Question about SanDisk Sansa E280 MP3 Player
Playlists Won't sync Playlists from my Windows Media Player
  • 758 Answers
What you need to do is to uinstall the device completely from the computer..once you have the device remove, open your windows media player click on tools, options, go under privacy,clear the history and caches...and then reinstall the device back...let me know if that doesnt help yo
Please rate accordingly
Thank you
Computerrrep
Posted on Nov 08, 2008
How do i copy music to my mp3
You can sync your music and pictures to your player using Windows Media Player.
By default, Windows Media Player automatically loads all the music and picture files
stored in your My Music and My Pictures folders into the library. If you add new files to
these folders, they will also be automatically added to the library.
If Windows Media Player has selected to sync your device automatically, you can choose not to sync your entire media library. You can choose what you wish to sync from existing
playlists or create new playlists. These playlists you have selected will then sync to your player every time you connect it to your computer.
1 Click the down arrow beneath the Sync tab and select Philips GoGear SA60xx > Set Up Sync.
> The Device Setup dialog box appears.
2 In the Available playlists pane, select the existing playlists you want to sync and then
click Add.
28
4.3.4 Select files and playlists for Manual Sync
If you sync manually, you must create a list of files and playlists you want to sync. You can also shuffle which files from your playlists to sync to your player.
1 Start Windows Media Player.
2 Switch on your player and then connect it to your computer using the supplied USB cable.
3 Click the Sync tab.
4 Drag the files and playlists that you want to sync from the Contents pane to the Sync List pane. You can also right-click on the file or playlist and select Add to "Sync List".
3 To create a playlist, click New Auto Playlist and follow the steps on the screen to specify criteria for files in the auto playlist (for details on how to create an auto playlist,
4 To remove a playlist, click the playlist in the list of Playlists to sync, and then click Remove.
5 In the Playlists to sync pane, select a playlist and click the Priority arrows to arrange
them in the order that you want them to sync.
Feb 12, 2011 | Philips GOGEAR SA6045 MP3 Player
My Sansa e280 is not downloading my playlists from Windows Media. I have tried dragging and dropping the playlists from my computer music folder to the Sansa folder and it still will not write to the mp3...
The Sansa e280 can be operated in 2 ways of USB connection modes: MSC or MTP.
In MSC mode, viewing the player as a removable disk, the "copy
and paste" or "drag and drop" method will work.
In MSC mode always through the "safely remove hardware" icon, click to remove the player's disk before taking out the USB cable.
In MTP mode, operating the player in software like Windows Media Player: under Library or Sync,
first create a playlist
next sync the playlist.
In MTP mode, follow up the warning or text in the software that gives permission when to disconnect the player.
Apr 11, 2010 | SanDisk Sansa E280 MP3 Player
How can I stop my 8gb clip automatically downloading my library i do not want all my library on my clip
1) Connect your Clip to your PC.
2) If Windows Media Player doesn't run automatically, run it.
3) On the left side of Windows Media Player, right-click on your Clip and select "Set Up Sync".
4) If you don't want songs to be synced automatically to your Clip when you connect it, uncheck "Sync this device automatically."
5) If you do want songs to be synced automatically, but not your entire library, check "Sync this device automatically", then click on the playlists you DON'T want to sync under the "Playlists to sync" list, and then click on the "Remove" button.
Feb 09, 2010 | SanDisk Sansa Clip MP3 Player
Wen i delete music from the library in windows media player it also deletes it from my philips gogear mix how do i stop this
Playlists to sync on the player can be set in Windows Media Player.
When selecting the Library or Sync tab in WMP full view, the GoGear is visible on the left side in the list.
The player can be either connected seeing the player's icon or not connected seeing the player's map name.
Right click the GoGear Mix and select Setup Sync...
The box, Sync this device automatically probably is selected.
Prevent the player from unattended synchronizing by unchecking this box: Especially when you're removing lists on the computer frequently.
Setup the the playlists to sync first and synchronize manually after that.
Temporary "Sync this device automatically'' must be selected, to be able to edit the playlists to synchronize.
On the right half of the Device Setup screen there''s the "Playlists to sync''.
Under playlists to synchronize, first remove all playlists or those you are going to delete in the library, before synchronizing.
When needing more information, just post a comment.
Jan 06, 2010 | Philips GOGEAR SA6045 MP3 Player
Flash mp3 (MC4004) F"n thing making me mad!
When the player shows up as a detected device in Windows Media Player 10 or 11, the MC4004 will try to synchronize the playlists that are on the player with those on the computer.
It is possible that playlists on the computer:
1. have been removed or
2. are no longer in the library for synchronizing
Synchronizing can be set automatic or manually in WMP.
When you right click the player in the list in WMP, selected Library or Sync view, you will be able to setup the sync mode of
the player.
