Question about Logitech Cordless Desktop MX3200 Laser Keyboard Mouse
Clock reset how do i reset the clock on a logictec mx3200 keyboard?
  • Anonymous Nov 10, 2008
    cserdfcwsezdfceswrdferfdgverfdvedrfgvtdfgvetrfd
    President:
  • 2,712 Answers
To adjust the LCD's time and date:
  1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
  2. Press (FN + F10). You are now in 'Set mode' (you can exit this at any time by pressing the Esckey).
  3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
  4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
  6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
  7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
The time and date on the LCD should now be displayed properly.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you resolve your problem.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Nov 07, 2008
Your solution was right on the money - Thank you!
Scott R .... Atlanta Ga.
Posted on Nov 13, 2008
Keyboard clock
1. press the "fn" key (just below the question mark key) + F10
2. press F10 to step thru hour, minute, month, and day
3. press F10 to exit setup
or go to logitech web site and view the ms3200 manual (a pdf of the instruction sheet that came in the original package).
May 04, 2009 | Logitech Cordless Desktop MX3200 Laser...
Mx 3200 keyboard runs but won't type
windows xp info.
go to start,
control panel,
systems,
hardware,
device manger,
click on x at keyboard see your keyboard there right click delete keyboard shut down and reboot leave keyboard plugged in...and it should find and reload the keyboard.
if this does not fix the problem..shutdown the computer unplug the keyboard and mouse...reboot the computer and let load all the way...I know you can't do nothing about signing in or working on it
but let load all the way after finished loading push button to power it off are unplug it...then replug the keyboard and mouse and boot it back up should fix it...
Apr 05, 2009 | Logitech Cordless Desktop MX3200 Laser...
Time and date wrong on keyboard
To enter the date and time setting format,press the FN key and the F10 key at the same time.
Hope it works for you.
Mar 21, 2009 | Logitech Cordless Desktop MX3200...
MX3200 Cordless Keyboard alarm clock
Hold down the FN button (next to the right CTRL button) and press the F11 button.
Jan 31, 2009 | Logitech Cordless Desktop MX3200...
I have a mx3200 cordless keyboard that has a clock and date window. The alarm clock goes off at 2:00pm how do i turn it off? Do you have a manual I can download?
got this off the logitech forum, The only instructions that I can find (which came with my relatively new pc) are on a large "Installation Guide," the most pertinent information from which is about setting the time and date: "To enter time/date setting format on the keyboard LCD, press the FN key and F10 key simultaneously." Also "LCD: Mode (F9): switch mode from Time/Date to Alarm to Timer to Character Count. Set (F10): press to set Time/Date, Alarm and Timer. Change batteries one by one to keep LCD settings. Remove the 4 keyboard batteries to reset Character Count to "o." Bell (f11): put Alarm On or Off. START/STOP (F12): start 01 pause Timer." The Logitech program group (should be on your Start menu) will give you further information for identifying keys, and for formatting the keyboard and mouse. Good luck.
Dont lite up at all cant even see clock
Normal 0 Press the Receiver button (and the lights will start flashing.
Then if the Keyboard isn't working, press the small RESET/CONNECT button on the back of the board to connect the keyboard to the receiver.
Hope this helps. Bud
Jan 04, 2009 | Logitech Cordless Desktop MX3200 Laser...
I bought this keyboard and mouse last year and never lite up cant even see the clock whats wrong w it has new batteries
If the MOUSE isn’t working, push the small RESET/CONNECT button on the back of the mouse to connect to the receiver. Then they should work okay.
Keyboard
Go to
this page on the Logitech support site
and follow the seven steps to adjust the LCD time and date on your Logitech MX3200 keyboard.
Don't forget to rate this solution once you've tried it !
Apr 28, 2008 | Logitech Cordless Desktop MX3200...
MX 3200 Cordless Laser Keyboard - Logitech
Press the FN key and *at the same time* press the F10 key for 1 second.
The first part of the time should start to flash.
Use the up / down keys to change the hour, then press TAB. The minute figs. should now flash. Use up/down to change the minutes and press TAB.. do the same with the date and month etc, you can also set 12h or 24h clock.
When you are finished press ENTER.
Nov 24, 2007 | Logitech Cordless Desktop MX3200 Laser...
Mx3200 clock re setting
Hold down FN and F10 which says set in blue. This allows you to reset the clock.
Nov 04, 2007 | Logitech Cordless Desktop MX3200 Laser...
Logitech Cordless Desktop MX3200 Laser Keyboard Mouse Logo
109 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
