Question about LG VX4600 Cell Phone Over-the-ear Handsfree Headset Headset
My phone is stuck on car kit
I have no enhancement setting. I have no head set setting. I've never used a head set. I tried alcohol. To no avail. What else can I do? I can't hear it ring. I can't hear any commands. Can't hear anything. Thanks, Amanda
SOURCE: Car kit
there is internal damage an easy fix is to plug it into the car charger and it will only work on the charger you should have let the phone sit out and dry with the battery detatched. my phone did the same thing about 3 months ago. if that doesn't work you'll need a new phone
Posted on Mar 27, 2007
Shilon
  • 104 Answers
SOURCE: -car kit-
Throw the menu search the profiles and change it to general instead of -car kit- it will be as before.
Posted on Mar 28, 2007
thebus
SOURCE: Car Kit Setting
get aluminum foil and insert it in the charger thingy and rub for a little bit, it worked for me
Posted on Jul 09, 2007
SOURCE: Car kit
im gay
Posted on Feb 13, 2008
zzedly
  • 300 Answers
SOURCE: car kit mode
Car kit mode is usually caused by debris in the phone's cable connector (at the bottom of the phone). The debris causes two or more contacts to be electrically connected to each other, causing the phone to think it's connected to a car kit. Remove the battery from the phone and clean the cable connector contacts with some rubbing alcohol and the corner of a towel. Also, try using an opened paperclip to scrape the contacts in the connector, this will remove any corrosion that may have built up.
Posted on Mar 04, 2008
WHEN I MAKE TEST REPORT THE BLACK COLOR INCORRECT AND WHITE HORIZONTAL BARS APPEAR
If you already tried for cleaning, manually just try it as shown snap shots..Alcohol is best solvent to clean print head nozzles, use cotton or ear buds and swab on nozzles with alcohol, then try for print quality.. If no result replace black print head.. 1_4_2012_9_08_31_pm.jpg1_4_2012_9_08_58_pm.jpg1_4_2012_9_09_28_pm.jpg
Jan 04, 2012 | HP Photosmart C5180 All-In-One InkJet...
Enhancement settings
Enhancement setting are settings for phone accessories like the head-set, blue-tooth etc..the settings make your device perform better
Jul 03, 2010 | Nokia 6300 Cellular Phone
MY YELLOW AND MAGENTA INK DOES NOT PRINT. i HAVE RUN THE CLEANER OPTION NUMOROUIS TIMES WITH NO SUCCESS. WHAT NOW?
Try using a cleaner. I went to youtube and got some ideas about cleaning the inkjet nozzles. You can find a cleaner kit (Liquid and Syringe) on ebay.
You will need to remove the cartridges and slide head to the middle. Make sure you get a paper towel underneath the head, just fold the paper towel so that it is thin enough to slide underneath the head.
You can use a water dropper to put a few drops of water and alcohol (If you don't have the cleaning kit). I tried using alcohol, some people say don't use alcohol, some say use Windex, but I just tried water and alcohol.
Drop alcohol on top of nozzle. Wait about 10 minutes. Towel will soak the alcohol and water. Insert cartridges and try printing.
I had the same problem, yellow and magenta was not printing. After researching on the internet, I decided to try cleaning it myself with alcohol. I was able to get the magenta to print, but yellow still is not printing, so now I am waiting for the cleaner kit with the syringe. The alcohol did make the other colors come out richer and crisper, so it must have done something right.
Anyhow, let me know what you decide to do and if it works for you.
Dec 13, 2009 | Epson Stylus 2200 InkJet Photo Printer
Head set always on
look i will help u
its easy
okay!!
first u ve to promise me that u gonna give me Fixa rate if i helped u
okay??
1/dissasemble the phone
2/ bring medical alcohol and a tooth broch
3/ brush the haedset circuits and diods with al chold and brush
4/get the phone togther
5/ try it
if the problem still occur u got to chnage the haed set chip.*
Aug 16, 2008 | Nokia N73 Cellular Phone
My lg vx8300 phone
Go to settings and change the normal mode and re staret the phone settings will actvate.
Jun 24, 2008 | LG VX8300 Cellular Phone
Can't use my cell. says car kit on .won't go away.Don't have a car kit.Help!
there will be some settings changed in your cell go to enhancment settings it will show text phone\ loop set\ car kit move it as no if this does not help then there will be some moisture in your cell taqke it to the service center
May 17, 2008 | Cell Phones
Connection
Try deleting all paired device from the parrot and your phone, remove battery from you phone to reset it. Then follow below instructions from Parrot.
Pairing Devices: ** From your car kit:
** Select SETTINGS / ADVANCED SETTINGS / PAIR WITH PHONE / OTHER PHONES
* From the phone:
* Select MENU / SETTINGS / BLUETOOTH / MY DEVICES / SEARCH NEW DEVICE
* The phone will search for available devices
* Select CK3100 from the list of available devices and enter PIN code \"1234\"
* Phone and CK3100 are now paired. Wait for auto connection
Feb 04, 2008 | Parrot MINIKIT Bluetooth Hands-Free Kit...
Car kit
there is no setting to find. clean charger port with rubbing alcohol and a tooth brush, be gentle. turn off - let dry and recharge for 2 hrs. worked for me. pain I know. taking battery out will not help. but should check battery conections to see if they are clean,do the same as above. if purple you have water damage. verizon warranty is void if this is the case.
Aug 06, 2007 | LG VX8300 Cellular Phone
Operation
To edit the settings for the headset, car kit, or another audio accessory, open Enhancement settings > Headset. Scroll to the following setting and press OK to edit. * Default profile - Scroll to the sound profile that you generally wat to use with the headset and press OK. Hope this works for you.
Aug 11, 2006 | LG VX4600 Cell Phone Over-the-ear...
LG VX4600 Cell Phone Over-the-ear Handsfree Headset Headset Logo
19 people viewed this question
Top LG Radio Communications Experts
Damen Wong
Damen Wong
iPhone Technicians
iPhone Technicians
Level 1 Expert
coolboyjitu
Level 1 Expert
Are you a LG Radio Communication Expert? Answer questions, earn points and help others