For more help look in the help function "Help with Sync" under the Sync tab in Windows Media Player.
Need more assistance ? Just post another comment.
Jan 04, 2010 | Audio Players & Recorders
I can't get a playlist onto my Sansa m240. I tried the method described on this site, and the name of the playlist came up, but said it had no files.
Creating Playlist
To create a playlist for Windows Media Player, follow these steps:
1. Launch Windows Media Player.
2. Clear the List pane by clicking the Clear List pane button.
3. Click the arrow below the Library Tab then select Create Playlist.
4. Type in the name of your Playlist.
Loading Content 14
5. Click Songs from Library then drag them from the Details pane to the List
Pane.
6. To rearrange the songs, drag them up or down in the List pane.
7. Click Save Playlist.
Transferring Playlists
To transfer playlists to your Sansa player, follow these steps:
1. Connect your Sansa player to the computer.
2. Select Sync digital media files to this devices using Windows Media
Player on initial connection.
3. Right-click on Your Sansa Player, then select Set Up Sync.
Loading Content 15
4. Select Personal Playlists from the drop down menu on the left pane.
5. Highlight the playlists you want to transfer to your Sansa player, click Add,
then Finish.
6. Synchronization will start as soon as you click Finish. To see the Sync
progress, click on Sync Results.
Dec 05, 2008 | SanDisk Sansa m240 MP3 Player
Menu
These directions only apply to the Philips SA6045/37:
It's not going to be easy, because you will have to do two undesirable things: 1) Set your player up for auto-sync, which will result in the player adding unwanted media files to your player without your consent - and possibly overloading your player; and 2) You will have to roll back to Windows Media Player 10.
If you ask me, it's not worth it, but here's the procedure:
  1. Playlists can only be synchronized to your player via “auto sync”. Autosync will automatically synchronize your Windows Media Player library content and your player content each time you connect your Player to the PC. If you use the “manual” sync option the tracks in the playlist will transfer to your player but the playlist itself will not.
  2. Hook up the Player to the computer, allow a few minutes for the Windows Media player to recognize and detect the connection of the Player.
  3. Click on the Sync tab.
  4. Click on “Sync settings” or “Set up sync”
  5. In the pop-up window, select the playlists that you want to sync
  6. Click “OK”, the sync will start automatically
Note: playlists never show up in the device panel under the sync tab of Windows media Player even if they are on your device. Check on your device whether you can see the playlist.
-Tha Mp3 Doctor
Sep 12, 2008 | Philips GoGear Flash MP3 Player
Sansa m250 playlists
First you need to set your Sansa m250 mp3 player to MTP mode:
) Tap your menu button and select "Settings" > "USB".
2) On this screen, make sure that there is a check next to "Auto Detect" and NOT "MSC".
Note: Music that was transferred to the player in "MSC" (Mass Storage Class) mode will not be accessible once the player is put into MTP mode.
However, the music can still be accessed by switching the player back to MSC mode.
To transfer a playlist using Windows Media Player version 10:
- Make sure device is showing as an "audio device" and in MTP mode
- Create a playlist by right clicking a song in the library, add to>additional playlists>new or by saving a now playing list
- Select the Sync tab and click "Sync settings"
- Check "Synchronize device automatically"
- Set "View" to "All Playlists"
- Place a check next to the playlists they want to transfer to device
- Media Player should then sync those lists once you hit OK.
Once you Sync for the first time a new folder "Playlists" will appear in your m250 using Windows Explorer. Once that folder is created you can even use Windows Explorer alone to create playlists, all you have to do is right click on a song and choose create a playlist. Double click on playlist > Reference Tab, on the window you simply drag and drop your songs.
Hope this helps
Aug 28, 2008 | SanDisk Sansa m250 MP3 Player
Cannot load playlists
Try sync your player with winamp. It synced the whole winamp media library (including playlists). Hope this can help.
Jun 10, 2008 | Samsung YP-K3 MP3 Player
IRiver H10 - Cannot update playlists
There are two ways to format an Mp3 player - one on the computer itself, and one in Windows Media Player. Both methods will end up erasing all the songs on the player, but the player will be "good as new" after that. Sometimes reformatting in this manner will override the player's native formatting and cause problems - this can be reversed in most cases by updating the player's firmware. Firmware upgrades are available from most manufacturers' websites.
WARNING: The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes, format it to FAT or FAT32. - Connect player to computer, double-click my computer, right click on icon of mp3 player and select format. This only applies to Windows-based computers.
You can also format the player in Windows Media Player itself:
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
-Tha Mp3 Doctor
Feb 20, 2007 | iRiver H10 MP3 Player
SanDisk Sansa E280 MP3 Player Logo
129 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
