posted by sinsin18 on Oct 30, 2006
i have it all set and it scans and copy's just fine, but when i try to print up a photo, it say's failure to communicate with printer. i have uninstalled and reinstalled 4 times. but still a problem a problem. any help out there?
Best Solution
posted on Jun 20, 2007
Guest
Rank:
Apprentice
Rating: 0%, 0 votes
Rating: 0%, 0 votes
Return the printer for a printer that will work with Vista, it appears that Lexmark doesn't care if their printers work or not. My friend has the same problem with the Vista driver for the Lexmark X7170 not printing or communicating over the USB port at all. Work with XP, but not Vista
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Oct 30, 2006
Best to start from beginning, assuming your usb cable is ok.
Remove printer from usb port,then uninstal printer driver.
Re install printer driver and when prompted re connect printer(Use a different USB port, if have a spare one).
Make sure windows finds new hardware, then identifies your printer(popup on right side of task bar), them watch for it telling you 'Your hardware is installed and ready to use'.
Go to your printer folder in control panel and look on printers properties to see if it's on line.
Come back if this does not cure it.
Solution #4
posted on Mar 06, 2007
I have just purchase a new computer that use's Vista Windows, tried to install and it says can't find the driver? Called and was tolded that I would have to contact you and get a free download to correct the problem
Comment by babyhuie, posted on Mar 11, 2007
I've done all that was suggested and the printer still won't come onto the computer
Suggest a new solution for this problem
Post a New problem for Lexmark P4350 All-In-One InkJet
Email this problem
Email this problem
This Problem Also Relates To:
Lexmark C782DTN Printer
Lexmark C782N COL LASERPR 25PPM 1200DPI 256MB ETH Printer
Lexmark C782N Laser Printer
Lexmark C910fn Led Printer
Lexmark C770dtn Laser Printer
Lexmark C760n Laser Printer
Lexmark C762n Laser Printer
Can you Help with these Printers problems?
Lexmark P4350 All-In-One InkJet Printer
lexmark p4350
lexmark p4350
i have installed from disc but... Answer This...
my all in one wont scan
when i try to scan from my... Answer This...
Repair Service
Find Printer Repairman Near You:
