Question about Amana Dryers
Amana Dryer LE7111WB (BOM: PLE7111WB)
My Amana dryer is making a terrible noise when it runs. It squeaks and groans loudly as the drum turns and dries the clothing. I don't want to take it apart unless I know I have the parts to fix it. Can someone help?
Amana Dryer
Model Number: LE7111WB (BOM: PLE7111WB)
SN: S948048780
  • 1 more comment
  • Chaz Conrad
    Chaz Conrad Nov 07, 2008
    I'm listening to the dryer now. It squeaks repeatedly and grinds, both to the same rhythm; about 10 beats per second, and is very loud.
  • Chaz Conrad
    Chaz Conrad Nov 21, 2008
    Take the drum out and replace the drum rollers. Check the drum glides and the glide pads which are on the housing that supports the front of the drum.
    Most likely drum rollers.
    http://www.repairclinic.com/SmartSearch/...
  • Chaz Conrad
    Chaz Conrad Dec 06, 2008
    It was the drum rollers. I purchased and installed some other parts just for peace of mind though it wasn't necessary. The dryer is surprisingly easy to get into once you try it. The drum rollers are back there, but quite simple to replace, too.
    You guys are a wealth of help. Thanks!
  • 210 Answers
SOURCE: squeaky dryer
Depends how technical you are. More than likely it is the rollers (depending on who made the Kenmore). Go to www.apwagner.com and you can get the parts there. Or if you are unsure about taking it all apart, call for service.
Sgt 48
Posted on Jun 03, 2008
Illeagle
  • 525 Answers
SOURCE: GE Dryer makes an intermittent noise when drum is turning with clothes
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
TheMobilian
  • 8220 Answers
SOURCE: The dryer is making a terrible squeaking sound.
That my friend is the sound of metal to metal on the rear drum bearing. The drum has a ball mounted on the rear of it affectionately known in the biz as a trailer ball. It rides in a grease slathered plastic bearing. The bearing is mounted with a metal bracket. Over time the plastic will wear down and the ball will begin to meet the metal mount.
The mount will begin to act like a guillotine and actually eventually cut the ball off 85a72c7.jpgand the drum will fall into the heating element and the resulting massive breakdown only occurs on a sunday night. LOL
Posted on Jan 20, 2009
  • 479 Answers
SOURCE: Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Posted on Aug 11, 2009
vostendorp
  • 347 Answers
SOURCE: I have an Amana Designer
Without seeing the pieces of metal I would think that they came from the front bulkhead, which is what supports the front of the drum,if it has made the surface of the bulkhead rough it will need to be replaced along with the front seal....
Posted on Aug 12, 2010
GE 5 Cycle Automatic Heavy Duty Extra Large loud noise
All ge dryers have a center bearing on the back side of the drum and drum glides on the frontside. The glides make a scrubbing sound when bad and the drum is hard to turn. The rear bearing does a squeak thang when the plastic bearing wears thin and begins to make metal to metal contact between drum mount and rear bulkhead mount. It is an easy fix but the drum gotta come out. here is my pictorial page that shows how with videos and repair pix:
Paw Paws GE dryer repair page
http://appliancejunk.blogspot.com/2011/09/late-model-hotpoint-dryer.html
http://appliancejunk.blogspot.com/2011/08/hotpoint-dryer-eating-clothes.html
Jan 09, 2013 | GE 5.8 Cu. Ft. Extra-Large Capacity Gas...
Have an older model amana elec dryer, amana no 10380120, starting making terrible loud noise and not turning clothes. please help
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Dec 10, 2010 | Amana Dryers
My dryer makes terrible noise when tumbling. It is a loud squeaking noise. Is it a belt that needs to be replaced?
Loud squeaky noises are usually a dry bearing--in this case, probably the one(s) that hold up the front of the drum. Open the top to inspect, then remove the front panel to replace or repair. Hope this helps!
Oct 23, 2010 | Frigidaire Dryers
Very loud squeaking noise - like a noisy loose fan belt on a car.
The dryer needs to be rebuilt, new drum belt and drum rollers to cure this problem.
Mar 24, 2017 | Frigidaire FDE336RE Dryer
My dryer works right it's just when it's running
Usually lound screeching and squeaking noises are caused by dry drum rollers. You need to lube the rollers or replace them. When I say lube the roller I mean the shaft and bearing part of the roller.
Sep 24, 2009 | Hotpoint Dryers
Maytag Neptune Dryer makes loud noise while drying.
heatman101
ergfgfjk
Sep 06, 2009 | LG DLE2514 Electric Dryer
Candy cic60 condenser dryer
The drum itself turns on an axle or sprocket. It may need to be oiled. The motor that turns it may be going bad. The windings and bearing could be bad. I assume it is drying O.K.
Feb 04, 2009 | Candy CDC266 Dryer
Loud Noise
heatman101
879dgyj
Dec 18, 2008 | LG DLE5932W Electric Dryer
Dryers Logo
107 people viewed this question
Top Amana Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you an Amana Dryer Expert? Answer questions, earn points and help others
