Louder than usual sound during spin cycle
My two year old washer just started making a louder than usual sound during the spin cycle. There is no grating or rattling, sounds just like the regular "airplane noise" but way louder. I can now hear it spin from two rooms away.
  • 641 Answers
SOURCE: Loud Noise - Spin Cycle
If the washer is making a squealing noise, the problem is more likely to be the basket drive. If it is more like a rattling sound, the centerpost bearings are probably worn out. Open machine's rear panel and spin the basket manually by turning the drive pulley, to find out from where exactly the noise come from. Defective part should be replaced. Good luck !!
Posted on Jun 29, 2006
It sounds like the bearings are going bad. Try spinning the drum with your hand while it is empty. It should spin nice and smooth. If the rotation feels a little rough and noisy, you might have a problem. You can double check by taking the drive belt off and try shaking the pulley. If there is "play" when shaking the pulley, the bearings are most likely toast. The inner stainless drum rides on two bearings which sit in the rear of the outer plastic drum. The whole plastic drum and bearings come as one piece and go for $150. It would cost about the price of a new maching to have someone come out and repair it for you. It sounds like kenmore has had a bearing problem which is pretty rediculous considering how much these things cost. Sears said, "those tend to go in a few years", which is criminal especially since the warrenty is usually conveniently exopired by the time this problem happens. If you are handy, have a spare day, and can remember how to put a washing machine back together, go for it. I did it and it was not a fun time. There is a lot of sharp metal edges in the machine so wear gloves. good luck
Posted on Nov 14, 2006
aborcass
  • 2651 Answers
SOURCE: Rattling noise during high speed spin
sounds as if you might have a bad rear bearing, real obnoxious almost painful to listen too kinda sounds. big job, but might have some part warrentee depending on age of unit
Posted on Oct 21, 2008
SolutionGuy
  • 331 Answers
SOURCE: WASHER SOUNDS LIKE AN AIRPLANE TAKING OFF DURING SPINE CYCLE
Most likely a failed "spinner" assy. The roaring that you hear is the bearing telling you it's had enough and has gone on strike.
MAJOR job! If it's over 5 years old, I recommend calling a professional and get quotes. Then decide what you want to do.
If it's less than 5 years old, it should be under warranty. Contact Sears. Tell them you have a failed spinner and tub bearing assy. and have them do the repair.
*Just a quick note. You should use only HE detergent in these machines.
Tracy
Posted on Oct 28, 2008
Gort007
  • 1187 Answers
SOURCE: We have a whirlpool duet
The rubber belt is worn and slipping under load. (like a fan belt)
There could also be something caught in the belt or pulleys; clear it out and it should work.
If worn, replace belt soon...
Hope this helps!
Posted on Sep 15, 2009
Humming or buzzing during wash and spin cycles.
it's the motor that makes the humming sound..it may have difficulty in starting..when starting like this the motor draws more current and this may cause the windings to burn out..try reducing the load..if the sound disappears then indeed the capacity of the motor is deteriorating...take out motor and clean bushing and lubricate.. also realign belt ..
Jun 20, 2009 | Maytag PAV2300 Top Load Washer
Chugging like noise during certain cycles
your clutch need to be replaced as does the tub shaft bearings i;m sorry this is not a do-it-yourself job, try to make a deal to trade in your washer
Apr 22, 2009 | GE Washing Machines
I have Kenmore 80 washer and for the last few weeks it has been making louder noises with a little whinning sound during the spin cycle, now it simply will not spin, but it does make awhirring sound on the...
first off empty the washer and check the 2 belts about a foot, from the bottom,to see if there still intact,,,also could need some grease to free up seized parts...gl
Mar 28, 2009 | Kenmore 22422 Top Load Washer
We have a Maytag dryer that is 7 years old. It runs on propane. Recently it started getting louder during the drying cycle and it keeps getting louder. It sounds almost like a buzzing (NOT like the...
Never saw a response to my clarification request, so I hope you have resolved you service question. Without further info, it's hard to give good advice, but you might look at the blower wheel to see if it is spinning loosly on the motor shaft. That will make noise, and usually continues for a few seconds after dryer shuts off.
Sep 04, 2008 | Dryers
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Loud increasing "ticks" during spin cycle
take the two screws out of the front bottom panel and fill the machine up with water then get a flashlight and turn to spin and if you look at the top of the transmission behind the motor watch for any water flying out it there is that is the cause of the problem if not you have a bad motor
Jan 27, 2008 | Amana NAV5800A Top Load Washer
Washing machine is louder then normal on the spin cycle.
This sounds like the rear bearing is going. After getting louder, the next problem is grease appearing on your clothes during the spin cycle. This is a very major repair.
Jan 10, 2008 | Kenmore 43042 Front Load Washer
Amana spin cycle
it sound like the motor is bad,
Dec 31, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Noise during spin cycles
GE WPXH214ACC Washer drum makes loud noise when spinning sometimes. We've had it since 2005 & never had this happen before. Washer is level, must stop & redistribute clothes to correct. Just started happening now.
Oct 12, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
