Question about Aprilaire 1120 Humidifier
Aprilaire 112 How do I check the water valve? My fan runs but the water doesn't get past the valve.
    President:
  • 878 Answers
Kurt, a couple of things you can check. First when you turn the humidistat do you hear a click from the solenoid? This would indicate that you are in fact getting power. Check the saddle valve from the supply. Turn it in and out to make sure it is not clogged. You should have a inline strainer on the inlet side of the valve. Make sure it is not clogged with deposits. On the discharge side of the valve should be an oriface, make sure that is clog free. If you have an meter you can check for power at the soleniod or pull the harness off and ohm it. Should show continuity. Catriver...post back.
Posted on Oct 15, 2006
SOURCE:
Honeywell he240 no longer working. It is less than 2 months old. I noticed water had stopped flowing out of drain tube. The filter tray is not filling up with water. Humidistat clicks when turned up and...
Maybe the hose is blocked. Take the hose off the supply side, and blow into just enough to add pressure to it and see if that works.
Try this site for more details or a similar issue:
Honeywell HE240 new install not working
Feb 12, 2015 | Honeywell Humidifiers
Fan and water run continuously on he360
I'm not sure what wiring option did you use, but looks like you did not include pressure or sail switches... When the furnace blower/fan is off it should open the 24volt circuit and close the water valve (normally close) and turn off the fan. If you can post more wiring details maybe pictures or hand sketch I'm sure problem can be fixed in the few minutes.
Nov 10, 2013 | Honeywell HE360A1027 Whole House...
Doesn't turn on
Hello, check to see if you have 24 volts to the solenoid valve when the blower motor is on, if you do the solenoid valve is bad if not chevk to see where the voltage stops. Also, since tnis is a fan powered humidifier, the relay that energizes the fan could be bad aswell.
Nov 26, 2011 | Aprilaire 700 Humidifier
Humidifier is full of water but the light shows it's empty. Since the humidifier thinks there isn't any water it won't run.
More than likely, the float valve in the top of the water collection bucket is broken or stuck in the DOWN position. Turn the unit OFF & unplug it. Remove the bucket for it's holder and empty any water that's in it. Inspect the float valve to see if it moves freely. Jiggle the arm of the float valve to see if it moves up and down freely. If it doesn't then it's stuck or broken. Hopefully, it's only stuck, because in most cases, purchasing a replacement bucket with the float valve installed is your only option.
Hope this helps you solve the problem. Thanks for choosing FixYa.
Sep 17, 2011 | Essick Air Humidifiers
The water not reaching the humidirier and the fan runs couinnuously
Hello, water not reaching the humidifier can be caused sediment buildup in the strainer of the solenoid valve, a faulty solenoid valve, sediment at the saddle valve, or no power to the solenoid valve. The fan will run continously if the relay that engages the fan is stuck as it is gettimg a constant 120 volts.
Jul 06, 2011 | General Filters 1042-LH Humidifier
We have a kenmore humidifier on the furance model # 48945. it doesn't stop running so our water bill is twice what it should be. I've tried to find a manuel on line so i can figure out how to...
Noodles, it sounds like the float valve inside the water reservoir is stuck in the down position. Turn the water line ON/OFF valve to the humidifier OFF. Open the top of the reservoir and you will see the float valve. Gently, lift it up, to see if it will remain at the top of the water level, which left in the reservoir. It it doesn't, then the float needs to be replaced. In the mean time, leave the water line ON/OFF Valve OFF.
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 07, 2011 | Kenmore Humidifiers
No water is flowing to the humidifier so I obviously have a problem with where the valve connects to the water supply. With no water, the fan nothing works on the humidifier. Is this normal? If I get...
Is the saddle valve open? if it is check for sediment build up in it, if it;s clear you will need a new saddle valve. If the fan is not running than most likely you are not getting power to the humidifier, check for 24 volts to the solenoid valve. By the way do you have a current sensing relay or sail switch hooked up to this humidifier?
Dec 28, 2010 | Honeywell 360B Humidifier
Has been working well for past 5 years and now the water no longer flows, you can hear it click on and fan runs fine, will not run water in test mode
May be an issue with the solenoid valve. check for voltage at the valve. if there are error codes check the owners manual for cause. I am providing a link to the manual if you don't already have one. the last thing to check would be the control itself. the control and the solenoid valve are the 2 main items for the unit. hope this helps.
http://www.aprilaire.com/themes/aa/en/manuals/AA-Humidifier-Owners.pdf
Dec 21, 2010 | Aprilaire 700 Humidifier
It does not turn on with the furnace. the aprilaire fan does not click on and there is no water running through the system
Hi check the stat and see if the water feed is not blocked at the jet seeif you have water to the valve
Dec 22, 2009 | Aprilaire 700 Humidifier
440 Aprilaire Humitifier small solinoid doesn't open
Make shure that the the filter in the bottom of the valve is clean. Turn water off use a 1/2 & 7/16 wrench to take apart the bottom connection on valve use a small screwdriver and push the small screen out and clean then put it back together.Use the same wrenches and take apart the top of valve clean inside valve and clean small orfice in plastic water line put back together. Make shure 24volts is gettin to valve you should her a click when furnace is running or fan. It may take a couple times to clean. Hope this helps
Jan 11, 2009 | Aprilaire 600 Humidifier
Humidifiers Logo
219 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
Doug
Level 1 Expert
Joe Paxton
Level 1 Expert
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
