Question about KitchenAid KUDS24SE Built-in Dishwasher
Cranky dishwasher I have to admit my wife's solution is the only one that works. Our ten-year-old Superba built-in usually starts a normal cycle part-way through, at the wash part, without filling or opening the dispenser door. Therefore the dishes come out with the soil now baked on. Closing the door, selecting normal and start results in a pump-out sound, or at least just the pump running to wash the dishes. The dishwasher ignores any cancel button push,and the light does not come on over the cancel button. The only way to stop the cycle is to open the door, but then it begins from where it left off shortly after closing again, as it should. Having been batching during my wife's holiday for the last week, I eventually was faced with a crammed-full dishwasher and, too lazy to wash it all by hand, I resorted to her technique of slamming the door as hard as I could and, presto, it started filling with water and worked perfectly! It's always bugged me that she's done that, I just figured she didn't understand how the control panel worked, but now I think she's on to something. So, before the door falls off the dishwasher, what should I consider?
  • smsmith40 Oct 05, 2008
    I have resorted to calling my Sculptura "Christina" after S. King's novel about an evil car with personality cause this machine seems to have a mind of her own. "She" has decided to stop working while mounted undercounter (no water coming inside the unit when running). After I remove the lower panels to check for crimps in the H2O hose, I find nothing. Then pull 'her' out from underneath the counter, Christina seems to run just fine. Re-mount her underneath and guess what....it's Christina!! Help!
  • therald Nov 12, 2008
    Our KitchenAid has the same symptoms: when selecting Normal Wash and prressing Start, it immediately goes to the end of the cycle and activates the discharge pump. I finally tried selecting Rinse Only and it started to fill. Without stopping or canceling, I selected Normal and it seems to be going throught the proper cycle now.
    President:
  • 878 Answers
You want to make sure that the dishwasher is level and secure first of all. Then I would look into the door latch assy. Sounds to me that you are not making all the latch switches when closing normally. When you are slamming it, you are making the switches. The heating element runs through the neutral side of switches, therefor if the switch is broken or the latch is not making, no heating of the water. This results in a default or very long wash time. Check this out first....Catriver..post back.
Posted on Oct 15, 2006
Green normal light is on but none of the buttons including start button work
Hello friend, thank you for your post!
I understand that the light on your Frigidaire dishwasher is lit as it normally is, except it will not operate. It is possible that your dishwasher may have an issue within the keypad or control panel. You can perform a reset, in the case that it is a miscommunication error within the dishwasher. You can reset the dishwasher by flipping the household circuit breaker off for at least ten minutes. If this does not help correct your issue I would recommend seeking assistance from a professional technician for a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. I hope this information is helpful. -Matt
Nov 22, 2013 | Frigidaire FFBD2406NS Built In Dishwashers
I am locked out of cycle with clean light blinking green and cannot find my manual, dishwasher is about 1 year old. Is there a sequence to break this cycle? I turned off power for 60 seconds to no avail.
Hi
I have not seen this model in Australia, but normally if you hold down "Start/Stop" button for 3 to 5 seconds, that should clear the cycle.
Otherwise if you have a Clear button press that for 3-5 seconds.
Ash
Sep 06, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Rough film on dishes
first clean dw use tang then prime sink and run dw after that cut back on detergant
Jun 06, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
My dishwasher is just three years old. The other night my wife said it made a loud noise while it was running and now it is full of water at the end of the cycle. Any ideas?
The pump attached to the end of the motor shaft inside the tub may have broken. If it doesn't spin the water wont pump out but usually the water wont spray on the dishes either. Watch it run a second with the door open and the door switch make to see if it's spraying.
Mar 22, 2010 | Bosch 24 in. SHX46A05UC Built-In...
Normal cycle leave dishes half clean. Heavy cycle
in the bottom of the machine, under the bottom rack, is a screen looking piece. twist or just pull up, should be able to clean that then replace.
Aug 08, 2009 | KitchenAid 24 in. KUDP02CR Built-in...
Cycle time
yes its normal.bosch dishwashers use very little water and energy but,the cycles need to be longer to get the dishes clean. its perfectly OK.(ps use cascade powder if you can)
Jul 24, 2009 | Bosch 24 in. SHU6802UC / SHU6806UC...
Dishwasher won't cycle
Sounds like you need a new timer. Costs about $50 - $60. I had the same problem. The knob now turns. Hope this helps.
May 18, 2009 | GE Nautilus 24" Built-in Dishwasher
Runs forever! even on Normal wash...help !!
Check to make sure you heating element has not failed. Dishwashers of today heat the water periodically through out the cycle and if the element has failed. The heating delay light is the indicator that tells you that it is trying to heat the water.
Feb 26, 2009 | Frigidaire 24 in. FDB635RF Built-in...
Dishwashers Logo
333 people viewed this question
Top KitchenAid Dishwashers Experts
Carmen Mikulic
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
