Question about Hitachi 61SDX01B 61" Rear Projection Television
Automatic widescreen mode
When changing from hi-def channels to 480p resolutions(or vice-versa) on my tuner the tv automatically goes to widescreen 16:9 mode and I have to reset it back to 4:3 mode(where I like to view it). Can I get it to lock in to 4:3 mode and not go to widescreen automatically?
  • b-stang2 Nov 07, 2008
    hitach tv 61sdx01b
  • b-stang2 Nov 10, 2008
    thanks, but i still can't get it to stay. no big deal just a lot of aggravation.
  • 44 Answers
If memory serves, no. If I'm wrong, the would be a setting in the menu or the remote to change it from 4:3 to Set by Station or Automatic. Might say Format.
Posted on Nov 07, 2008
1080p tv stays in 480p mode
Resolution is a slave to the source. It sounds as though the source is only outputting 480p. Go through the menu settings of the source device(bluray, cable, satellite box, game system) and set it to output 1080.
Jul 10, 2012 | Toshiba REGZA 46RV530U 46-inch 1080p LCD...
How do I get my 52inch rca scenium to show 1080 using my ps3
Video Output Settings Adjust the system's video output settings. Select the best output settings for the TV in use.
1.
Check the resolution supported by your TV.
Resolution (video mode) varies depending on the TV type. For details, refer to the instructions supplied with the TV.
2.
Select in_setting.gif (Settings) > in_dispset.gif (Display Settings).
3.
Select [Video Output Settings].
4.
Select the connector type on your TV.
Resolution (video mode) varies depending on the type of connector used.
videooutput001.jpg Input connector on the TV Supported video modes (NTSC region) *1 Supported video modes (PAL region) *1 HDMI 1080p / 1080i / 720p / 480p 1080p / 1080i / 720p / 576p Component / D-Terminal *2 1080p / 1080i / 720p / 480p / 480i 1080p / 1080i / 720p / 576p / 576i Composite / S Video *3 480i 576i AV MULTI / SCART *4 480p / 480i 576p / 576i *1 The video mode options vary depending on the region where the PS3™ system was purchased. In North America, Asia and other NTSC regions, 480i video mode is displayed as [Standard (NTSC)]. In Europe and other PAL regions, 576i video mode is displayed as [Standard (PAL)]. For details, refer to the instructions supplied with the product.
*2 D-terminal is a connector type used mainly in Japan. The resolutions supported by D1-D5 are as follows:
D5: 1080p / 720p / 1080i / 480p / 480i
D4: 1080i / 720p / 480p / 480i
D3: 1080i / 480p / 480i
D2: 480p / 480i
D1: 480i
*3 Composite is the connector used to connect the AV cable that is supplied with the PS3™ system. S VIDEO is a format mainly used in Japan.
*4 AV MULTI is a format mainly used in Japan. SCART is a format mainly used in Europe. If [AV MULTI / SCART] is selected, the screen allowing you to select the type of output signal will be displayed.
5.
Change video output settings.
Change the resolution for the video output. Depending on the connector type selected in step 4, this screen may not be displayed.
videooutput003.jpg 6.
Set the resolution.
Select all resolutions supported by the TV in use. Video will automatically be output at the highest resolution possible for the content you are playing from among the selected resolutions.*
* The video resolution is selected in order of priority as follows: 1080p > 1080i > 720p > 480p/576p > Standard (NTSC:480i/PAL:576i).
If [Composite / S Video] is selected in step 4, the screen for selecting resolutions will not be displayed.
If [HDMI] is selected, you can also select to automatically adjust the resolution (the HDMI device must be turned on). In this case, the screen for selecting resolutions will not be displayed.
videooutput004.jpg 7.
Set the TV type.
Select the type of TV in use. Set when only SD resolution (NTSC:480p / 480i, PAL: 576p / 576i) is to be output such as when [Composite / S Video] or [AV MULTI / SCART] is selected in step 4.
videooutput005.jpg 8.
Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the in_left_key.gif button.
videooutput002.jpg 9.
Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Output Settings] in this guide.
Source: http://manuals.playstation.net/document/en/ps3/current/settings/videooutput.html
Feb 28, 2011 | RCA Televison & Video
My new set displays only 480p SD on all my HD channels. Am I missing some settings in the menu's or is something more sinister going on? Any help would be greatful, I'm drowning watching sports!
hi,
u can enjoy full hd 1080p video through only ur tv inputs as 2 component video and 2 HDMI. the tv is seted to receive videos up to the resolution 1080p automatically (need not have any setting). just check the output of ur cable box or BD player, is it outputs full hd. if u are using the tvs internal tuner u will only get 480p.
ok
Dec 20, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
I need the product specifications for this model
hi,
u didn't specify any model. any how i am senting speck of the following model. if u have selected model in ur mind, just contact me through fixya. will sent u the specification.
