Question about Copystar CS-1815 Printer
Paper jam 11
I am getting error message paper jam at cassette 1. However, there is no paper jam, it wont even start to print. I am able to xerox copies fine. But everytime I try to print, it gives me the "paper jam" error.
  • 734 Answers
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Turn off the printer.
Step
Remove any paper trays. Inspect them for wrinkled or damaged paper.
Step
Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
Step
9
If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
Posted on Dec 04, 2008
Getting a error message JAM11 on copier CS-1815?
A paper jam in the
paper feed section
is indicated during
copying or printing
(no paper feed from
the cassette).
Jam code 11
Paper in the cassette is
extremely curled.
Check if the feed roller is
deformed.
Defective registration sensor.
Check if the feed clutch
malfunctions.
Electrical problem with the
feed clutch
The above is taken from the sm
Also the feed tyre needs cleaned / changing and or cassette springs need stretching !!!
Dec 03, 2013 | Copystar CS-1815 Printer
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
Feb 24, 2011 | Xerox Phaser 8500/DN Printer
Wont print ready light and alarm light flashing
When the printer "Ready" and "Alarm" LEDs flash as shown, please check the following points:
1.Paper Jam: Clear the paper jam referring to "How do I clear paper jams?"
If the printer does not automatically resume printing, press the control panel button.
2.No Paper/ Misfeed:
-The paper cassette may be out of paper or not properly installed.
-If it is empty, load a new stack of paper into the paper cassette.
-If there is paper in the paper cassette, make sure it is straight.
-If the paper is curled, straighten it before printing. Sometimes it is helpful to remove the paper, turn the stack over and put it back in the paper cassette.
-Reduce the amount of paper in the paper cassette, and then try again.
-Make sure you use paper that meets Brother's recommended paper specifications.
-Reinstall the paper properly, and then press the control panel button. The printer will start printing again.
Dec 06, 2010 | Brother HL 1430 Laser Printer
Xerox 7700. Paper is jamming at lower tray and bypass tray. Will print one page fine but multiple pages it stars jamming
Hello. The Error 11, polygon motor failure is usually caused by the motor controller chip going bad on the mirror motor. We found some of the contorller chips and had them replaced. The refurbished laser units can be seen at: http://www.lpscomputer.com/p-3060-1-116-1110-00-laser-unit.aspx
Nov 18, 2010 | Xerox Phaser 7700 Laser Printer
The paper jam indicator on in error?
So it sounds like the machine is not feeding paper from the paper cassette. This is a common problem.
There are 2 possibilities. 1 easy and one a little tougher. The simple fix is cleaning the paper feed tires. Just pull out the paper cassette, then remove all the paper. You will see 2 felt type pads on the spring loaded metal plate. Spray these 2 pads with some glass cleaner. Dry the metal plate a little then lock the plate down and re-install the cassette without paper! Make sure the lower tray is selected for paper feeding and press the print button. The machine should try to feed a few times then shut down with a P in the display. Reset the P using the clear key then press print again. Repeat this procedure 5 or 6 times. Then remove the tray, dry the pads a bit then re-load the paper, re-install the tray and give it a try. If dirty feed rollers were the cause then this procedure will fix it. Let me know how this works out.
Thank You for using Fixya
Apr 23, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
LSU error message
Remove the jammed paper. Unplug the printer from the mains and PC. Inspect the rollers, etc for tiny paper piece(s) that may be stuck, or other debris. Try to clean rollers and make sure they are dry.
Keep printer unplugged for about 2 minutes and replug and try a test print.
Also make sure that you have waited long enough for the printer to heat up before giving a print job.
Finally, it could be an issue with the paper sensor. If this is the case, you will probably have to take the printer in for servicing..
Apr 27, 2009 | Xerox WorkCentre 220 All-In-One Laser...
OPTRA T610 NOT PRINTING FROM TRAY1
What happens is that the rubber roller that's supposed to pick paper up and load it in doesn't pull the paper from the tray anymore, hence it gives the paper jam error message. If you want you can replace that rubber roller to fix the problem, however first thing I do is to take that rubber roller out (remove tray and look underneath to find the roller) and turn it inside out then fit it back. This will give the rubber roller the grip that it missed and solve your problem.
Jul 13, 2008 | Lexmark Optra T610 Laser Printer
Xerox 1008: Paper Jam when no paper is stuck
It Is a sensor that you should clean or re-locate. Try searching on sides of the roll or near the place where it shows you or tell you about the paper Jam.
Mar 20, 2007 | Xerox FaxCentre 1008 Plain Paper Laser
I can neither send or receive faxes
hi 003 - Recording paper jammed when feeding from the 3rd cassette. Remove the jammed paper. (1) Open the Printer Cover. (2) Remove the jammed paper. (3) Slide out the Paper Cassette. (4) Remove the jammed or wrinkled paper and reload the recording paper into the paper cassette. Caution: Make sure that the paper is set under the clips of the Paper Cassette. You can load about 500 sheets with standard weight paper (20 lb. or 75 g/m2). good luck
Feb 23, 2006 | Panasonic Panafax UF-885 Plain Paper Laser...
Copystar CS-1815 Printer Logo
435 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
Oloyede Monsuru
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
