Kenmore Elite 45986 Front Load Washer Logo
Posted on Nov 07, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F6 Code Machines stops not long into the cycle. Error code F6 comes up. cancelling and restarting cycle does not help. What is this code?
  • mouse4414 Nov 08, 2008
    same error
Ron Coons
Level 3:
President:
  • Kenmore Master 2,651 Answers
  • Posted on Nov 07, 2008
Ron Coons
Kenmore Master
Level 3:
President:
Answers
2651
Questions
Helped
1547463
Points
7824
F6 communication error in ht emotor controll board, located in the lower left front of machine
Todd Karutz
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 31, 2012
Todd Karutz
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
5912
Points
9
Unplugging the washer for 10 seconds and plugging it back in will solve this problem 9 times out of 10.
What does error code F6 mean
The meaning of error code F6 can vary depending on the brand and model of the washing machine. Here are some possible explanations for F6 error codes on different brands:
  • Whirlpool: F6 error code on Whirlpool washing machines typically indicates a problem with the motor drive tachometer, which measures the motor's speed. This can be caused by faulty wiring or a failed motor control board.
  • Kenmore: On Kenmore washing machines, F6 error code can indicate a problem with the motor or motor control board. This can cause the washing machine to not spin or agitate properly.
  • Maytag: F6 error code on Maytag washing machines can be caused by a problem with the communication between the central control unit and the motor control board. This can cause the washing machine to not start or complete a cycle.
  • LG: On LG washing machines, F6 error code can indicate a problem with the motor or motor control board, or a communication error between the main control board and the motor control board.
It's important to consult the user manual or contact the manufacturer for more specific information and troubleshooting steps based on your specific model and error code.
I have an f6 code and the machine will not operate once it comes up
The F6 error code means that the computer on the control didnt detect that the motor reached a high speed on the spin cycle, sometimes it thinks the washer didnt spin fast enough because of a loose wire connection either on the motor or the control boards (motor &machine control) if you find that the washer did actually spin at high speed (clothes dont come out sopping wet at the end of cycle) the wire connections or the motor control board will be the potential causes of the F6 error code. Try unplugging the machine for five minutes to let the computer reset then try again. Next check the control panel wires. f6 code flashing on display Kenmore Elite HE3 Washing Machine
1helpful
2answers
What does and F6 error code mean on a whirlpool duette front loading washing machine mean and how do I fix it?
Error code F06 means Drive motor tachometer error.
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
1/ Check wire harness connections between the Drive Motor/Tachometer and the Motor ControlUnit (MCU), and between the MCU and the Central Control Unit (CCU)
2/ Check the Drive Motor
3/ Check the MCU
4/ Check the Wire Harness
Replace failed component or contact an authorized repair agent.
I was getting the F H error code on my washer. I hit cancel twice to clear the code to see of a cycle restart would remedy. Now the wash cycle is stuck on 45 min. remaining & the cancel button is no...
The FH error code on your Kenmore Elite washing machine is an indicator that there is a problem with incoming water. When there is little water coming into the machine, the FH code will appear and the washer will stop. There are a couple of common problems you can check while you are resetting the FH error code. You will need to remove the power supply to the washer to reset the code.
  • 1 Look for the "Pause/Cancel" button on the washer control panel. The button will be below the digital time clock and to the lower right of the wash cycle selector.
  • 2
    Press the "Pause/Cancel" button twice to cancel the wash cycle. Unplug the Kenmore Elite washer from the wall outlet.
  • 3 Check for kinks in the water supply hose while the washer does not have power. Turn off the water supply spigots and remove the hoses from the back of the washer. Check the port screens at the hose connections for sediment buildup and clean as necessary.
  • 4
    Connect the water supply hoses back to the washer and turn on the water spigots. Plug the washer cord back into the wall outlet.
  • 5
    Select the wash cycle and press the "Start" button.
  • 3helpful
    2answers
    F6 error on Hitachi washing machine Sk 120KJS
    If your washing machine indicates fb or F6.. here's what i always do..
    Make sure your washing machine has connected to the power socket..
    To switch on your washing machine
    Hold the power button of the washing machine and at the same time switch on the power socket..
    Voila! It works!
    Do take note that by doing that it does not fix your washing machine but it helps to overcome this issue..
    Why does the washer stop during a load and "F 06"
    GENE
    The washer stops half way through all cycles and displays "oL" .
    Error oL means overload.
    If the "oL" error code appears, the washer has been filled with a load that is too large for its capacity, causing it to drain.
    *Remove some items from the washer and add more detergent since the previous amount will have drained with the water.
    *Close the washer and press the START/PAUSE/Cancel button to remove error displayed and restart the cycle.
    If Pause/Cancel does not work:
    *Unplug washer or disconnect power for one minute.
    *Plug in washer or reconnect power.
    *Re-select the cycle and press Start.
    NOTE: If the error remains on the display, and the condition above has been checked, call for service.
    Hope this helps.. :)
    14 cycle front load washer fridgidaire
    press cancel. (turns off washer)
    press start/pause (wake up)
    hold cancel and start/pause 10sec
    last error code will come up.
    E47 door lock error
    check wires connections to the door lock..
    replace door lock..
    hope it helps
    2answers
    "F" error code in WTW6600SG1 Cabrio Washer
    I don't have a solition and am looking for one my duet whirlpool keeps coming up code F
    Alexander
    vince
