Question about Philips SoHo 107T21 (White) 17" CRT Monitor
High pitch sound being emitted
Hi, There is a very high pitched noise coming from the monitor; shriller while reproducing dark colours. The sound intensity reduces when the monitor is switched off and switched back on but slowly grows stronger again. Coming to think of it this sound has been always there albeit at lower intesity. Its only now, when the noise has become more shrill and painfull that I have been able to place the source as monitor.
It could be a harmonic noise caused by dust inside the monitor. If you are qualified (brave enough) to remove the back cover, blow the entire inside of the monitor out with compressed air (carefully) that may help. It could also be the flyback transformer. In that case, you would have to have the transformer replaced (I wouldn't recommend doing it yourself unless you are a TV technican as the CRT can contain a static charge of 14,000-25,000 volts- even when unplugged)
Posted on Jan 04, 2008
When turned on the screen is blank and makes a high pitch buzz
Samsung LCD TV with no video and high pitched sound - Digital TV ...
www.tomsguide.com/forum/54120-4-samsung-video-high-pitched-sound
Nov 8, 2015 - 25 posts - ‎12 authors
Our is the same model and has started making a very high pitched ... to acutally turn on and then when it does, the screen is still black and we ...
Is your LCD making a buzzing or high pitch noise ...
https://www.devside.net/blog/lcd-making-a-buzzing-noise
Dec 30, 2008 - In my case, the monitor was fine for the first two months. But then started making a buzzing noise... 1) when on, 2) worse when .... my Samsung TV ismaking high pitched noises even if its turned off. I will NEVER EVER EVER ...
TV not turning on; making high-pitched sounds - Tom's ...
Dec 13, 2015 | Televison & Video
Piaggio mp3 125cc motorcycle, won't start and emits high-pitched "whining" noise, last garage-serviced October 2012
chec alternator for health--sounds like bearings are bad--du u gut a repair book for that model--git one online or checout library sec 629--its a basic component so othr manual can help u
Feb 25, 2013 | Piaggio Motorcycles
My Dell inspiron 13r laptop is emitting a very high pitched noise when it is on. I have tried reinstalling my audio drives but nothing seems to be working... Please help
If it is a relatively quiet, high pitched noise, it may not even be from your speakers. I've experienced a high pitched noise whenever i plug in my AC adapter to my PSP, so there is a chance it might be power related.
Mar 25, 2011 | Hi-Capacity Equivalent of DELL INSPIRON...
View sonic computer screen was dropped and now when you turn it on the picture comes on and then it emits a high pitched sound and turns off. any suggestions?
Sounds like you may have broke at least one of the lamps . The high pitch sound you are hearing is the high voltage that goes to it .
Feb 05, 2011 | ViewSonic OptiQuest Monitor
High pitch frequency noise coming from rear of TV and is very annoying to listen too. It is a constant noise and is more apparent when there is more black color on screen.
High pitch sound on LC-42D62 is reproduced by switching transformers on power supply board. To correct this problem, you will need to remove power supply unit from the TV, spray all transformers with SILICONE CONFORMAL COATING. Let it dry for 12Hrs. Then install power supply unit back.
Dec 31, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Panasonic TX32POL1 high pitched noise
The high pitch sound is comming from a power supply transformer that will resonate (or vibrate) at the operating frequency (12-14KHz).
This is usually affordable to repair -at least worth the estimate.
Oct 14, 2009 | Televison & Video
Won't turn on.
Thats sound it's because the horizontal IC are in bad conditions and need to replace it.Good luck.
Jul 25, 2008 | Televison & Video
Weird noise over everything
According to the Samsung website: "The high pitched sound you hear is probably coming from the flyback transformer. The flyback transformer converts the relatively low voltage electricity that comes from the outlet in your home to the high voltage electricity needed to drive the cathode ray tube in your TV. It is not unusual for a flyback transformer to buzz softly when it operates. However, if the sound is loud and high pitched, it probably means the transformer is failing. To eliminate the sound, you will have to get your TV serviced."
Nov 08, 2007 | Samsung SlimFit TX-S2783 TV
High-pitched noise
Could you specify if noise is coming from : - The freezer - The outside back of the refrigerator - The bottom of the refrigerator
Jun 13, 2006 | Smeg FAB28
Philips SoHo 107T21 (White) 17" CRT Monitor Logo
226 people viewed this question
Top Philips Computers & Internet Experts
micky dee
Steve Allison
Steve Allison
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
