Question about Baumatic B205SS Stainless Steel Electric Single Oven
Oven fault code
Oven now has F4EO OR F4ED ON DISPLAY oven does not heat but fan and light work ok , any ideas ta john
  • lnubs99 Aug 22, 2008
    lost the manual, had a power cut and cann't reset the timer, it comes up as fw34 cooker model f4e0
  • Anonymous Mar 15, 2014
    f4eo on display oven will turn on but wont heat and keeps beeping
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 112 Answers
I think your thermostat is broken, try replacing it with a new one.
Posted on Dec 12, 2007
I have a Bush AE56DA electric oven, the main oven has stopped heating up. Also the oven light and thermostat light have stopped working. Everything else works fine. Any idea's? Thanks.
This sounds like a regulator problem, now there are the switch or a built in behind the cooker. WARNING DO NOT OPEN ANY PART OF THE OVEN ISOLATE THE MAINS FIRST.
You will need a tester, multi-meter would do. check the switch for continuity check the heating element there may be a hole in it, its very difficult to see slight Gray Colour just at the hole, find and inspect the fan motor if there is no continuity after disconnection of wiring between the winding terminals, on most models you have to remove the fan before you can inspect the heating element, but there are a few the other way round. Hope this is helpful .
Regards
John
Nov 02, 2014 | Ovens
AEG double oven/grill stopped working
It appears the oven has shorted out. Try checking the breaker box and see if any switches have been flipped. If this is not the case a new oven is in order.
Jan 24, 2014 | Ovens
There is no heat coming from the microwave part of the oven, although the grill, convection oven, motor, light and fan all work. The 8 amp fuse on the board where the mains cable enters the oven has blown....
Hello, If everything comes on when it is started, like the light in the cavity and the fan (which one can hear running), and the timer counts down but it doesn't heat, the problem is probably isolated to the high voltage section of the oven.the magnetron i guess is kind of faulty and this is the most expensive part in a microwave oven.
If the display is on and the oven won't come on and run, there may be a problem in the door interlock system or the thermal protection system.
wish yo good luck,
take care.
Jul 19, 2010 | Ovens
My oven is not heating up but the fan is working - any ideas?
I dont know your model but generally the problem would be that the ring element around the fan has blown or less likely the thermostat has failed.Normally if you can see the light on the control for the oven temperature control light up and can hear a click from it as you turn up or down the the thermostat should be ok.You will have to get the ring element out and check with a multi-meter if it is blown and replace.
Hope this helps.
May 20, 2010 | Ovens
I have a creda collection C362E everything seems to work except the main oven, any ideas?
For all Free appliance repair videos visit our VIDEO TUTORIALS
You-Tube video "pEhRqdvpiJM" placeholder (do not delete)
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 14, 2010 | Ovens
FAN ASSISTED PART OF OVEN DOES NOT WORK - ALL OTHER PARTS OF OVEN WORK
3ce67db2-692b-4b64-9a3b-5ffc185dfc29.pngIf its convection , take the back panel off inside the oven an change the element . Ta daaaaaaaa !
Dec 26, 2009 | Bosch Ovens
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
BLANCO Stove Not heating up
Resolved, I took the fan cover off and the round elementjust fell apart, so I'll get a new element and all should be OK.
Regadrsd,
john S.
Jun 18, 2009 | Stoves Ovens
Baumatic B205SS Stainless Steel Electric Single Oven Logo
806 people viewed this question
Top Baumatic Ovens Experts
ashburton
Starnley Johnwells
Starnley Johnwells
Are you a Baumatic Oven Expert? Answer questions, earn points and help others
