Question about Roper REX4634KQ Electric Dryer
Dyer cutting off
After drying for about thirty minutes the dyer will cut off. i unplugged it for about thirty minutes and it started back just fine then cut off again.
  • timothygonza Dec 18, 2008
    the dryer runs about a minute with heat then shuts off
  • 198 Answers
Sounds like a bad motor, motor is overheating and shutting down
Posted on Jan 18, 2009
1989 Ford 150 4cly truck will run fine then starts cuting off and dies out . . no one can fix it. in shop now. shop owner pay labor can not fix. in shop 50 days
Hi, Check fuel pump that it is running properly. Sounds like an electrical problem with the pump. Good luck.
Oct 29, 2012 | 1996 Dodge Ram
My computer won't connect to the internet
there can be multiple reasons for this, try cutting off the computer for 1 minute and while it is off unplug your router for about thirty seconds, then plug the router back up wait 5 seconds and turn the computer back on!!!
Dec 15, 2010 | Computers & Internet
After 4 years of great service my tv cuts of by itself. I unplug for a few minutes and plug it back in and it plays for 30 minutes and cuts off again
Your power supply is going. It is probably a capacitor that has dried out or some other overheating problem.
Tim
Nov 26, 2009 | Sharp 25N-M100 25" TV
The freezer works fine, but if you unplug it, it won't start back up, you have to let it sit unpluged for about 30 minutes to an hour before it will come back on. Its like it needs to cool off, it does get...
The high side and low side of the refrigerant system , have to equalize , before the compressor can start . If you unplug , then plug back in , the high side has a lot more pressure , therefore the compressor will not start and the overload will cut the compressor off . When overload cools slightly , compressor will try to start again . If pressures not equalized , overload will cut compressor off again . As this happens , the compressor will get hotter and hotter . Eventually , pressure will equalize and compressor will continue to run . Very bad on compressor and components .
Aug 06, 2009 | Freezers
Dryer works and cut off
Sounds like heat over load switch is tripping due to lint build up , check around heating coils for lint build up if electric and make sure that you have free air flow from exhaust vent
Aug 05, 2009 | Frigidaire GLEQ2152ES Electric Dryer
My dyer will not cut off
I would suggest checking to see if your start button is stuck
Jun 17, 2009 | Dryers
Kenmore 970 C81062 10 Electric Dyer WILL NOT
It sounds like the drum may be stuck. Turn the dryer on with the door open, just keep the button pushed. Then try to turn the drum by hand, and see if it will start to turn.
Jun 04, 2009 | Dryers
Kenmore Electric Dryer 70 Series
your motor is over heating and shutting off.you need new motor.
Mar 11, 2009 | Kenmore 65924 Electric Dryer
Roper REX4634KQ Electric Dryer Logo
87 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
