Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag MAV6000 Top Load Washing Machine
OUR MAYTAG MAV6000AWQ WASHING MACHINE WILL NOT SPIN OR AGITATE. THE MOTOR SEEMS TO BE WORKING OK THE BELT IS FINE AND TURNING THE MACHINE WILL FILL AND DRAIN. DO THESE MACHINES HAVE A CLUTCH? OR IS THIS A TIMER PROBLEM MENTIONED BELOW
  • nobbsy5 Nov 08, 2008
    maytag will drain not spin
  • 61 Answers
Tip the machine back remove the belt try to turn the drive pulley manually . sorry the larger pulley in the centre. if you can turn it counter clockwise and feel the inner drum moving then the thrust bearing is ok. if not you may need to replace it.Also a bad lid switch can cause this problem.
Posted on Dec 18, 2008
Washing Machine doesn't spin/drain.
Did he overload the unit
The belt may be moving but are the pulleys still locked to the shafts
Use a dab of white out, paint, colored marker and then watch the shafts to see if they are moving.
Could have broken a shaft key.
Feb 28, 2010 | Maytag Atlantis MAV6000 Top Load Washer
My maytag atlantis will not agitate it runs through all the cycles it will spin but will not agitate. The belt is intact.
WELL THATS BECAUSE ITS AGITATED WITH THE XTRA LOAD YOU PUT IT THROUGH WHEN YOU ARE SITTING ON IT NOW I KNOW ITS FUN BUT SPIN CYCLE IS ONLY DESIGNED FOR WASHING CLOTHS...I HOPE THIS ADVISE FIXED YOUR PROBLEM.
Oct 31, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Matag Atlantis MAVT634 will not agitate
Does the motor start and run for agitation with the belt connected?
Jan 29, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Agitater does not spin
the transmission needs to be replaced
Jan 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine fills, but won't agitate
Lid switch if its a Maytag Alantis... You said you have a GE top load in the start of your problem and ended witha maytag?
Dec 18, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washing machine won't agitate.
Depending on type of washer, typical top load Maytag, motor turns in opposite direction for wash and spin. Your problem will no doubt be the transmission.
Nov 01, 2008 | Washing Machines
Maytag mav6000awq repair manual
No I don't. Also I couldn't find the model on the pull down but the Maytag is 745G model LAT8650AAL
Oct 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Motor will not spin both ways
Starts fine then stalls, I would check the belt,gear case and also for a seized pump bearing. Pull the machine out and remove the access panel with a 5/16 socket and put it into spin, try to watch as you start the cycle. Then if you don't see any problems tilt the machine back and examine the belt for wear, glazing, cracks and rotate the belt to find any frozen items, gear case and pump.
Oct 10, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6000 Top Load Washer Logo
272 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
