Question about SySTOR Systems (400S52) Burner
Oil Burner Will not Ignite
Changedd nozzle as there was dirt in the nozzle filter. Furnace will not ignite!
  • Anonymous Jan 05, 2009
    I HAVE A RIELLO 40 F3 HEAD, MOTOR GOES ON BUT CANNOT IGNITE -
    (SEE FLASH AT END OF TUBE) - I CHANGED FILTER, SUSPECT CLOGGED NOZZLE OR DEFECTIVE ELECTRODE. WANT TO KNOW THE CORRECT PROCEDURE TO CHECK AND\OR REPLACE THESE PARTS.
    CAN YOU HELP??
    THANK YOU
    ANGELO
  • Anonymous Mar 05, 2009
    Same problem.. Resolved with changed nozzle + filter
My burner will not light mpdel 701-crd. carlin
Posted on Jan 02, 2009
First do you have enough oil? do you have one line or two? and did you bleed off the pump after putting the nozzle in?
Posted on Nov 14, 2008
Burner shut off then there is a clicking sound, burner ignites again
this is normal the clicking sound you hear is the system starting another cycle for your furnace to ignite the burners, then turn on tbe fan blower.
Sep 27, 2017 | Heating & Cooling
Oil dripping from bottom of burner
Remove the electrodes & nozzle assy
Clean nozzle & check that it is tight
Sand electrodes clean,file ends flat
& set gap
Check the pump for leaks
Mar 02, 2013 | Cars & Trucks
Weil mclain furnace always locks out or latch up have tried button always repeats. oil in tank
Your problem could be in a number of areas. Have you checked and/or changed the filter? If you've had a recent oil delivery, there's a good chance it stirred up the sediment in the bottom of the tank and caused the filter to clog. Likewise the nozzle could be clogged. I would check those two items before anything else. After that, it could be a bad flame sensor or, if it doesn't ignite at all, a bad high voltage ignition coil.
Jun 21, 2011 | Heating & Cooling
Rheem Highboy Oil Furnace runs, then shuts down. I throw in a lit paper to burn off oil residual from failed start. Hit 'Reset' button and furnace starts up. It may start up by itself for the next 3...
Oil furnaces have certain items that routinely go bad or need adjusted to work properly.Some of the common things are nozzle, then gap and location of the igniter,then last is the fire eye. You can see all of these items by pulling the burner tray out. The nozzle delivers the fuel in two ways more or less, first is spray angle then second is the rate or GPH. Nozzles are to spray an atomized mist this means no heavy droplets of fuel. If you have large drops of oil chances are a new nozzle can help you out, please pay attention to spray angle and GPH. The igniter is next, after time they will wear and you can clean the rods and reset the gap to specified distance, that being said it also needs to be a certain distance from the atomized fuel to ignite properly all very important. Then last is the fire eye it tells the furnace that a flame is established and to deliver fuel or flame out and shuts fuel down. These will build carbon deposits at times so simply clean off the deposit and clean the lens with a soft cloth and windex reposition put the burner tray back in hook up the fuel line and off you go.
Dec 20, 2010 | Heating & Cooling
I had the oil tank filled and the furnace stopped working, I primed the furnace and it still wont work, It seems like the furnace wants to start,but it keeps stalling out. Is it a problem with the ignition...
Just had the tank filled ... Im getting the idea you burn one or two tanks per year? I would suspect sediment was stirred up in the tank and your filter is not clogged. Do you have your burner professionally serviced each year or do you do the work? For me ... I get it serviced ... they adjust the spark ... put in a new nozzle ... new filter ... clean the burner ... fire box and stack and I never have a problem.
Back to your problem ... I think if you replace the filter ... you will be back in business.
Thanks for your interest in FixYa.com
Oct 06, 2010 | Heating & Cooling
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
I have a riello burner for my central heating system. When i turn the heating on the burner ignites for a few swconds and then goes out.... the burner tries to re-ignite and the same happens. I have...
Replace the nozzle, don't try and clean it. After the burner runs a few seconds, do you have to reset the control (red button) before it will start again? Does it sound like there is a pulsation in the flame when it starts or it is running out of oil? You may have a bad ignition control. Start with the small stuff, nozzle, strainer filter, oil tank filter and then work to the more complicated.
Aug 01, 2008 | Heating & Cooling
Burner does not ignite when turned on.
No, it is most likely the contact problem emerging from dirt that catches on burner (spilled, grease, oil, milk etc.). Take burner off, scrub it and clean it. Same goes for its seat which is usually made of brass. They must have metal to metal contact with no dirt in between acting as isolator.
Apr 08, 2008 | Dacor Preference SGM365SS Gas Cooktop
Computers & Internet Logo
1,932 people viewed this question
Top SySTOR Systems Computers & Internet Experts
David Payne
David Payne
Are you a SySTOR Systems Computer and Internet Expert? Answer questions, earn points and help others
