Question about HP PhotoSmart 7660 InkJet Printer
Printer thinks it's jammed
Our hp 7660 always thinks it's jammed.After pressing "ok" to resume calibration, it sends out one blank page--so not jammed, then rolls the next sheet up into place and them says "paper jam" again. This is irritating. Please help
  • tinatetzlaff Nov 07, 2008
    We tried to clean the roller. So far, it is doing the same, trying to run the calibration page, and then it gets started and then we still get the paper jam message. Willing to try any suggestions out there. thanks again for trying.
    Master:
    Sergeant:
  • 449 Answers
Hi!!
try to clean the roller
Posted on Nov 07, 2008
Printer says paper jam on calibration
If you check closely, you may find there is a small piece of paper trapped between the rollers?
Feb 21, 2013 | HP PhotoSmart 7760 InkJet Printer
K5400 warning lights indicated print head problems. I have cleaned the print heads and reinstalled them and I am back in business but now it's doing a test print on every occasion.
Try doing an alignment with the printheads.
You can also try changing the inks,if that solves the problem eventhough old inks are stil not empty,contacts might be the issue on old inks which causes error blinking lights which is an indication of printhead rejection.
Method one: Clean printheads in Solution Center
  1. Make sure the printer is loaded with unused white paper.
  2. In HP Solution Center , click Settings , and then click Printer Toolbox .
  3. Select the Services tab, and then click Clean Printheads .
Method two: Clean printheads from the control panel
  2. Press and hold the Power button
  3. Press the Cancel button two times.
  4. Press the Resume button one time.
  5. Release the Power button
    Cleaning the printheads takes a few minutes, and when it completes, a page prints.
Method one: Calibrate linefeed in Solution Center
  2. Open HP Solution Center , then click Settings , then Printer Toolbox .
  3. Select the Services tab.
  4. Click Calibrate Linefeed .
  5. An Advance Linefeed Calibration window opens. Click OK .
  6. After calibration, print another PQ Diagnostic. If there are still dark lines or white gaps in Test Pattern 3, the printer must be serviced.
Method two: Calibrate linefeed from the control panel
  1. Press and hold the Power button
  2. Press the Cancel button fourteen times.
  3. Press the Resume button six times.
  4. Release the Power button
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in the post that helped you.
Please click "YES" in solution that solves your problem as "was this helpful?"
(Although I am employed by HP, I am speaking for myself and not for HP)
Apr 10, 2011 | HP OfficeJet Pro K5400dn Photo Printer
Cannot find resume button on HP 7210
the resume button is on the control panel . Peform a self-test by pressing and holding the RESUME button on the control panel until the product begins printing. A test page prints. you may have to hit enter to get to see resume after you have cleared the jam
Nov 11, 2009 | HP Officejet 7210 All-In-One InkJet...
Just replaced my black ink but printed page comes out blank
Change your print preferences to black and white as a work-around until you get color.
Aug 10, 2009 | HP PhotoSmart 7660 InkJet Printer
After changing black ink it does print badly
remove and re-seat it.
calibration is automatic.
To print a test page try.
Press and hold the OK button.
Then press the left arrow key one time.
Release the OK button.
Printer tool box, use head cleaner, nozzle check.etc...
Replace the cartridge.
Hope this helps
Ric.
Apr 17, 2009 | HP Photosmart D5160 InkJet Printer
Machine refuses to print incoming fax. "Paper mismatch"
HP Printer 7210 or 7310 Gives Error receving faxes Load a new blank paper on paper tray.
Press * and # simultaneously, and then release both buttons.
Press 1 , 2 ,and then 3 . The Service menu appears.
Press the right arrow button (>) until the System Configuration menu appears then press OK.
Press > until Media Sense Calibration or Calibrate Spot Sensor appear and then press OK. The unit should pick the paper and eject it.
Press the Cancel button until date and hour appear on display
Mar 05, 2009 | HP Officejet 7210 All-In-One InkJet...
HP 7660 "Print Cartridge Cradle is Stuck" Message
I was having same problem but it was a paper jam all the time and then it started to state Cairrage Jam. And what was happening was the unit the cartridges sit in was not going all the way to the right. A little nudge and you could feel it move. Closed lid and sometimes it would print but eventually it would fail. Just replaced but I suspect if you can get to the cairrage you could clean/repair whatever was keeping it from going all the way to the right.
Hope that helps!
Dec 18, 2007 | HP Photosmart 7660v InkJet Printer
Hp-dj 9650 won't print
please reinstall printer software
Sep 22, 2007 | HP DeskJet 9650 InkJet Printer
HP 5550 Print issue
When you removed the jammed paper , the jam paper sensor was not reset or positioned correctly. The reason the machine was sending two pieces of paper thru at once was probably due to the paper feed sensor. A lot of H'Ps do this. Try re-aligning the tray and if you pulled the paper out and heard a grinding noise, the whole feed unit is probably out of time.I would only re-install the software as a last resort, since your problem was caused by hardware, not software. Scrivitron
Jun 20, 2007 | HP DeskJet 5550 InkJet Printer
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP PhotoSmart 7660 InkJet Printer Logo
147 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
