Question about Roper RAS8445KQ Top Load Washer
I have roper washing machine
It is not draining water, after rinse i dont see it go to rinse
I don't know if the agitator is turning or not but the whole agitator is lose from the bottom part of the agitator. The washer also leaks. We have checked all of the hoses etc and there is no problem with that. We wonder if the leak isn't coming from the agitator being lose.
Posted on Nov 14, 2008
How to get Roper Washer to drain & spin? My Roper washing machine is only a few months old and now it won't spin out or drain water at any level. I even tried just rinse & drain. Model #...
since it is only a few months old, it must be under warranty. So try that first before touching any repair job lest you void the warranty.
Jul 30, 2014 | Roper Washing Machines
My 5 year old Roper washing machine fills up, washes/agitates the cloths, drains them when the washer get to the rinse line to start the rinse cycle it stops, and all I hear is a humming. The machine will...
I'm not familiar with roper washing machines so I'll ask the question does it have two fill hoses. Most European machines now only have one fill. If it has two then it sound like the machine takes the initial water from the one fill and the rinse cycle water from another. The humming sounds like the valve for the other fill needs replacing. These are quite inexpensive and easy to fit. Power off.. remove lid ....switch of water...take out valve when you establish which one is affected and replace
Oct 17, 2013 | Whirlpool WTW5700S
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Where is the reset button on Roper washing machine top load water fills but nothing else happens
try to turn the timer dial to rinse and spin, and then see if the water will drain
Jul 07, 2011 | Roper RAS8445KQ Top Load Washer
I have a Roper washer. It filled with water to wash, but when it came to draining the water to rinse, it just stops. It will add water on rinse cycle, but it will not drain or spin.
Sounds like the lidswitch. As a safety, the tub will not spin if the door is up (open). In turn, it will not drain if it wont spin. This is a common problem with whirlpool washers. You can go to searspartsdirect.com to get the breakdown and order the part.
Feb 17, 2010 | Roper RTW4300SQ Top Load Washer
Washing machine stops at rinse cycle
Sounds like a faulty lid switch. The switch will not allow this unit to drain/spin if the switch is faulty.
Jan 05, 2008 | Roper RAS8445KQ Top Load Washer
Washer problems
if it wont drain , check your lid switch, check out your motor coupler, if it will not agitate and spin, replace your motor coupler, if it agitates and dont spin, replace your lid switch.
alot of times the washer will drain but we hurriedly cut it off when we hear noise or the water is out but it never spinned and so the clothes are soapy wet...
Nov 12, 2007 | Roper RAX7244KQ Top Load Washer
ROPER RAS6233KQO T.L.W.-Won't fill/rinse with cold water
Most washers have a small screen at the water inlet valve. They can be accessed simply by revoving the hose from the back side of the washer, using a small screw driver you can carefully remove the screens and clean them out under a faucet.That may be all that is wrong.
Oct 27, 2007 | Roper RAS8445KQ Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
106 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