dotclear.gif Olevia 232V General
  • Product type LCD TV
  • Diagonal size 32.0 in
  • Viewing angle 178 degrees
  • Viewing angle (vertical) 178 degrees
Video
  • Technology TFT active matrix
  • Resolution 1366 x 768
  • Display format 720p
  • Image aspect ratio 16:9
  • Pixel response time 8.0 ms
  • Progressive Scan Progressive scanning (line doubling)
  • Widescreen Widescreen
  • Widescreen modes Panorama,
    Full,
    Conventional 4:3,
    Zoom
  • Dynamic contrast ratio 1600:1
  • Comb filter 3D digital
  • Color temperature control Yes
  • HDCP compatible Yes
  • Supported DTV resolutions 1080i,
    720p,
    480i,
    480p
  • Supported computer resolutions 1360 x 768
TV Tuner
  • TV tuner presence Yes
  • Tuner qty 1x analog/digital combo
  • Digital TV tuner ATSC
  • Analog TV tuner NTSC
  • Secondary audio program (SAP) Yes
Audio
  • Sound output mode Stereo
  • Total output power 20.0 Watt
  • Speakers 2 speakers
  • Speaker system speaker type Right/left channel speaker
  • Additional features Auto volume adjustment
  • Speaker form factor Built-in
  • RMS output power 10.0 Watt
  • Speaker system speaker qty 2.0
  • Audio controls Bass,
    Treble,
    Balance
Convenience Features
  • Closed captioning Yes
  • Parental channel lock Yes
  • V-chip control Yes
Connectivity
  • Video interface S-Video,
    Composite,
    Component,
    HDMI
  • HDMI ports qty 1.0
  • PC interface VGA (HD-15)
Remote Control
  • Type Remote control - Infrared
Power
  • Power device Power supply - Internal
  • Power consumption operational 180.0 Watt
Dimensions & Weight
  • Dimensions (WxDxH) 37.8 in x 9.4 in x 22.2 in
  • Weight 35.5 lbs
Manufacturer Warranty
  • Service & support 1 year warranty
  • Service & support details Limited warranty - Parts and labor - 1 year
Dimensions & Weight (Shipping)
  • Width (Shipping) 42.8 in
  • Depth (Shipping) 12.4 in
  • Height (Shipping) 25.4 in
  • Weight (Shipping) 45.4 lbs
Sustainability
  • ENERGY STAR Qualified Yes
Dec 14, 2010 | Olevia Televison & Video
Tv is showing 480p and we want it at 1080p on our new Toshiba 40XV648 40-Inch 1080p 120Hz HD LCD TV Cinema Series.
After searching the owners manual I find that there is nothing mentioned about the screen resolution i.e. 480p to 1080p.
This set is capable of your desired resolution and as far as I can tell it auto selects because it senses the input video and decides which is the best setting for that source.
It's important to understand that you need 1080p video to use it at it's full capabilities. It won't give you a 1080p resolution from a VCR or a standard DVD player. You need a DVD player that is capable of producing a 1080p encoded video. Some satellite receivers are capable of that but you need to make sure you know what resolution that you are sending to the television.
Local TV stations won't usually broadcast HD at 1080p. Your best bet is to use a DVD player that is capable of that high resolution for your best picture.
Please note that what it says in the owners manual about "Resolution" has nothing to do with the 480p, 720p or 1080p signals, your set selects that automatically it will start by selecting the 1080p then goes to 720p then 420p it's dependent on the video you send to the set.
Please note the "resolution" function is actually like a "sharpness" control.
Your video input (tuner, VCR, DVD, games and etc.) is likely your problem.
Mar 30, 2010 | Televison & Video
Model LG52LG70 has a problem when switching from High Definition channels to non-high definition channels, and vice a versa. The tv simply shuts off, pauses for 10 seconds and then turns on. Time warner...
Any high def TV will momentarily go blank when changing from High Def to normal mode. Ten seconds is an abnormally long time for that to take place. If you still have a warranty on the TV I suggest you take it in to have it serviced. Otherwise you will have to pay to have this item checked out. There are a number of issues that might be causing the problem so it will be necessary to have a technician check it out.
Feb 18, 2010 | LG 52LG70 52 in. LCD HDTV
I Have A Vizio 32LCD and my problem is i am trying to get the PS3 to play with the HDMI I have a HDMI cabel hooked up to the hdmi input on the back of the set and it is hooked up to to the HDMI input on...
1. Check the resolution supported by your TV.
2. Select (Display Settings) under (Settings) in the home menu.
3. Select [Video Output Settings].
4. Select the connector type on your TV.
D2: 480p / 480i
D1: 480i
5. Change video output settings.
6. Set the resolution.
7. Set the TV type.
8. Check your settings.
Confirm that the image displayed is at the correct resolution for the TV. You can go back to a previous screen and revise the settings by pressing the button.
9. Save your settings.
The video output settings are saved on the PS3™ system. You can continue on to set audio output settings. For details on audio output, see (Settings) > (Sound Settings) > [Audio Output Settings] in this guide.
Apr 06, 2009 | Vizio L32 32 in. LCD HDTV
Only get 480p
Hi.
Your friend is wrong you will get same resolution of 1080i whether you use component or Hdmi.
But you will need a high def input to tv in order to get this resolution EG high def cable box or satellite.
http://dysonmanuals.llc.nu/
Mar 24, 2008 | Sony KLV-S32A10 32 in. HD-Ready LCD...
SYLVANIA 6620LG TV - DTV??
The ;quick answer is YES, you will need a converter box to receive digital broadcasts. This set has only an analog tuner built-in. That is why it is HDTV "ready" (ready for you to add a tuner).
As for HDTV vs EDTV it is a matter of resolution. Your set is capable of EDTV resolution, which is better than SDTV (standard definition TV) but not quite as good as HDTV. With a digital tuner you will be able to view all digital programming, even HD, and it will look excellent, though not quite as sharp as a set with higher definition.
Feb 14, 2008 | Sylvania 6620LG 20 in. EDTV-Ready LCD...
HD resolutions
Your TV would have to be HD ready and will automatically set itself to 1080i, but if you go into the XBOX 360 console settings' the top menu enables you to change resolution, but if the x box does not recognise 1080i it will not show up. See if 720i shows up as this is still High Def. and also that 60 Hertz is the setting and not 50 hertz
Dec 30, 2006 | Mitsubishi WS-55857 55" Rear Projection...
Hitachi 61SDX01B 61" Rear Projection Television Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
