Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printer doesn't print well
I just replaced the ink cartridges, I've done this before with no problems, but this time the printing is very poor. I was told to replace "color" and I did, and had poor quality, so I replaced "black" too, and still very poor quality.
Do I need to calibrate or clean something??
  • Joyce Vitzthum Nov 07, 2008
    My cartridges were Kodak originals, and the prints are faded looking. Thanks
My printer is printing light/faded copies, I changed both the black and color cartriges but it is any better,
Posted on Nov 07, 2008
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
try to open and
remove the cardtridge and
clean up the nozzle use alcohol
and cooton buds
    President:
  • 2,712 Answers
Hav you replaced with original cartridges or 3rd party/refilled ones? This is a common problem when using generic/refilled cartridges. Let me know that first..
When you say poor quality, do you mean faded printouts, or broken print? Kindly explain in detail, so I can assist you further.
  • Swilin Sampson
    Swilin Sampson Nov 07, 2008
    Using the printer software, do a nozzle check and a deep clean. You could also try to clean the nozzles manually using a Q-Tip and some isopropyl alcohol. It could be a case of clogged nozzles. However, since you said that these cartridges are new, I doubt that would be the case unless you haven't usd the printer in a long time.
    Also, in printer properties, make sure that you have not selected 'Economy' or 'Fast Print' mode.
    Should the steps above fail, try reinstalling the printer driver.
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
Won't Print Color Ink
INK PROBLEM
Inkjet printers need to be used frequently to prevent inkdrying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages,then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer thanreplace the print head.
May 19, 2012 | HP PSC 1510 All-In-One InkJet Printer
I'm having a problem with the ink magenta on an IP4500 Canon Printer, it's not printing any magenta even with new cartridges and I've done all the maintenance checks!! Help!
there are small metal spring contacts between the cartridge holder and the cartridge itself, these send the signals to the print head via the cartridge holder. Over time, as a print cartridge moves from side to side during printing these flatten out and no longer come into contact with the cartridge. Find the contacts behind your magenta colour cartridge and re-tension the spring metal contacts so they once again contact the metal faces on the cartridge. They maybe hard to find as they will be in the place where the cartridge goes, use the flat copper faces on the cartridge to give you a clue as to the position of the contacts in the holder.
Apr 16, 2012 | Canon iP4500 Photo Printer
I have try to print but its not printing. i've allready fill the ink still the page come out blank.
It could be due to the refilled cartridge that you are using. Refilled cartridges tend to degrade print quality and cartridge performance.
You can try to clean the cartridge nozzles. Please follow the steps below to fix the problem:
  1. On the printer control panel, press Copy.
  2. Press Options until Maintenance is highlighted.
  3. Press the right arrow until Align Cartridges or Clean Cartridges appears, and then press Select. A test page will then be printed forcing ink through the cartridge nozzles and clean them.
Try to print your document again to verify that the cartridges are working.
If that doesn't help, I would suggest you replace your cartridges with new genuine Lexmark cartridges.
Aug 17, 2011 | Lexmark X6150 All-In-One InkJet Printer
I've got a HP C4780 printer which I have had for around a year but only used about 5 or 6 times! Despite the ink cartridges having ink in them, the black cartridge is not printing at all. Not even a...
The ink solidifies right behind the micro printing nozzles. The only way to attempt to rectify this is to dip the print face into some warm (not hot) water for a minute or two, and dry after wards. If the cartridge recovers, Yippee, if it doesn't, replace.
Common problem. Be thankful it isn't a Canon or Epson, which entails replacing a seriously expensive 'print head'.
Jun 08, 2011 | HP PS C4780 All in One InkJet Printer
Hi. After using budget ink cartridges, the print quality has been very poor and not printing the correct colours it suppose to. I've performed many print cleaning options but it is still not rectifying...
If the cartridges you're using give you poor results, throw them away cos you don't know what other damage they might be doing.
I'm not saying don't use budget cartridges, just bin them if they don't work properly and get a different brand.
Alternatively, are cheap cartridges worth all this hassle?
May 30, 2011 | Brother MFC 6490CW InkJet Printer
Streaky printing
At most cases of printer, especially which have done refill at cartridge, print quality is poor or streaky. Many factors influencing this printed result. To overcome print quality is poor, maybe following tips can usefull to prevent printed pages are missing lines or streaky.
First step is ordinary to be done many people when print quality is streaky that is doing cleaning. To get good printed result, sometime this facility is used more than once.
Use Ink Refill with Quality Nicely
For printer have refilled, sometime the quality of printing is also influenced by ink. If will fill your printer again, use ink which the was quality of nicely. I have tested some refill inks at cartridge which have been ascertained still nicely ( sorry: I do not want to publicize result of this attempt). In the reality result make me surprise, there ink of refill making the printed quality is crummy. To choose ink refill read following tips :
  • See viscosity of ink, every merk of ink refill have difference of viscosity. Don’t use Ink refill too jell. Difference of this viscosity is no measure reference viscosity of ink from factory maker of printer
  • Don’t fear to try some inking merks. Done this, you’d find refill ink fitt with your printer. I now only using one merk of refill ink ?.
  • This suggestion of forum, but I still not yet proved. May believe or not. Good ink aroma of soft usually.
Change Original Cartridge
This is last choice. A lot not like to do this ways, because price of original cartridge still costly. Alternative, you can use compatible cartridge which the was price of cheaper than original cartridge. At newest printer, usually there are two until four cartridge in one printer. And price four same cartridge almost at the price of printer even there are some costlier.
Let me know !
Thanks
Fame !
Apr 02, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Poor or no printing
When inkjet printers are not used much, the ink dries up in the cartridges and on the print head, causing poor printing, and, as the dried ink builds up, no printing at all. no matter how many times the cartridges are changed, the dried ink won't work out. Some people have had luck with this problem by using alcohal and a q-tip to clean the print head. If that doesn't work, you will need a new printer.
Feb 12, 2009 | Lexmark JetPrinter X1185 All-In-One InkJet
Installed all new ink cartridges and now poor printing results
Dear louis,
You have done right thing by cleaning the print head. If the print head still clogged after repeatedly cleaning, It seems that the print head need to be replace with new one. Make it sure by printing nozzle check pattern. Is it good or not?.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 28, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Black won't print!!
Hi denzirelli, Apparently several reviews of this printer say it is known for poor print quality when dealing with graphics AND the tubes can become blocked. As far as troubleshooting goes if you haven?t done so already purchase a new set of official Brother ink jet cartridges, black and color. The newer ink jets are a lot smarter and remember the last couple of cartridge serial numbers. If that doesn?t work then try running the nozzle cleaning utility a couple of times. If that fails call the Brother and let them walk you through the troubleshooting process. I don?t suggest you lie, just don't volunteer the fact that you were evil and tried to deprive them of their profit. Worst case they won?t do a warrantee replacement, best case is you?ll have a working printer. If you don?t want to pursue the above option or if tech support won?t help then we?re back to troubleshooting again, when you say it doesn?t print black does that mean colors do print? If that?s the case then I suspect the black tube or the nozzles are blocked. From what I?ve read it?s a little bit of a pain to remove the print head but the key is not to disconnect the tubes. Remove the print head and the cartridge container as a unit. The ribbon cables have to be unplugged from the circuit board. Disconnect the belt and you should be able to take the print head out and clean it. Let us know how it turns out and don?t forget to rate the posting.
Jan 05, 2007 | Brother MFC 210C All-In-One InkJet Printer
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
385 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
