Question about D-Link RangeBooster G WBR-2310 Wireless Router (WBR2310)
D Link model 2310
My Router has lost internet connection. I have one computer running off this router. I use a speedstream 4100 modem to connect to At&T DSL service. The modem works fine, if I have it directly connected to the "home computer", but when connected to the router, neither computer has an internet connection.
I have reconfigured the router from the "bedroom computer" that uses the router.... and that did nothing.
Any suggestions of what I might try next?
  • 52 Answers
When you connected your PC directly to the modem, were you able to get the internet working automatically or did you have to run a dialup-like connection?
If it worked automatically, try this:
1. Connect a PC to a numbered port of the Dlink router (don't connect the modem to the router nor the PC)
2. Open Internet Explorer and enter http://192.168.0.1 on the address bar. This should then ask you to login. (restart the router and the PC if nothing happened then try again)
3. Enter admin for the username and blank for the password
4. Once you're on the Dlink Setup page, click on Network Settings on the left panel.
5. Change the Router IP address to 192.168.2.1 then hit Save Settings
6. Now, connect a cable from the Speedstream modem to the WAN port of the Dlink router then check if your internet is working from the wired PC.
If its still not working, turn off the modem and the router and then power the modem first (wait for the lights to be stable) then plug the router.
Hope this works for you. Goodluck!
Posted on Nov 07, 2008
    Scholar:
  • 102 Answers
Go into the router configuration page like this 'http://192.168.0.1' (check the manual here for the default IP to go into your particular model) make sure on the WAN page your ISP settings are correct, they have to match to correctly provide any computer to have an internet access, also make sure that your router is configured for auto DHCP settings meaning it assigns local IP addresses to each machine it is connected with. Also make sure on the wireless side you ahve configured the WPA or WPA2 security with TKIP/AES encryption. You can put a pass phrase into the wireless settings to make it more secured.
Once the WAN portion is done properly your router will start assigning the IP addresses to all local computers and all should have internet access. Hope that helped!
I'm trying to install and configure my TrenDnet router but first I had to set my modem to bridge mode to use the router but when in bridge mode my SpeedStream won't connect to the internet. Why?
In Bridge mod, it means that you have to configure a Broadband connection on your computer to be able to connect to the internet.
To use your router with the speedstream, the Trendnet must not be used in bridge mode. Configure it to be connected to internet, then plug the speedstream to it.
Apr 28, 2011 | Siemens SpeedStream Modem (4100) (SS4100)
How do I configure for wireless?
Siemens Speedstream 4100 is just a modem, if you want to connect to the internet wireless you will need to set up your speedstream modem with a wireless router.
It can work with almost all the wireless routers available in the market, but I would recommend a Linksys wireless router.
Dec 31, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
No access through D-Link DIR635 - Modem speedstream 4100
Hi! try to reset the router for 10secs that is located at the back of the router..then connect your computer directly to the router and pull up the browser and type in at the url:192.168.0.1, it will ask u the username and password, username by default is admin and the pass, just leave it blank, then it will show the setup page of the router..try to check this first in order for you to setup the router so that it will talk to the modem: if u bypass the router it will work, the reason why the modem wont talk to the router bcoz the router is not properly setup.. if you are using a cable modem from ur cable company provider- u need to do a mac clone on the router u have to clone the mac address of ur computer. normaly the mac of ur computer is the one register to your cable company and on the setup page of the router just selct on the internet setup, dhcp after clonning the mac address of your computer. u need to connect ur computer directly to the router and then after doing the process connect the router to the modem. if u are using a username and password, u have to use the pppoe settings on the router, if ur isp set a static ip , set it up to the router, to check the ip setting of your isp.. connect the computer directly to the modem and check if u have internet.. then click on start, run and type cmd,it will give u a dos prompt and from there type ipconfig/all and it will show u the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
Aug 08, 2009 | Computers & Internet
Will there be a problem adding Siemens speedstream 4100 to DSL?
u need to setup ur router to program it so ocnsequently u can connect ur pc to the router instead to the modem
1) so u need to prgram ur router by configure the required settings
2) u need to write down ur username and password inside router program
3) then u can be connected to the internet via router
good luck
Jul 27, 2009 | Computers & Internet
Linksys wireless G router not working when connected to dsl modem
hey there, can u acces the gateway of the router
192.168.1.1 than enter ur login & password
than reset the router to fabric setting when done go back in the router and configure it as u like to have it
Jan 04, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Very slow, or no connection to internet, on wired computer, not wireless one
Yes, it would be best to reconfigure it. Try the following but note.. resetting the router will erase all previously given settings.
First, reset the router - when the unit is on, press the reset button (using a paper clip) for 20 seconds then let go of the button. Once the WLAN light is solid, it means that router has rebooted.
Go to a computer wired to the router and open Internet Explorer, enter http://192.168.0.1 on the address bar. Enter admin for the username and leave the password blank.
Once you're in the Dlink page, this is where you can configure your Internet and Wireless settings again. Just run through the setup process (as if you just got the device out it's box).
Nov 06, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Oct 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 4200 and Linksys WRT54G router
there are several types of patch cables, but basically there are 2 general types: one for servers (they keep the websites) and for computers.
the servers need to communicate with each other in order to be in sync. so some cables are switched in one end.
The computers just want to receive and send data; it does not care about sync.
Aug 05, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Wireless adapter ......need something compatible with a siemens router
you probably need another router such as linksys, netgear, belkin.. etc.
Nov 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
D-Link RangeBooster G  WBR-2310 Wireless Router (WBR2310) Logo
297 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
