacement tip, then i just tighten the bolts. that is how the tip was on the when i bought the 8200. cheers
Posted on Dec 29, 2008
If you are really desperate for a tip use a metal box staple, the copper colored ones that always tear your hand open if you don't pull them out.
Posted on Apr 30, 2009
  • 25 Answers
If the tips your using are not the OEM size, you can always use a small piece of paper clip to act as a adapter reducing the ID so the tips make proper contact.
Posted on Nov 27, 2008
Is the weller 8200 comparable to the "Old Weller
Hello, your Weller 8200 soldering gun is rated at 140 or 160/100 watts. While the junior was about 70 watts. Go to this web site for parts: www.e-sonic.com/aboutus/cat/S/soldering%206.pdf GB...stewbison
Apr 23, 2011 | Weller Welding Tools
What is the proper output voltage going into the solder tip?
The voltage is nearly unreadable it is so low, but the current is quite high. If the tip won't heat, loosen the tip nuts and re-tighten.
Dec 12, 2010 | Weller 8200 Soldering Gun
Weller 8200 series soldering gun sometimes fails to heat; tightening screws and/or gently spreading arms often helps. Is there a permanent fix?
There is constant maintenance needed to keep soldering, the key ones are the tip fastening nuts, and the tip itself. The tip eventually needs sanding and immediate retinning, Clean with damp rag during and after each soldering event, and heavily re tin at end of event.
Sep 14, 2010 | Weller Welding Tools
Need to know where I can get tips for a 8200 gun.
Sears Hardware carries Weller and and has tips for the 8200 Weller Soldering Gun, I just swa them yesterday at Sears Hardware.
May 21, 2010 | Weller 8200 Soldering Gun
Does not melt solder
The body contains a transformer, which steps your 120AC down to a lower voltage. The lower voltage runs THROUGH the tip, heating it up. Possibility ONE: Transformer is no good, throw it away. TWO: Not enough current is running through tip, because tip is corroded OR those mounting nuts are corroded, loose, OR somebody put new tip into nuts but neglected to bend both legs of new tip 90 degrees. Look at the barrels, you will see little holes in the sides, tip's legs go into those holes.
Mar 15, 2010 | Weller 8200 Soldering Gun
Weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Jan 22, 2010 | Weller 8200 Soldering Gun
How do i solder together some headphone wires?
1- pull the trigger and melt some solder onto the tip then release the trigger.
2- hold all the wires together.
3- touch the tip to the wires and pull the trigger. when the solder on the tip melts again it will flow onto the wires
Jan 16, 2010 | Weller 8200 Soldering Gun
Weller 8200 does not heat
loosen nuts that hold tip and retighten,it'll heat if xfmrs good
Jul 13, 2009 | Weller 8200 Soldering Gun
Weller 8200 Soldering Gun Logo
868 people viewed this question
Top Weller Welding Tools Experts
Lawrence Oravetz
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Weller Welding Tool Expert? Answer questions, earn points and help others
